Tail lights leaking.
Submitted: Wednesday, May 26, 2010 at 14:02
ThreadID: 78786 Views:2922 Replies:5 FollowUps:4
After several weeks of heavy rain I was checking my 'van today and noticed the six large tail light lens all have a fair bit of water in them. Is there any way besides silicone to seal them so that I can still remove them to replace globes or whatever. A mate suggested vaseline but that will only make a mess and act as a dust magnet.
Rob.
Reply By: habika - Wednesday, May 26, 2010 at 14:05
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
AnswerID: 418232
Reply By: Member - barry F (NSW) - Wednesday, May 26, 2010 at 14:08
Hi Rob, we used to have the same problem on a previous van & overcame the problem by running a light bead of silastic around the gasket area. It fixed it for us.
I also know of people who have drilled about a 3mm hole on the underside of the lense to let the water out. Cheers
AnswerID: 418233
Follow Up By: Member - Niss42 - Wednesday, May 26, 2010 at 15:34
G'day Rob, I had the same problem. I fitted new gaskets from Hella and also drilled a small hole on the under side.
Barry
FollowupID: 688273
Reply By: Roughasguts - Wednesday, May 26, 2010 at 14:18
Yep Mine did too, cheap lights on a Windsor.
I just ran the good quality black electrical tape around the lens cap join. Still there after two years of rain and travel. But before you do that dry off all the electrics and spray with Lano guard/Lanox or similar, and some sealer on the tail light mounting screws that attach to the van. The lanox is too help keep the rust out of all the electrical contacts.
Cheers.
AnswerID: 418236
Reply By: Member -Signman - Wednesday, May 26, 2010 at 14:53
You can get 'sealed' units....as used on boat trailers...
AnswerID: 418243
Reply By: Allan B, Sunshine Coast, - Wednesday, May 26, 2010 at 15:44
Hi Rob, if you use silicon, a tip is to apply it to one face only and wipe an oily rag over the other face before bringing them together. The silicon will act as a moulded gasket but the oily face will prevent the silicon sticking to both faces and so facilitate later disassembly.
AnswerID: 418245
Follow Up By: Nargun51 - Wednesday, May 26, 2010 at 17:33
Smarter than the average Bear!
What an obvious, simple and brilliant idea. Why didn't I think of that?
File it under U for useful.
FollowupID: 688274
Follow Up By: Allan B, Sunshine Coast, - Wednesday, May 26, 2010 at 19:36
Oh, and another thing.............. It can also be useful to only half-tighten the two parts until the silicon has cured, then fully tighten. This will apply more pressure to the formed sealing gasket.
FollowupID: 688312
Follow Up By: Member - mazcan - Thursday, May 27, 2010 at 13:53
hi racin rob
if you use automotive engine gasket silicon you can get it apart easily
rather than using roof and gutter etc which forms a permanant bond
FollowupID: 688483
