Saturday, May 08, 2010 at 19:45
Hi Missy.
We had a similar issue some years ago with a Navara dual cab.
We went to a local spring maker here in
Cairns (he is probably not much use to you) with our
camping gear in the back.
The springs had sagged even when empty.
He took a look at it & said he would put in 1 extra main leaf & reset the other mains & we would have 1 inch extra height over the standard unladen height with our gear in the back. That is exactly how it turned out.
We left the original shocks on until they were cactus. Before they were gone we had done several trips including the GRR,
Savannah way, Tanami,
Cape York Peninsular a few times & the easy short trip into the Bungle Bungles. I think those shocks did 80,000.
My son now has a Navara & has just had the rear main leaves reset to get a little extra height & had the front torsion bars wound up by the same bloke. He didn't get any extra leaves & it cost him $240 I think.
He is up on the old coach road from
Maytown to
Laura tonight & he has the original shocks with about 25,000 on them.
I am a bit of a cheapskate & can't see value in changing shocks when the ones you have work fine. When I put new springs under my Patrol (Kings Springs & they sagged 1" in 175,000k) I kept the original shocks.
They worked fine for dirt highways like the Tanami,
Oodnadatta,
Birdsville, Plenty,
Savannah Way, Peninsular developmental Rd, Burke Developmental Rd, Kennedy Dev Rd.
At the moment I have a Hilux single cab & have put heavier coil springs in the front to handle the steel bar. I have kept the original shocks. The rear leaves have already sagged with 5000 on the clock & I will be going back to the local spring maker to have them reset.
I don't intend to do anything extreme with the car. Just dirt highway stuff like we did with the Patrol & Navara & a bit of 4 wheel driving.
Not only do you have to drive to the conditions of the road but you also have to drive to the abilities of your vehicle. I have never BLOWN A SHOCK & only know a few maniacs that have done so. But I can't keep up with them.
I suggest you go to a spring maker & talk to them about your springs. Some of these EXPERTS in these 4x4 shops don't know anything about springs.
At the end of the day they are only retail assistants
415884
Follow Up By: Lex M (Brisbane) - Saturday, May 08, 2010 at 21:27
All good advice from Fatso.
Did a similar thing with my Hilux Dualcab with a spring works in
Brisbane that's been around for about 40 years. On their advice, 1 extra leave and reset springs with about 1 inch lift. New bushes, bolts etc. Drive in/drive out for about $350.
685999
