Where to fit an Engine Watchdog sensor to Lc79 V8 ute?
Submitted: Saturday, May 22, 2010 at 13:30
Member - Serendipity(WA)
I purchased the Engine Watchdog sensor and just wondering where others who own the landcruiser V8 diesel have positioned their sensor on the motor. There is not a lot of room in and around the motor but I have easily found two vacant bolt holes at the front near the thermostat housing.
Also funded myself a EGT sensor. Where can I plug this in. I was considering that it should be placed within 200mm of the turbo on the exhaust side. The upper side would be just too hard to get to.
I have a Manta 3in exhaust but it has a flexible coupling in very close to the turbo outlet leaving only a bare 80mm of pipe between the turbo and the coupling. If after the coupling it would be about 300mm away. Not something I figured on. Should of had a look but I still wanted to have one fitted. Do others just drill a hole in the pipe and cut a thread to fit the sensor attachment?
David
Image Could Not Be Found
Reply By: Member - bungarra (WA) - Saturday, May 22, 2010 at 14:23
I placed my watch dog sensor just foward of the front injector. (Drivers side)There is a tube support there that is tapped into the head and the bolt is only supporting the tube as it then runs across the top of the front of the engine..if that makes sense
I placed in over the bolt first so that it is in close contact with the head then replaced the bracket for the tube
417659
Reply By:- Saturday, May 22, 2010 at 18:30
Why would you get an Engine watchdog when you can get a Scangauge?
It can do only one thing for $149, Scangauge does this plus
fuel economy, all engine sensors and fault code ident/clear for $189 plus postage.
1 you have to go into the engine bay vs 1 you plug into the OBDII port in cab
417701
Follow Up By: Member - bungarra (WA) - Saturday, May 22, 2010 at 18:41
simply because the watch dog has an audible alarm and can be set at whatever temperature you wish in order to advise you of impending temperature rising prior to being aware too late.
I have both and i certainly keep my eyes on the road more than I do the scan guage, which, as you are aware is multi functional but not audible
687776
Follow Up By: Member - Serendipity(WA) - Saturday, May 22, 2010 at 19:21
Well like Bungarra I already have a scangauge 2 which is a great device. But when you pay a lot of money for a car and then wish to keep you car in top condition adding little extras seems to be the right thing to do.
The scan gauge will only tell me what my onboard computer can read and for engine temperature I am relying on a
water sensor which I think is on the thermostat. If by some unforeseen reason I had no
water or very little
water in my system then the
water temp would not read an overheating problem. Try comparing your scangauge to your dash temp gauge on a hot day when you are pulling a load with the a/c on - your scan gauge will read more but I know my dash gauge barely moves.
These two units are only small and descrete tucked down to the lowest part of the dash and with the audible alarm I can be alerted asap there is a temperature issue.
With the cost of parts for these new motors (the V8 is fantastic) I would prefer to put a stitch in time to save nine hundred.
This is only my point of view -
David
*** Who are you
687785
Follow Up By: Member - bungarra (WA) - Saturday, May 22, 2010 at 19:27
I also have a low
water alarm for all the same reasons as Serendipity and I are explaining
687786
Reply By: Member - G N (VIC) - Saturday, May 22, 2010 at 19:13
Hi David
I agree with your purchase and not wanting to be a knocker, rather learn.
Will this unit respond quick enough to save your engine in the event of a rapid / complete coolant losss?
I fitted a level sensor to one vehical which i love, but its a bit of a job to fit, i would like to fir this more simple system to some other units we have IF it will give the same protection.
Does anyone have any tech info?
kind regards
GN
417708
Follow Up By: Member - bungarra (WA) - Saturday, May 22, 2010 at 19:31
http://www.enginesaver.com.au/
Check this out..it is a coolant loss sensor...immediately activated be loss of coolant surrounding it........the alarm will sound instantly before loss of coolant causes over heating
Have one of them too!
687789
Follow Up By: Member - G N (VIC) - Saturday, May 22, 2010 at 19:46
Hi Bungarra
thats similar to what i fitted to one vehical and i get that this can be fitted more easily to inline radiator hoses and is probably a good option.
I just thought if the other type which i think just bolt their sensor to a head loaction, if they work fine then these would be the easiest to install?
but will there be enough temp rise on outside of head before the cylender temp gets high enough to do damage if drop coolant?????
Thats the big question in my mind.
thanks for the link
GN
687793
