Willow Jerrry Cans - Venting - Covering
Submitted: Wednesday, May 26, 2010 at 09:16
silver bravo
Hi All,
In the cargo area of our bravo (under the canopy) we have a custom rack made up for 4 x 20L Willow Jerry cans.
I have aconcern regarding the venting/potential vapour release of them as we travel, and was thinkning that if its safe, I might wrap/seal each jerry can in a strong clear garbage bag, reducing vapour exit into the cargo area.
While securley mounted uprioght in the rack, the 4 cans will be covered with a flap of carpet (to keep from sunlight and prying eyes).
I plan to vent the jerry cans every day.
We have exlectrical equipment (dual battery and work lamp wiring) wiring in the cargo bay area aswell, and i wish to reduce my risk of spark (all electrical connection are fuxed and shrink wrapped).
Can anyone give me some supporting info? I wish not to raise the issue of metal/plastic jerry cans. I just want some clear reccomendations.
Dane
Reply By: Member - Phil G (SA) - Wednesday, May 26, 2010 at 10:25
Storing petrol, not diesel I take it?
418192
Follow Up By: silver bravo - Wednesday, May 26, 2010 at 10:28
Yep.
Unleaded.
688221
Reply By: feathery - Wednesday, May 26, 2010 at 10:44
I travelled over 12000 km in a pathfinder with 7 jerry cans of petrol in the back all had good seals when fulling up made sure that no
fuel was left on can, funnel and spill rag went into air tight container inside air tight plastic bag. We never got one whiff of fumes we never vented the cans neither also do not 1/2 empty cans make sure thy are either full or empty wrapping in plastic garbage is a waist of time if the fumes get out of cans then a garbage bag tied in a knot at one end is not going to help plus the rubbing of cans will rub hole in bags I also carried spare seals but with care you should not nead these
good luck
greg
418197
Reply By: ob - Wednesday, May 26, 2010 at 10:47
How
well is your canopy ventilated? I would have thought it would be safer to make provision for petrol vapours to disperse rather than concentrating them to a point where the slightest ignition source could ignite them.
ob
418198
Reply By: silver bravo - Wednesday, May 26, 2010 at 10:50
Thanks guys.
Ill take all those notes on board.
Appreciated.
418199
Reply By: Member - mazcan - Wednesday, May 26, 2010 at 11:15
hi silver bravo
if you only put 20lts in each jerry can and not try and get extra in them
then it should have room for expansion and contraction without having to vent them each day imho every time you vent them you waste petrol
i have carried plenty of petrol in metal j/cans even on the csr/gunbarrel etc in october years ago and i have never bothered about venting them
wrapping them in plastic garbage bag will achieve nothing as petrol disolves that cheap plastic
my dual battery was in the engine bay and the fridge was in the rear
seat area so didnt have the potential for any fireworks
as for having electrical equipmt in there as
well i would hope that the battery is in a proper box
but that wont stop petrol fumes from getting in and if you have to do anything to the electricals at anytime i wouldnt attemp it while the jerries are in there
re -quote (all electricals are fuxed and shrink wrapped)
i presume you mean fused
you also have to be ever mindfull of
-if a jerry can sprung a leak and they have been known too the petrol will find its way down onto the hot exhaust through the rear tub corner drain holes i sealed
mine up with sikaflex
i carried my j/cans in a heavy duty cardboard box which had the potential to absorb some petrol for awhile at least and hopefully give a bit of detection time before leaking down and out the rear i still have the box and put diesel j/cans in it if i have to carry exta
it was a parts box i got from work and i put a layer of rubber matting under them and then put a piece of thin sheet rubber between each of them to stop chaffing or static build up this worked for me on many trips on dirt tacks
sorry about the long reply
cheers and safe travels
418204
Follow Up By: silver bravo - Wednesday, May 26, 2010 at 11:27
MAzcan,
Thanks for the info.
All electrical connections are fused and heat shrinked. The battery is in a proper marine battery box and will be sealed as much as possible (with a hose for the battery to vent outside the canopy). I wont do any maintenance while the jerr ycans are installed.
