Tardis has its new front end .
Submitted: Sunday, May 23, 2010 at 13:36
Mandrake's Solar Power
Further to the thread 78295 concerning drawbar box -
Well its now made and fully loaded -
Image Could Not Be Found
Side
views to show all doors open and items enclosed ..
Tim Webb of Horsham is the builder ..
Jeep is now capable of 1000 Kms of travel before refill ..
Water increased to 80 litres - Stubbie capacity increased to a full slab LOL ...
Still fully solar powered and nearly ready for the
Kimberley 2011 trip.
All I have to do now is re-wire the Tardis and place a small fuse box somewhere handy ,,,
Steve
Reply By: Mandrake's Solar Power- Sunday, May 23, 2010 at 13:38
S/be previous thread 77825 ooops ..
417787
Reply By: Member - Fred B (NT) - Sunday, May 23, 2010 at 14:34
Steve,
you should have put the dunny at the top mate..... then all you had to do was open the top lid and sit on top... all done mate... lol..
Now you have to open the side... pull the dunny out... set it up... all takes time if in a rush... lol...
How does the new mods and extra gear up front affect the tow ball weight? The box is almost as big as the camper....lol..
regards
417797
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 14:43
I know I'm a bit of an exhibitionist !!! But there are limits ...
Tow ball weight just measured at 90 Kgs ... Still
well within the parameters for Jeep and trailer ..
Steve
687879
Reply By: Paul G K (vic) - Sunday, May 23, 2010 at 14:42
Steve
Bit of a worry to caryy gas cylinder on side, if pressure relief valve was to operate it will give off liquid gas instead of gas vapour
Regards Paul
417799
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 14:55
Paul ,
What's the likelyhood of that happening ? And if it does the liquid will squirt out into the box and freeze the aluminium sheet - There's no flame or electrics anywhere near so explosion's not a concern ...
I've stabilised all movement by making a cradle to hold the bottle and there's a firm foam pad on the upper lid to hold the bottle locked into the cradle .. It aint gunna move ...
Steve
687882
Follow Up By: dirttracker - Sunday, May 23, 2010 at 15:07
Steve,
I would check the legalities of carrying a cylinder in that fashion. Even if you don't mind, it may fail registration is contrary to regs. Just a thought.
687884
Follow Up By: Member - Captain (WA) - Sunday, May 23, 2010 at 16:12
Hi Steve,
I would suggest you rethink your gas cylinder storage. Here are a few links to LPG safety bulletins, they ALL state that you MUST carry a gas cylinder upright.
Kleenheat Gas NSW fire brigade adviceQLD gov advice
The problem is that if the PRV was to vent, it would now vent liquid that would expand 270 times its volume. In a sealed space like yours, with the shine shining down, the potential to vent is very high. If/when it does, this could easily rupture under that pressure as your locker seams
well sealed. Even if is didn't rupture, the gas would now sit at the bottom of the locker and any stray spark or static electricity on opening the locker .....
For your own safetys sake, you need to rethink its layout and venting.
Captain
687889
Follow Up By: Wilko - Sunday, May 23, 2010 at 16:13
Hi Steve,
There are adaptors that screw on the gas cylinder to make it safe to carry in that fashion, I it would expand 288 times so it would be like 288 gas cylinders leaking upright.
Otherwise it looks great.
Cheers Wilko
687890
Follow Up By: Member - Captain (WA) - Sunday, May 23, 2010 at 16:25
Hi Wilko,
The POL adaptors for transport only seal the gas connection in case it leaks or the valve starts to unscrew in transport, it does not affect the PRV (pressure relief valve) port and its venting. Unfortunately, there is no method of making it safe to carry a gas cylinder on its side.
Captain
687891
Follow Up By: Wilko - Sunday, May 23, 2010 at 17:51
Hi Captain,
The adaptor was being used so that acetylene cylinders could be safely laid/stored/operated on their side on a
mine ute.
It replaces the valve and afaik lifts the intake point to the highest point of the cylinder(when its on its side).
It then works the same as an ordinary cylinder, you do have to lay it down so that the intake is at the top of the cylinder though ( marked by an arrow).
Cheers Wilko
687903
Follow Up By: Member - Captain (WA) - Sunday, May 23, 2010 at 21:04
Hi Wilko,
I think we are talking about two different things, the acetylene adaptor sounds like it replaces the whole valve assembly and repositions the PRV intake, given it has an arrow indicating direction. The POL adaptor is simply a "seal" on the LPG valve in case the valve itself leaks or isn't turned off fully.
Captain
687934
Reply By: Mandrake's Solar Power- Sunday, May 23, 2010 at 16:21
Many thanks for the advice everyone - Looks like I have two choices -
move that shelf down to enable the cylinder to stand upright
OR
the cylinder will have to go on the side of the camper on one of those bracket / holders ..
Steve
417812
Follow Up By: Dave B ( BHQ NSW) - Sunday, May 23, 2010 at 17:36
Steve, I would also be concerned about that expanse of sheet metal bouncing stones back into the rear of your car and possibly break your back window.
I reckon you will have more chips than a fish & chip
shop on your tailgate.
Dave
687900
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 18:03
Dave ,
Think I have that covered - Tow hitch has a full width mud flap attached and I have a polycarb stick on rear window cover -
After the trip back from Horsham to
Melbourne I checked the front of that box very carefully for nicks and dents and there were none so it looks like the mud-flap works on bitumen - Hopefully it will work just as
well off the black stuff !!
STeve
687904
Reply By: Member - Andrew (QLD) - Sunday, May 23, 2010 at 18:36
Aerodynamics of a brick now LOL
Steve, do you any more info on the tardis branding etc? Seems like a
well-sealed setup.
Andrew
417850
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 19:20
Its a Stockman POD with Camper option .. 65 litre
water tank and side mounted jerrycan holders .. otherwise standard ..
The POD
Very light and great for towing but tiny on storage which is why the box became the option ..
Steve
687915
Reply By: Sir Kev & Darkie - Sunday, May 23, 2010 at 18:42
Steve,
What is the turning circle like now with the box so far forward??
Cheers Kev
| Russell Coight:
417851
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 19:18
G'day Sir Kev ,
Haven't done a good test yet but I did come close when doing my usual expert reversing bit -- LOL
I think that where I will take this baby it will be OK ..
Steve
687914
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 19:26
Kev ,
I think that photo doesnt do the distance any justice - My tow hitch is a long one to come out and beyond the rear spare tyre on the jeep ...
Its all bloody awkward but it works nearly ...LOL
687917
Reply By: Member - Boeing (PER) - Sunday, May 23, 2010 at 18:45
Steve, Is there enough room to lower the shelf that the gas bottle is on so that it can sit upright. From the pictures, it looks like it may go close.
Mark
417855
Follow Up By: Mandrake's Solar Power- Sunday, May 23, 2010 at 19:24
I was looking at that before and I could either lower that shelf OR cut a round hole in it and drop the gas bottle down through the hole 100 mm and it'll fit BUT that still doesn't get around the enclosed space / not-vented bit referred to above ...
I think I will have to move my electric
junction box and mount the gas bottle at passenger side rear on one of the gas ring holders welded to the sub-frame ...
That way that shelf can stay where it is and support some spare food and drinks .
Steve
687916
