fitting fans behind three way fridge any info or thread thanks in advance
Submitted: Sunday, Jul 11, 2010 at 11:08
Member - Norm H (QLD)
Reply By: Sir Kev & Darkie - Sunday, Jul 11, 2010 at 11:24
Norm,
Thread 1Thread 2Thread 3Thread 4
Found by search the
forum for "Gas Fridge" and "Second Fan"
HTH
Cheers Kev
| Russell Coight:
423634
Follow Up By: Member - Norm H (QLD) - Sunday, Jul 11, 2010 at 12:03
thanks kev for assistance
cheers Norm
694113
Reply By: Member - Keith C (NSW) - Sunday, Jul 11, 2010 at 12:46
Gday Norm,this is what I did, I got a frig fan with a thermostat from Caravan Accessories and a sheet of 25mm styro foam, then removed top and lower external vents and glued the foam to the inner wall of the van in the frig space to narrow the void between frig and wall,this makes a better flue effect.
I then stuffed as much insulation around the sides and top of the frig as I could.
I mounted the fan to the floor on a bit of rubber to stop vibration,and connected the wires to the 12v
junction block,it cuts in and out as needed, mount the fan as close to the condenser as you can. I also have a computer fan mounted to the inside of the top vent sucking out, its wired to the thermofan as
well. I have wired the frig direct to the van battery with 6 b&s cable, fused at the batt.,.It all works
well on hot days. Hope this helps
Regards Keith .
423637
Reply By: Member - Heather G (NSW) - Sunday, Jul 11, 2010 at 14:39
Hi Norm,
I asked our local RV repair man to do just this for our 184 litre Dometic 3Way fridge only a few months ago, as it used to run very hot. When he pulled it out he discovered that the insulation around it hadn't been done and the problems we were having were due to that and failure to vent it to the outside. In other words - faulty installation of the fridge.
When he fixed this he said it was not necessary to fit the 12v fan and we have recently returned from a trip as far north as
Cooktown with no problems. The fridge no longer heats up the pantry cupboard next to it and kept its temperature constant regardless of the temperature and humidity outside. We ran it on gas (for up to 8 days at a time) and 240v while we were away, as
well as 12v when travelling between camps, thermostat constantly set on 3. I keep a fridge thermometer in it to check that the temp is below the safe zone so as to avoid food poisoning and spoilage of food.
I also had the wiring checked and it was all replaced wih heavy duty stuff direct from the tow vehicle when running on 12v, rather than going through the smart charger.
Maybe you dont need to fit the fan after all if you check it out. If not, I am sure some other person on EO will be happy to give you the information necessary.
Hope this helps.
Heather
423651
Reply By: Member - res.q.guy (Vic.) - Sunday, Jul 11, 2010 at 16:19
Reply By: Member - Norm H (QLD) - Sunday, Jul 11, 2010 at 23:27
Thanks for all info received,
regards NORM.
423718
Reply By: Member - Willie , Sydney. - Monday, Jul 12, 2010 at 09:02
Hey Norm,
How is the fishing? Got any metre barra ?
I have been over in
Leonora - got over 2 oz gold in two weeks, came back and went to French Open and Wimbledon with my wife.
Willie
423743
