Settings for a Timing Belt
Submitted: Saturday, May 22, 2010 at 18:46
cobber
Dose anyone know the settings for a timing belt (Replacement Belt) Camry 1994 model
Reply By: Member - Graham H (NSW) - Saturday, May 22, 2010 at 18:59
need to read owners manuals as about that time they went from 100,000km to 150,000 change intervals
417707
Follow Up By: cobber - Saturday, May 22, 2010 at 19:45
Hi Graham, the timing belt has broken and we are going to replace it, but do not know the settings.
687792
Reply By: oldpop - Saturday, May 22, 2010 at 20:14
Cobber
If it is a twin cam just line up the timing mark on crankshaft pulley TDC and marks on cam gear if belt has broken probably has tied the valves in a Knot
Oldpop
417718
Follow Up By: oldpop - Saturday, May 22, 2010 at 20:23
Cobber Forgot to add
While you are in there change the crankshaft and camshaft seals and the
water pump been there and done that
Oldpop
687800
Follow Up By: Member - Christopher P (NSW) - Sunday, May 23, 2010 at 10:33
Only change the seals if there is evidence of oil. recently did my laser 01 kq model, no leaks from seals, so we didnt change the seals did waterpump and cam belt though. my mechanic and i did it!
His advice on seals is " No oil leak, No change seals as they will tend to leak if changed"
But that could be different
687852
Reply By: Maîneÿ . . .- Saturday, May 22, 2010 at 20:16
Have you checked to see if you have bent the valves or damaged the pistons ??
Note THIS information is NOT specifically for the Camry BUT should work
Generally... the timing marks have to be aligned, then there (probably) will be marks on the timing gears too, all have to be aligned when the belt is tightened, so often the marks have to be offset a bit to allow for the adjustment procedure.
Maîneÿ . . .
417719
Reply By: Member - Toyocrusa (NSW) - Saturday, May 22, 2010 at 20:50
Hi cobber. As said above. It is possible that the valves have been damaged after the belt broke as the pistons can interfere with them when the valve/s are open. It is not easy to see the timing marks but here is a brief explanation.
The camshaft pulley has a small hole in it, this hole is lined up with a mark on the top of the camshaft bearing journal. The best way to get the crankshaft in time is to remove the #1 spark plug and rotate the engine until the piston is all the way up at the same time temporarely install the lower timing cover and the pulley, set the pulley to the zero mark, line up the notch on the pulley with the zero on the cover)make sure that after the belt is installed the engine is rotated by hand then see if the marks are still lined up and the belt tensioner is adjusted so that the belt is tight.
If all else fails your local Library should have a workshop manual you could look at. I would also look at changing the oil pump housing gasket as
well as the three oil seals and
water pump as recomended above. Regards,Bob.
417727
Reply By: Member - Phil G (SA) - Sunday, May 23, 2010 at 08:54
Just Google stuff like this and you'll get plenty of responses:
Camry Timing Belt search
417755
Reply By: Member - Graham H (NSW) - Sunday, May 23, 2010 at 10:09
cober is it 4cylinder or V6
417766
Follow Up By: cobber - Sunday, May 23, 2010 at 19:06
4 cylinder, thanks for all the replies so far.
687912
