Engine wachdog temp settings ?
Submitted: Saturday, May 22, 2010 at 13:00
ThreadID: 78659 Views:3415 Replies:6 FollowUps:17
I just fitted an engine watchdog to the Rodeo ute and it currently running at about 80oC normal running.
I have set the alarm to 90oC
I was just wondering what others here have set as alarm and running temps
I know every car is different I was just trying to get a rough idea
( It is a tiny bit bloody coolish here this morning :)
Reply By: Rock Ape - Saturday, May 22, 2010 at 13:30
Mate,
I have had mine set on aprox temp of 99C to allow for fluctations in load and ouside temp. Haven't ever set the alarm off at that setting.
I think from memory boiling point is around 110c + with a pressurized system.
Mine is just a simple Murphy gauge but it is very accurate.
Have a good one
AnswerID: 417656
Reply By: Member - mazcan - Saturday, May 22, 2010 at 13:55
hi d200dug
i have mine set at 92deg
my bravo diesel runs between 79 -84 depending on day time temp so i think if it went to 92 i would want know why
i have noticed on hot days when i pulled up on rd side the temp goes up while idling to 89 then drops back i
originly set alarm at 89 but it kept going off for above reason but does;nt now at 92
i have mine attached to rear of engine block away from fan cooling area this area gets hot very quickly if engine is overheating and will raise the alarm more quickly than being at the front of the engine in the slip stream of the fan
but that's only my opinion and i know too well that others will tell you something completly different and so be it
the watch dog will also give you the daytime temp when you first turn it on before starting motor
cheers hope this has helped
AnswerID: 417658
Follow Up By: D200Dug- Saturday, May 22, 2010 at 15:49
Thanks for the info I wanted a day time temp for the car :-)
Now I have one !
FollowupID: 687755
Follow Up By: Member - mazcan - Saturday, May 22, 2010 at 17:58
hi d200dug
yes but remember the day time temp is only applicable if the motor has'nt been running
FollowupID: 687769
Follow Up By: D200Dug- Saturday, May 22, 2010 at 18:50
Yep I was guessing it was not 60oC outside at the moment :-)
I wonder if you could fit a second sensor and switch to read the air temp ?
FollowupID: 687780
Follow Up By: Member - mazcan - Saturday, May 22, 2010 at 21:13
hi d200dug
sounds like a good and feasable idea you could contact- engine watchdog-
and see what they say
signals australia ph 07-32776770
it can be used for trans temp etc so why not air???
FollowupID: 687814
Follow Up By: D200Dug- Saturday, May 22, 2010 at 21:33
I am thinking I want to keep this as simple and as fool proof as possible :-)
I do not want to cook and engine while I left it switched on air temp :-(
FollowupID: 687818
Follow Up By: Member - mazcan - Saturday, May 22, 2010 at 23:53
hi d200dug
i have been searching on google for--- car outside air temp guages-- and theres a few in america found one i like so have sent an email to them for shipping/payment advice so now await their reply??????
gauge and sender are 2 separate items -the senders are universal -
so just choose gauge of your liking
www.carparts.com also a company called jc whitney
FollowupID: 687828
Follow Up By: D200Dug- Sunday, May 23, 2010 at 00:02
I am not sure I can justify buying another bit for the truck ( or that I can find anywhere to put it :-)
Many thanks please let me know if and when they reply I will also have a look myself.
cheers doug
FollowupID: 687830
Follow Up By: D200Dug- Sunday, May 23, 2010 at 00:04
hmmm maybe at $10 ish
Do you want one ?
let me know what the postage and handling charges are and if they are cheaper if we buy 2 :-)
FollowupID: 687831
Follow Up By: D200Dug- Sunday, May 23, 2010 at 00:18
http://www.jaycar.com.au/productView.asp?ID=QM6326&keywords=thermometer&form=KEYWORD
Jaycar $22 no worries about the internet
FollowupID: 687834
Reply By: Member - bungarra (WA) - Saturday, May 22, 2010 at 14:26
mine is set at 95 for the LC 79 / v8
VKS 1341
AnswerID: 417660
Reply By: fugwurgin - Saturday, May 22, 2010 at 14:31
i have a scanguageII in my 03 RA rodeo 3.0l TD. it reads 89oC to 94oC. currently travelling around oz towing a camper trailer. total weight of car, trailer fully loaded with passengers is 3450kgs, sat on 120kph in NT 28oC day. temp sat on 90oC. i guess 99oC would be a good setting as you would need to allow for hills etc, dont want the alarm going off prematurely.
