Montezuma Falls TAS
Just wondering if the above 4WD track is suitable for a vehicle travelling solo with no recovery gear. We have a Toyota Prado and will be there late Sept or early Oct.
Reply By: Member - Tony (ACT) - Thursday, Aug 19, 2010 at 15:07
Found the track slow and potholled, but no problem for a single vehicle.
AnswerID: 427713
Reply By: Signman - Thursday, Aug 19, 2010 at 15:50
We attempted it in March..there is a 'nasty' hole about 1 km in. We were on our own so chickened out.
I reported it to Forestry- so may be fixed by now.
AnswerID: 427724
Follow Up By: Member - Min (NSW) - Sunday, Aug 22, 2010 at 17:33
That hole was there in Feb 2006 when we also chickened out. We were on our own and in an XTrail. The hole was full of water and we were less experienced. I hope it's fixed by the time we pass by that way again - otherwise I'll walk in.
FollowupID: 698722
Follow Up By: Member - Norm C (QLD) - Sunday, Aug 22, 2010 at 21:04
We did the drive in Feb this year. The hole was certainly there then. By going to the extreme left (going in), you can get a good line. You need to get out and walk it first.
I must admit, I didn't do that initially and tried to just drive through. After the embarrassment of an initial failure, I did what I should have done in the first place. After having a good look, I drove straight through (well almost around) the obstacle. On the way back I took the same line with no hesitation.
Other than that hole, it was just a rough track. No great challenge and compared to other drives, nothing special. I commented to my wife that if we go back to Tassie, we will walk into the falls from the other side. I think it would be much more memorable. I did the first 1km or so of the walk out (just to have a look) and it seemed more enjoyable than the drive.
The falls is well worth the visit though.
For an easy drive through similar terrain, but much more pretty, do the Bird's Bridge drive at Kelly's Basin near Strahan. If you have the energy do the walk to the deserted town of Pilinger at the end of the drive.
Some info and pics in my Tassie Blog.
Norm & Kabby's Tassie Blog
FollowupID: 698766
Follow Up By: Member - Min (NSW) - Monday, Aug 23, 2010 at 10:18
Norm,
Thanks for the info. Your blog has certainly whetted my appetite for another trip to Tassie. Such a small island, so much to see.
The weather was foul when we were at Snug and further north but we bided our time in Richmond waiting for a flight to Melaleuca and Bathurst Harbour - highlight.
I'm always surprised that people go to Port Arthur but do not explore the rest of the Peninsular. It is spectacular, as your photos attest.
Travel safely,
Min
FollowupID: 698797
Reply By: jeep cherokee - Thursday, Aug 19, 2010 at 15:57
Hi Matmob, i was there last March(2009) and only proceeded about 200 m before deciding to turn back.I would not advise going after there has been substantial rainfall especially.It is a reasonable walk back if you do get stuck.Also remember the route out requires a certain section that follows the river bed before you can exit up the river bank.
When on the Spirit of Tasmania do yourself a favour and get the Tasmania 4x4 book from their tourist shop.It gives you all the 4x4 tracks and their degrees of hardness etc etc.
Proved to be invaluable for us.
AnswerID: 427727
Reply By: Motherhen - Thursday, Aug 19, 2010 at 16:41
You can still get to the falls from the alternative route which we did with our caravan in tow, in the rain. Quite a long but flat walk along the old tramway to the falls (a bit slippery in places when raining).
AnswerID: 427734
Follow Up By: Member - Norm C (QLD) - Sunday, Aug 22, 2010 at 21:07
After having done the drive this year, that is the way we would do it next time. Looks a very pretty walk - but yes it would be a bit wet and slippery after rain.
Norm C
FollowupID: 698767
Reply By: Peter_n_Margaret - Thursday, Aug 19, 2010 at 17:40
Great drive, takes longer than you would think though.
We cleared a few low trees in 2006....LOL.
Most of it is quite easy because it used to be a rail track, but of course all the old wooden bridges are long gone, so the creeks are the interesting parts....
OKA196 Motorhome
AnswerID: 427740
Reply By: matmob - Thursday, Aug 19, 2010 at 17:47
Thank you. There are a variety of opinions - has anyone done this track this year? 2010?
AnswerID: 427741
Follow Up By: alby1 - Friday, Aug 20, 2010 at 14:05
Yes we did it early this year ,however we turned back after a while found it too rough for our motorhome.
FollowupID: 698490
Reply By: Crackles - Friday, Aug 20, 2010 at 18:06
The track in is fairly flat & for the most has a firm base. In places it is developing ruts which I would recommend good all terrain or mud tyres to safely negotiate in the wet. At a minimum you'd need a tyre gauge, shovel & air compressor. If you have no recovery gear at all on a stock Prado I'd suggest taking the walking track in from Williansford on the East side. Could always pair up with another vehicle as the falls are well worth the trip in. I believe the Ring River Track which gets very slippery is no longer open.
Cheers Craig..........
AnswerID: 427872
Reply By: Rod E B - Monday, Aug 23, 2010 at 11:46
We drove in from the other end , with caravan,
walked in , track level until the end
This is one of the best waterfalls I have seen
AnswerID: 428115
