smart charger
Submitted: Tuesday, Jul 13, 2010 at 19:50
ThreadID: 80062 Views:3735 Replies:5 FollowUps:3
I Have a smart charge BC-012-15A on my van. I have just discovered the light circuit was dead. When I checked the battery was dead flat and the smart charger seams dead as well. The 240v supply to the charger is ok and when a separate current was supplied directly to the battery all the downstream circuits were ok too.
Can these chargers just die? Do they have internal fuses? How can I prove the charger is the problem, nothing seams to light up?
Reply By: TerraFirma - Tuesday, Jul 13, 2010 at 20:09
They have a 15-20amp fuse. They can blow fuses sometimes if you clip and unclip the croc leads on and off a battery whilst the power is on. I don't use this charger I use a Ctek, but speak to Derek at Sidewinder if you get stuck.
Sidwwinder SmartCharger Link
AnswerID: 423942
Reply By: Member - Ron M (NSW) - Wednesday, Jul 14, 2010 at 14:17
Do you have dry cell batteries in the van..
Ron
Ron MACKENZIE
AnswerID: 424021
Reply By: Member - Charlie M (SA) - Wednesday, Jul 14, 2010 at 22:31
If battery is dead flat it may need hooking to a charged 12 volt battery then starting charger as most late model chargers will not start if battery below 7 to 9 volts, as it deems battery faulty.
Some chargers will go below this down to 2 or 3 volts but you need to look at charger specs.
Charlie
AnswerID: 424071
Reply By: Member - Ron M (NSW) - Wednesday, Jul 14, 2010 at 23:24
A smart charger will not charge a dry cell battery
Ron MACKENZIE
AnswerID: 424075
Reply By: Morgo007 - Thursday, Jul 15, 2010 at 09:00
Thanks for the replies guys.
The battery is one of those sealed gel types. I measure it still has 1.9v of charge. I'll throw it on my other charger then put it back in and see if the smart charger kicks back in. Thanks Morgo
AnswerID: 424094
Follow Up By: Roach"ee" - Thursday, Jul 15, 2010 at 16:22
I think if it's been allowed to drop to 1.9 volts, there is a better-than-even chance that the battery is a bit like wallaby-Ted's brother..... (ie: Roo-Ted).
FollowupID: 694541
Follow Up By: Member - Ron M (NSW) - Sunday, Jul 18, 2010 at 15:23
A smart charger will not charge sealed gel types battery.
Ron
Ron MACKENZIE
FollowupID: 694823
Follow Up By: Member - Andrew (QLD) - Sunday, Jul 18, 2010 at 18:37
Tell us more Ron???
My "common" smart charger charges GEL type batteries, i'm almost sure most others would do the same.
1.9V is another issue ;)
Andrew
FollowupID: 694850