AnswerID: 417662
Follow Up By: D200Dug- Saturday, May 22, 2010 at 15:50
Thanks I will experiment and see what suits
I have an idea of the range it should be running in now anyway
FollowupID: 687756
Reply By: D200Dug- Saturday, May 22, 2010 at 15:51
thanks all
I have an idea of the range to set it in now.
I will do some experiments ....... if it ever gets warm again down here !!! :-(
AnswerID: 417672
Reply By: Member - G N (VIC) - Saturday, May 22, 2010 at 19:18
Hi all
Does any know for sure if these units will alarm quick enough if you had a sudden and complete coolant loss?
regards'GN
AnswerID: 417709
Follow Up By: D200Dug- Saturday, May 22, 2010 at 20:28
By all reports yes !
As soon as the temp starts to rise the alarm goes off, you may lose a pump but not the engine.
I am NOT going to test this if I can possibly avoid it but that is the basis the units are sold on, temperature is recorded every 2 seconds so it is far more accurate than the temp gauge in the dash.
FollowupID: 687803
Follow Up By: Member - Roachie (SA) - Saturday, May 22, 2010 at 22:04
The answer to that is, unfortunately, NO NO NO!!!!!
You see, if you suffer a sudden and catastrophic loss of coolant (say a blown bottom hose), your coolant will be gone and the temp of your engine will start to rise quite quickly....BUT this may not be apparent on your gauge/s because they have a sensor which (in many cases) needs to be immersed in coolant to be able to register. If the sensor probe is sitting in a thermostat housing or radiator hose without coolant around it, it may not register for some time.
I have a VDO temp gauge at the back of one of the Chev's heads, I have a TM2 with it's sensor bolted to the side of the block AND I have one of these:
Engine Saver Low Water Alarm
You asked if the TM2 will react IMMEDIATELY and I said NO.
However, THIS other device WILL react INSTANTANEOULY. To illustrate my point, a few years ago when I did a coolant change, the next time I drove the vehicle, I hadn't actually allowed all the air to evacuate the cooling system. This meant that the first time I drove it around a left hand corner, the alrm'd probe (in the top hose), was momentarily not covered by coolant....the alarm sounded briefly to alert me to the fact that the probe was not covered.
This is a brilliant device and it WILL save your engine in the event of a total and sudden loss of coolant....
FollowupID: 687822
Follow Up By: D200Dug- Saturday, May 22, 2010 at 23:59
So you are saying that having no coolant in the engine will cause damage before the engine overheats ?
FollowupID: 687829
Follow Up By: Member - Roachie (SA) - Sunday, May 23, 2010 at 08:36
Not exactly....what I'm saying is that you could lose all your coolant (and damage is done from that point onwards)........... then some time later, you may be alerted to this fact as the temp gauge "catches up". The temp gauge won't reflect the loss of coolant IMMEDIATELY in the same way that the LOW WATER ALARM will alert you.
IMHO, you really need both devices. Losing coolant isn't the only reason an engine might run hot.....it could accur with a blocked radiator or a thermostat stuck or a seized water pump. In all of these cases, the LOW WATER ALARM will not alert you to a problem, as there will/may be coolant still in the engine. This is when the ENGINE WATCHDOG (or a similar alarm set-up) will be of great benefit.
FollowupID: 687841
Follow Up By: Member - Roachie (SA) - Sunday, May 23, 2010 at 08:40
I should have added...... If you were parked-up overnight and (for whatever reason....it has happened to me) lost all your coolant due to a slow leak, then when you start your engine the next day and drive off, you could go for several kilometers before the Engine Watchdog's temperature reading reached the pre-set alarm point (say 92oC for example). However, with the LOW WATER ALARM you would know straight away that there was a problem before you even select a gear.....
FollowupID: 687842
Follow Up By: D200Dug- Sunday, May 23, 2010 at 11:32
Thanks roachie I understand what you are saying but my question is, if for sake of argument my engine loses coolant overnight and I drive off with an empty radiator and cooling system.
Will any damage happen to the engine of the vehicle before the engine block reaches say 92 degrees ?
I understand that it will probably damage the water pump by running it dry but the engine is my main concern.
I thought ( and I am no expert ) that it was the high temperature that caused the damage not a lack of coolant.
FollowupID: 687858
Follow Up By: Member - Roachie (SA) - Sunday, May 23, 2010 at 13:33
Sorry, mate, but that's a question to which I do not know the answer.
I (for one) would want to know I was out of coolant (or even just "low") before I drove off.... hence my decision to fit both devices.
Just an interesting aside..... my block temperature is generally approx 10oC cooler than the coolant temp at the back of the head.
FollowupID: 687868
