Wednesday, Aug 18, 2010 at 22:04
when planning your trip you will be amazed at what
fuel is actually available out there, dont factor in the
fuel purchase price as the "be all, end all" as we see many vehicles way overloaded with
fuel and for trips to
places where
fuel is available,
fuel is very heavy to carry and also takes valuable room up, speed is the main killer of
fuel and a lot of reports and even "blogs" you will find people have way over estimated
fuel usage and comment how they did not need to carry all the "jerrys" after all, at about 20kg per jerry it adds a lot ....
Do up your "budget" based on the most expensive
fuel for the trip and you can only win, if needed think about a small trailer as a RAV4 aint that big inside and you will need a fair bit of
camping gear if you plan to go to
places where
fuel is not available, you can add extra
fuel and
water in the trailer and keep the "good" gear in the car, trailers can be made small but strong so dont over look them ...................
That aside ..... if you do go the cans on the roof, wait until you are absolutly certain you need them and then fill them, drive a bit slower of course, tie, strap, bolt them down so the filler is at the top and you can buy a "pump" that is a syphon as
well and clip it on to the jerry while it is still on the roof, dont bother to un-tie it and it will syphon down into the
tank ....... that is about the ONLY good thing of having them on the roof .....
427630