The canopy has side windows that slide open, I will keep one of these open as we travel (dirt is gonna get in anyway!).
I will take your advice and only fill to 20 liters in each can.
I have sealed up the holes in ther tub floor already. Thanks for the hint.
Im going to fabricate a spill tray to sit under the jerry's to catch any leaks.
Thanks for the advice. This site is the best!
688227
Follow Up By: Troppo Tom (Virginia, N.T.) - Saturday, May 29, 2010 at 21:44
Yeah,
Don't over fill petrol jerries past the 20 lt mark.
I was in the middle of buck-f-nowhere and opened up the jerry quickly. The little lady was not impressed with the resulting shower.
I offered to sponge her off but was given the cold shoulder for a few hours!
OOps! :-(
688842
Reply By: Member - Royce- Wednesday, May 26, 2010 at 18:57
Any vapour should disperse as you drive.
If you wrap the jerry cans then where will the vented vapour go? It will either build up in the wrap which WOULD be a ticking bomb ... or more likely dissolve the plastic...
If the jerry cans vent automatically then you don't need to vent them every day.
Good idea to hide them. In some locations petrol is very attractive [sniffing].
If you think that there is a possibility of build up of fumes from the cans then maybe vents are needed in
the tub... or maybe rethink and mount them on the outside?
Keep the cans filled
well... as I understand it, the more air space inside the greater the gas build up and therefore the greater the pressure.....
418265
Reply By: Member - Mfewster(SA) - Wednesday, May 26, 2010 at 18:59
Slightly off topic (only slightly). The best covers I have found for jerries to stop them rubbing. Get some throw away large truck/tractor tyre tubes that are stuffed from your nearest tyre dealer. Cut lengths of tube the same length as a jerry. (no, not the bit with the cap on top, just the main body of the jerry. Pull these (like a condom) over the jerries. You might need a bit of talc on the tube to help get them on if the tube you get is a bit snug. The curve in the tube stretches out straight over that short a length and the covers fit like a second skin. Strong and light.
418267
Reply By: Michael ( Moss Vale NSW) - Wednesday, May 26, 2010 at 19:10
Dane,
Do yourself a favour and buy The Rheem/Visy containers. They have a purpose made yellow cap with an "O"ring and are leak free. Willow make their containers but buy in a standard cap that fits detergent and chemical and many other 10litre 15 litre and 20litre containers and can leak and can come free of the container if overtightened. They have had a recall some time ago and you can search on the net to confirm my claim. The one good thing about Willow containers is that they have a big diameter neck that the Visy/Rheem containers dont and they make filling difficult with hi-flow diesel bowser nozzles. Obviously if you are filling with petrol , you wont have a problem. I would for safety sake, not use the Willow containers inside a vehicle with petrol.. Michael
418271
Reply By: Robin Miller - Wednesday, May 26, 2010 at 19:45
Hi Dane
I would not nothing , provided the containers don't actually leak.
However first there have been a couple of different types and I do not know yours.
Mine were all from
supercheap at under $20 each and contain a single large cap and are sort of rounded, and have no vent holes.
About two years ago they came out with a squarer design.
I just made sure the caps on
mine screwed on properly (this reuired a couple of plastic burrs to be removed and they do not leak a drop.
However there is a slight penetration of
fuel thru the jerry and as I only carry
fuel inside the car for saftey reasons you can just smell this next morning if left inside car all night.
This level of expiration will not even come close to causing a flammable issue.
Stopping them rubbing is a seperate issue and I solved this very nicely by just putting them each into one of those $1 shopping bags they flog everywhere these days.
418275
Reply By: Mike DiD - Thursday, May 27, 2010 at 19:50
"I plan to vent the jerry cans every day. "
Why ??? More petrol will just evaporate until the pressure inside the can rises to the same it was before you let some pressure out.
People need to understand the concept of Vapour Pressure - any volatile liquids will vaporise unless the pressure above the liquid is the same as the Vapour Pressure for that temperature.
Make sure there are no leaks and that the container can cope with the vapour Pressure at the temperatures you will experience.
418456
