HJ80 Gearbox Question
Submitted: Monday, May 24, 2010 at 22:37
Member - Wayne B (NSW)
What is the difference between a H150F and a H151F gearbox fitted to the 1HZ Diesel engine. Some heavy handed person has cracked the case at the filler plug. Now leaking oil
I am looking for a 2nd hand box and want to know what ones are interchangeable I have a 1990 Non Turbo HJ80 Diesel
Wayne
Reply By: ross - Tuesday, May 25, 2010 at 00:35
Wayne AFAIK,the difference is that the H150 is the 1HZ box and has a slightly lower gears in 1st and 2nd
There is some good information about the gearboxes here
Site Link
and some more here
http://cruiserfaq.com/08-01.php
418017
Follow Up By: Member - Wayne B (NSW) - Tuesday, May 25, 2010 at 08:30
Thank you Most helpful
Wayne B
688073
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, May 25, 2010 at 13:13
I assume that it is the alloy box as you would be superman to crack the cast iron box by hand.
Can't it be welded if it is only the raised section for the plug? It's not really structural.
Dave
418053
