Wednesday, Jul 07, 2010 at 17:46
I agree with all above, when you fit your aux batt up front,get some double sided silver insulation ,as in the stuff you put over your window to keep the sun out and wrap it round the batt.,before installation.ABR sell insul packs for this application,that will stop most of the motor heat. I have done it on my 80s,it works
Ray,I have the same as you on the draw bar,I have also direct wired my van frig off the battery with heavy cable and fuse,it was an easy job,no voltage drop now, The batt., is fed thru an anderson plug connection.I also undid the 12v wire at the 7 pin plug to stop backfeed from the batt.,. Regards Keith C
693782
