Saturday, Jul 24, 2010 at 09:36
John,
I've this *question* for you, - What’s the value of having a 140 Amp alternator ???
You've said above: "I've used 20A or 30A fuses in that position for years. I also monitor charging current continuously. I've never seen more than 20A flow into my batteries"
You believe the maximum amperage produced by your 140 Amp alternator is just 20 Amps, this is obviously because it would 'blow' your 20 Amp fuse?
So according to your information, to have an alternator that can produce anything above 20 Amps is a complete waste of time, however I don’t believe Toyota & Nissan are aware of that information ?
John, then you say: “The alternator voltage is determined by feedback from the *cranking* battery, so will never rise high enough to force that sort of current into a deep cycle battery”
What absolute rubbish, you obviously don’t understand the Deep Cycle battery is wired in parallel to the Cranking battery when it’s being charged.
Effectively these two batteries are in fact just one large single battery with the exact same voltage.
The alternator voltage is then determined by feedback from this one large battery, (Cranking and also Deep Cycle battery combination) not from just the Cranking battery at all.
Please keep information factual, I hope you will consider this as 'constructive comment' :-)
Maîneÿ . . .
695548
