C/T DRAWER SEALS
Submitted: Thursday, May 06, 2010 at 21:55
Member - Scoey4 (SA)
The seals on the slide out kitchen and storage cupboards on side of my C/T are in need of replacement before trip to The Cape in July. Any suggestions on the best way to replace them and what with - the original seals were cheap and nasty - cheers.
SCOEY
Reply By: Moggs - Thursday, May 06, 2010 at 22:59
Hi Scoey,
Have done similar recently. Check out Clarke Rubber. They have a huge range of different automotive trims and seals, both pinch weld and adhesive. Just take along a bit of the old seal to match the thickness and you will be set.
415684
Reply By: Member - Mfewster(SA) - Friday, May 07, 2010 at 07:46
Hello Scoey.
As previously suggested, Clarkes are good. As you are in SA, for some items I have found Fitch the Rubber man in Hindley to be good and sometimes a fair bit cheaper.
415701
Follow Up By: Member - Phil G (SA) - Friday, May 07, 2010 at 23:30
"Fitch the Rubber man in Hindley "
hehe..... Mike, sounds like a condom salesman.....
I've been to Fitch the Rubber Man in Hindmarsh.... they have a good range of stuff :-)))
http://www.fitchtherubberman.com.au/
685872
Follow Up By: Member - Mfewster(SA) - Saturday, May 08, 2010 at 08:25
Phil, I am shocked to think that you reckon I might know about such things. They must have been under the counter.
685895
