Saturday, May 01, 2010 at 13:58
Thanks Peter.Battery Value
Your First question you sent to me re Charging Cabin Batteries by inverter connected to same batteries , if this is possible Both inverter & smart Charger are fixed in Truck
But you stated with reservations.Please advise on what problems I will have and are I asking for some think I don't need.
I only use the smart charger to charge batteries when home to house hold Power,The Generator via smart charger if batteries are getting low when camped for some time & the solar panels can"t keep up to my power supply no sun only rain
I have a isolation switch between my starter- and cabin batteries, and also a solar regulator between solar panels and cabin batteries. with Gauges to show charge rate to batteries,& gauge to monitor Batteries 12.5 approx
I am looking for information to improve my system if possible
I wish to charge Cabin batteries with the Inverter is running of cabin batteries when
camping .l thought this would drain my cabin batteries not build the power up
When driving all 6 batteries are all been charged by Truck alternator.
Should I connect Solar Panel Permit as I only connect when parked
685153
