Hard wiring a fridge...
Submitted: Tuesday, Aug 10, 2010 at 18:13
townsville
If i ran cables from the battery direct to a 12v fridge ,without a ciggy plug or any sort of plug, would that drain less power out of the battery???Would the engle or wacoe be less power hungry??
Reason i ask is, does the plug interfear with the direct currant comming from the battery? if i did this i would use a inline fuse...
tks in advance
Reply By: Member - Joel and Michelle (WA - Tuesday, Aug 10, 2010 at 19:11
I' not going to say that hard wiring is the best way to go, but the more connections you have have from power source to fridge the more resistance you get which uses power. I would still want to be able to unplug if desired.
Joel
426868
Follow Up By: townsville - Tuesday, Aug 10, 2010 at 19:19
Not going to totally hard wire it joel..just going to do away with the plug..ciggy plug.....i think the less resistance it has the better the fridge will work?? dont know...
697479
Follow Up By: gbc - Wednesday, Aug 11, 2010 at 05:36
yes it will work - yes it will be better. Fridge leads are dodgy compromises. Just fuse the positive side or better still run through a resettable (?) breaker.
697506
Follow Up By: Mike DiD - Wednesday, Aug 11, 2010 at 12:06
Cigarette Lighter sockets were only ever designed to rpovide power for 10 seconds - don't use them.
There are plenty of plugs which will work reliably and wihout voltage drop for many years e.g. Anderson Plugs.
697520
Reply By: Maîneÿ . . .- Tuesday, Aug 10, 2010 at 19:18
townsville,
You definately use an inline fuse at the battery end of the power cable.
Use 10mm² or larger cable from the battery to the fuse, then I assume your going to connect the fridge cable to the fuse.
This method will give the least voltage drop in the fridge power cable.
If you use this method you can change the fridge from the direct to battery situation back to a ciggy plug etc, by adding a 'missing' section of the fuse container to the ciggy plug cable.
Maîneÿ . . .
426871
Reply By: AlbyNSW - Tuesday, Aug 10, 2010 at 20:39
I cut
mine leaving about 6 inches of cable from the cig plug then fitted anderson plugs to both ends. That way you can re use cig plug if you want it in another vehicle etc. I then ran a hard wired cable direct from battery with an inline fuse with an anderson plug on end to connect fridge with. I don't think it is a case of draining more or less battery but getting a good solid connection so that your fridge works properly
426882
Reply By: DeanoNSW - Tuesday, Aug 10, 2010 at 21:40
I hard wired my Waeco CF80 into the back of my patrol after a tragic trip away.... pulled up after a hard drive with some serious country behind me only to find that the ciggie plug had come loose and the beer was warm. Tried with the red cover to the plug removed and a different female end - same result a month or two later.
So - I bought a second power lead and cut the end off it and hard wired it into the truck. Never ever let me down since. The other thing you get is less voltage drop as one less connection in the circuit.
426893
Reply By: bks - Tuesday, Aug 10, 2010 at 21:57
I hard wired my fridge as the cig lighter connection kept working loose. However I was still having voltage loss problems so I installed the Waeco wiring kit which has a ""merit" (spelling) plug connector which is very tight. I have had no problems since with either voltage loss or loose connections.
426895
Reply By: just - Wednesday, Aug 11, 2010 at 08:32
Direct wiring to fridge wont make fridge "less hungry" or reduce power required to run fridge. But it will reduce possible sources of power loss/heat generation etc caused by bad connections (especially cig sockets!). Also the correct sized wiring helps to reduce voltage drop.
426919
Follow Up By: Mike DiD - Wednesday, Aug 11, 2010 at 12:07
If the fridge is powerd by an Inverter then as the voltage drops at the fridge, the current drawn will increase to maintain constant power.
697521
