laptop charging
Submitted: Wednesday, Jun 02, 2010 at 19:45
Member - michael (BOXHD) r (VI
hello members need to no which is best thing for charging a laptop of a dual batt sys or is it possible . thanks mick
Reply By: Member - Danny R (QLD) - Wednesday, Jun 02, 2010 at 19:51
Depends on your lappie. Most will have a car kit which you can use. There are also some generic ones on FleaBay etc. You just have to watch that the non-genuine ones can deliver enough current for your application. I have an ASUS Eee PC which expects 12v, so I just use a direct cig lighter connection to my second battery to charge it. Works a treat.
419284
Follow Up By: Member - michael (BOXHD) r (VI - Wednesday, Jun 02, 2010 at 19:55
thanks danny i have a hp pavilion dv7 if that makes any sense to u some ppl say sine wave and some say pure sin wave so i not sure wht i need cheers mick
689441
Follow Up By: Member - evren1 (WA) - Friday, Jun 04, 2010 at 13:58
michael,
have exact same laptop.
I bought genuin HP 12 V charger off ebay. you can't go wrong! Charges fine off my dual battery set up in car and camper.
Evan
689711
Reply By: ABR - SIDEWINDER - Wednesday, Jun 02, 2010 at 20:47
Can you send me the plug size and a photo if possible and I will see if one of our new tips on the 90W charger will fit.
Derek from ABR
419290
Reply By: Steve and Viv - Wednesday, Jun 02, 2010 at 20:50
The Sine Wave thing is only if you are planning to use 240 volt. The question with that is why... You are far better to *convert* 12 to 17-19 volt or what ever your lap top needs. This is also safer that inverting 12 to 240,
well it is if your on the move but there is less waste in converting rather than inverting. You can get good converters form
places like DickSmith etc. Just make sure you look at the bottom of your PC and what ever you buy can deliver the power voltage and amps at 12 volts.
419294
Follow Up By: Ianw - Wednesday, Jun 02, 2010 at 23:16
errr, the problem with DC (12v) is that it cannot be converted or transformed into a higher voltage with out going thru conversion to AC, then a transformer to the higher voltage and then rectified back to DC. (i.e an inverter). These 12v to 19v converters are still
inverters; they just don't convert to 240v 50hz.
By using a high frequency they can be made a lot smaller and are more efficient than the 50hz ones. BTW if your lappy needs 5 amps, that is 5 amps at 19v, not 12v! Probably pulling 8 amps of 12v.
Ian
689471
Reply By: Maîneÿ . . .- Wednesday, Jun 02, 2010 at 23:45
michael,
I use a 300 watt Pure Sine Wave inverter
Gwwgle "inverters" and read the difference between Pure sine wave and those that are NOT pure sine wave
(that way I can't be held responsible for the results :-)
If I thought a cheaper non-pure sine wave was as good I would have saved money and bought one, but obviously I don't, so I didn't.
They can power any *realistic* 240v appliance you have with you.
Maîneÿ . . .
419320
Reply By: Maaate - Thursday, Jun 03, 2010 at 06:29
I found that when using a cheap modified sine wave inverter, I am able to power my ASUS laptop, but not my IBM Lenovo. (Using the 240V power supplies for both computers.)
I have no idea of the technical reasons, but it seems that some computers are more 'sensitive' to the power input.
419333
Follow Up By: Ianw - Thursday, Jun 03, 2010 at 19:13
I have an "IBM" Lenovo. It runs
well on a $20 12v to 19v converter from Ebay.
Battery is fully charged in 30 mins.
Ian
689584
Reply By: Member - Laurie K (WA) - Thursday, Jun 03, 2010 at 09:04
I have used Modified Sine Wave
inverters and had problems. I knew I was doing the wrong thing when I bought it. Have just purchased a Projecta Pure Sine Wave 150w inverter, plugs straight in, and works a treat.
They are more expensive, but ya pay peanuts, ya get peanuts. The power delivered is clean power, NOT a hybrid power.
Incidentally, a plug for the guys who sold it to me. I was in Mt Isa, shopped around knowing that I wouldn't get one in town, but was helped heaps by the girl at Dick Smith (who only had Modified
inverters the same as the one that died on me, but rang around other companies in town), and the guys at Auto Pro, who researched it, rang me back 3 times, ordered it, and had it for me as promised at 1pm the next day.
419349
