Thursday, Jun 10, 2010 at 12:19
Pat,
I second drivesafe.
Spiral wound lead/tin are the fastest lead acid batteries, in terms of current discharge and recharge.
They can accept charge from 0 to 95% within a lightning fast 45 minutes with the right charger/s.
And yes, they can be charged quickly by alternator up to 85 or 90% SOC.
If you come home, connect a good quality charger to it and let it top off the charge overnight.
Just by coincidence, I did a test a few days ago: put the spiral wound baby into the
Paj, and turned on the high beam. Left it sitting there for 2 hours 15
minutes, after which time the voltage had dropped to 11.8V under load.
Then I took the battery inside and used two 25A fast chargers* to
boost charge the battery at 14.8V at a combined max charging current of 50A.
I could watch the terminal voltage creeping up as the 50A pushed up the SOC
faster than the police would allow it. But surprisingly there was hardly any
warming of the battery, maybe 5 to 10 degrees above ambient if at all.
After 30 minutes or so, the voltage was 14.4V and the current started to
taper off. After another 15 minutes, the chargers went into float charging
mode, which signals a SOC of around 90 to 95%.
*(see photo of the setup attached)
Sorry, if I'm boring you with this, but I do this battery
charging/discharging/load testing thing on an almost daily basis. And from
what I've seen so far, these pure lead/tin spiral wound batteries react
extremely quick to applied charge, they just suck it in. They have me
excited as you might have guessed....
So if you're after really quick recharging times, this is the technology of
choice.
These batteries certainly will help you save in the long run, due to reduced
generator run times, and due to their longer cycle life.
Best regards, Peter
420290
Follow Up By: filosoph - Thursday, Jun 10, 2010 at 18:37
Hi Peter
Once we are on the road there is little chance of 240 volt charging. Refer to my posts to you via walkaboutcoffee email address.
I like the idea of the of the batteries you are talking about now in the above post. Are they the same ones you emailed me about a few months back?
Pat
690504
