Monday, May 17, 2010 at 10:31
As already mentioned, service it regularly, and use a 15/ 40 oil, the 20 60 is too thick.
I have extractors, and have found that i lost some low down torque, but it breathes a little bit better, but not much.
Found the best performance increase was fitting a snorkle.
We get around 9.5lts/ 100kms around town.
Have used foam unifilters before, but have decided to use the toyota genuine ones, as they have far more filter media than ryco.
Have taken them apart and checked side by side, also check my oil filters the same way, and its genuine toyota there too.
buy in lots of 10 and there 15 bucks, air filter at 50 is not that much more than a ryco one now too, and far better filtration.
Re tyres, stick with the 30" size, going up to 31" will affect your
fuel burn, and performance, you get better
fuel burn and performance with the standard sized tyres.
When I first got my lux, the oil was like thick set honey, ie turn the jar upside down, and it just starts to ooze down the side of the jar, but slowly.
I changed the oil, and ran it for a few hrs, changed it and ran for the next day, then changed it at the end of that day, ran another day and changed it again, then changed it at the end of the weeks driving, then another one at the end of the month.
This cleaned out the soot build up that the oil deposits there when it becomes saturated, and allowed the detergents in the oil to do their job.
First few changes it was lumpy and thick, now its still clearish by 1000kms running with only the soot created by combustion discolouring the oil.
Previous owner didnt use diesel oil in it either, but by cleaning out the motor like that, Im sure I saved myself a spun bearing or blocked up gallery, it must have been so close.
Do NOT use kero, or diesel in the oil to flush it, this reduced the lubricity of the oil dramatically, and will damage your big ends.
Just invest into a 20lt drum of oil and some filters and let it do its job.
I found that it took about 8000kms of running for the oil to really clean out the oil rings, and stop burning oil, it used about 1lt/ 5000km, for the first 10k or so, now its not using any.
Just a few things that i hope help with your investment.
Trains
416989
