On board air
Submitted: Sunday, May 30, 2010 at 18:36
TehEkHo
Hey guys...
Have been doing some reading, amongst other things - and have come to the conclusion that I want to fit an engine driven air compressor.
I have, sitting in the shed, a WRX air con compressor, a SR20 Pulsar air con compressor, and a 4 Cyl Charade air con compressor. When the weather clears up (and I'm not driving to uni for my exams!) I'll get my butt into gear, and start looking at options.
I'll most likely be sticking a
tank in the boot, so I can save under body space for a larger
fuel tank...
What I want to know, is what those of you do when you put the truck away?
Do we leave the system charged, or discharge it somehow? I always got my ass kicked when I left the
tank of the garage compressor charged overnight...
If we do relieve the
tank at the end of the day - what are different methods that we have come up with to do this? Obviously, the first thought would be a ball valve on the manifold that one operated at the end of the day...
What about automatic solutions? Any reason we couldn't fit a massive valve to the
tank that released on a timer, say 1 minute after the engine stopped? With a manual valve interposed so this function could be disabled should the air need conserving for whatever reason... The big kid in me thinks that it would be cool for my little truck to go *pt-schhhhhhhhhhhh* a little while after I cut the engine...
Reply By: Rockape - Sunday, May 30, 2010 at 19:03
Same as a truck, leave the
tank charged and bleed off the
water with a manual valve on the bottom of the
tank in the morning.
A/c compressors need oil and for their bearings and seals, that oil is in the a/c gas. no oil, siezed compressor.
418815
Follow Up By: TehEkHo - Sunday, May 30, 2010 at 19:12
no cool *pt-schhhhhhh* then...
Does said bleed valve need to be elegant? Or could it just be a ball valve off of a length of hose that attaches to the lowest point of the
tank? Or even better, have the
tank mounted "Upside down" with a T piece, ball valve on the bottom,
tank on the top, and "Everywhere else" off to the side...then just operate said ball valve in the morning like you say...
Was going to put an inline oiler on the intake for the compressor, and a separator on the outlet, to take car of pump lubrication...
688944
Follow Up By: Rockape - Sunday, May 30, 2010 at 19:16
Mate, a ball valve is fine and I see you have the lube worked out.
688946
Follow Up By: TehEkHo - Sunday, May 30, 2010 at 19:17
excellent. Now all I need to work out is finding the time to do such work...
688949
Follow Up By: TehEkHo - Sunday, May 30, 2010 at 19:20
ps. Cheers for the quick reply!
688950
Follow Up By: Rockape - Sunday, May 30, 2010 at 19:24
Hey! I think you will but just make sure you have a pressure release valve fitted.
688952
Follow Up By: TehEkHo - Sunday, May 30, 2010 at 19:26
of course!
688954
Follow Up By: Dave(NSW) - Sunday, May 30, 2010 at 20:05
If you go to this site www.patrol4x4.com and type endless air in the" search" you will get heaps of info.
688963
Reply By: pop2jocem - Sunday, May 30, 2010 at 21:47
Hi TehEkHo
I have an old AC compressor that lived under the bonnet of my HJ45 troopy many years ago. I haven't fitted it to the present HZJ75 because space limitations
make it a bit more of a challenge to drive it from the engine and my 12volt compressor does the job but no where near as
well. As far as lubrication went I just took the plug out of the side and squirted in a small quantity of gear oil mixed with a little Wynns additive every now and then. The air delivery line went to a piece of 2"
water pipe with the ends closed off and a drain valve in one end. This pipe was mounted vertically behind one of the uprights of the 'roo bar. I crammed as much steel wool into the pipe as I could and this served as a separator to take the oil that left the compressor out of the air. The air then went to a
tank with a drain valve in the bottom and a pressure relief valve in the top. The air that came from the
tank had no discernible oil in it.
I don't know if leaving the pressure in the
tank does any harm but personally I have always vented the system through the drain valve at the end of the day.
You can get dump valves that operate automatically when an amount of
water is collected in the air
tank but I don't see the necessity for them on a car unless you want your little truck to go *pt-schhhhhhhhhhh just like a big truck.
As far as the time taken to inflate tyres with a 12 volt jobby versus an engine driven one I have never seen even a fairly good 12v one come even close.
Pop
418844
Follow Up By: TehEkHo - Sunday, May 30, 2010 at 22:00
May look at replacing the drain valve with something that operates automatically down the track, when the big kid in me can spend money on pointless things...
Until then, I'll stick to the manually operated ball valve.
How big a
tank do (did) you run and how long did it take to fill from empty?
689000
Follow Up By: pop2jocem - Sunday, May 30, 2010 at 22:16
The
tank is about 30 cm long and about 20 cm in diameter, took about 1 minute to charge up to about 50 psi (sorry don't know the kpa conversation just off the top of my head) with the engine idling, obviously quicker with the hand throttle wound up a bit.
The other mod I was going to do but never got around to was to fit a pressure switch that turns the AC electric clutch on and off at preset pressures rather than just letting the safety valve operate.
689003
Follow Up By: TehEkHo - Sunday, May 30, 2010 at 22:30
When I do it, I'll be wanting to add the pressure switch from the get go...
Will throw in a check valve with unloader to give me the *pt-sch* (not quite *pt-schhhhhhhh*, but still...)
689010
Reply By: Grungle229 - Monday, May 31, 2010 at 07:36
Hi TehEkHo,
You will find the system will bleed itself off over a single or couple of days either back through the compressor or small leaks in the system.
When I did my system, I was carfull to use liquid thread sealer on all connections as
well as pinch clamps for the hoses. There is a one way valve after the endless aircompressor as
well but the system only stays charged for 24 hours. This is not a bad thing as the system works as it should for when I need the air.
My install can be seen at ->
http://www.grungle.com/endlessair.html
David
418872
Follow Up By: TehEkHo - Monday, May 31, 2010 at 19:26
Grungle,
Went to
the tip today (I frequent the buy back as there are quite a few good bargains to be had from time to time...) and spotted a Sanden AC Compressor. The bloke looking after the joint wanted $10 for it, and an old school fold out
camping table (You know the kind that weigh 20kgs...) so I couldn't say no...
Its a 510 Model, so the 5 Piston job, but slightly larger than the one you used in displacement. Looks to be slightly larger too...but thats based on pictures.
Went and popped the bonnet this afternoon and had an eyeball. Looks like I'll be able to mount it down below the factory AC. Shall be making bracketry out of some 3mm plate, and most likely using the same belt as the AC... Will have a look at the AC compressor more closely when I get in there and work out exactly how I'll be knocking it all up. With some luck I'll be able to attach it off the side of the AC, and then tack together the actual mounts in place on the vehicle to save problems with alignment...
I Guess time will tell...
689131
Reply By: Member - Serendipity(WA) - Monday, May 31, 2010 at 22:26
I had an endless air setup on my old Hj75. Fits easy on that motor.
I found a twin piston a/c pump from a Jap import car that a repair
shop had lying around. The twin piston a/c pump where not that popular as they are a bit larger and harder to fit under the bonnet of new cars but they did have a small oil sump that kept the unit lubricated and did not rely on lube in the gas.
This kept going for over 10 years until I sold the car with it still working with no servicing or adding oil to it.
I ran the air into an old auxillary air
tank from an International truck that I picked up from a truck wreckers yard. (standard air fittings just screw onto these) On this I also fitted a blow off valve set to 110psi.
This was the best air compressor I have ever seen operate and could pump tyres faster than any others and keep going to pump multiple cars. Rev the car up and it would just pump even faster.
David
419023
