Trailer: hubs or drums?
Submitted: Saturday, Aug 28, 2010 at 15:32
ThreadID: 81013 Views:4609 Replies:7 FollowUps:10
At the supplier I noticed that drums and hubs to suit my Rover rims were the same price - $100ea. They only had one of each so I ordered a new pair of hubs as that was my initial plan anyway.
On reflection though, is there any reason I shouldn't fit 'empty' drums, thereby saving myself $200 off the cost of an electric axle in the future?
Reply By: Rangiephil - Saturday, Aug 28, 2010 at 16:34
Only if they are electric drums I found they weigh about 10Kg each.
I machined them off my parallel hubs.
One slight negative of hubs only is that the drums would probably shield the seals from dust a bit, but my seals seem to last OK. I use marine seals.
Regards philip A
AnswerID: 428761
Follow Up By: wortgames - Sunday, Aug 29, 2010 at 07:30
Thanks Philip, I think I'll see if I can change the order.
You're not aware of any difficulties matching a new axle to old hubs in the future?
FollowupID: 699542
Follow Up By: On Patrol & TONI - Sunday, Aug 29, 2010 at 10:43
wortgames
There are two types of bearings used in most light trailers currently, they are the light duty (holden style) bearing (up to 750kg/axle as used on cheap box trailers) or the heavy duty slimline (ford style) bearing (up to 1100kg/axle as used on many 4wd trailers, smaller caravans 2 tonnes and under + other braked applications) These are the two most common arrangements.
An ethical supplier will not sell you 4wd stud pattern hubs on the light duty bearings, BUT strange things do happen sometimes.
The frormer 750kg is not used on braked axles, the latter 1100kg is.
Therefore if you want to fit drums to your axles now then you need to have the latter style axle to suite them.
This you need to know beforehand, the supplier will be able to confirm this for you.
Without the 1100kg/axle bearings you will not be able to do what you want to do.
Hope this helps, Colin.
FollowupID: 699555
Reply By: On Patrol & TONI - Sunday, Aug 29, 2010 at 10:50
wortgames
if you buy an axle fitted with the brake mounts and drums now then all you have to do later is buy the backing plates for the brakes and install them at your will.
By then it would only be a little more money to get your full braked axle first up and not muck around worrying about will this or that fit later.
JMHO, cheers Colin.
AnswerID: 428810
Follow Up By: Injected - Sunday, Aug 29, 2010 at 12:30
Colin
You missed a popular bearing combination of parallel bearings where two ford inner bearings (ALKO) are used, or one ford inner and one holden inner ( vehicle components).
FollowupID: 699569
Follow Up By: wortgames - Sunday, Aug 29, 2010 at 14:11
Hi Colin, thanks for the replies. The trailer is a 20 year old Carac off-road 6x4 with 45mm axle and (I believe) slimline bearings. I'd like to replace the hubs ASAP as I'm working it quite hard lately and I did a bush repair on one of them a couple of weeks ago which I don't totally trust. More importantly the wheels and tyres are long overdue for replacement. I'm getting new rubber mounted on some extra rims for the car this week, so I'll have a spare set of perfectly good Rover wheels and tyres crying out to be used.
Electric brakes would be nice but with all my current expenses and a 1950's caravan project that needs a new axle first, it will have to wait. I just know that when I was pricing an axle for the caravan, I was going to have to pay extra for Rover drums anyway, so it struck me that I might as well get drums for the trailer now - providing that there aren't any problems associated with running empty drums, or with fitting them up to a new braked axle at a later date.
If the drums cost the same as hubs, then the only downside I could see would be if running empty drums was impossible or undesirable, which doesn't sound like the case?
FollowupID: 699577
Reply By: Rangiephil - Sunday, Aug 29, 2010 at 13:36
Mine are ALKO parallels.
Just to save you the potential angst that I suffered, you do realise I hope that ALKO parallels with Rover pattern are AF threads.
If you want to fit Range Rover or Disco mags you have to have the PCD drilled by a shop and use Rover studs which are metric. You also cannot get the Rover patterned hubs and punch out the ALKO studs as their Knurled section is bigger diameter than the Rover studs
This caused me months of frustration.
Regards Philip A
AnswerID: 428825
Follow Up By: wortgames - Sunday, Aug 29, 2010 at 19:04
Hi Philip, I don't quite understand what you are saying. What are Alko parallels?
When I initially enquired about the axle I was told my Rover alloys would definitely fit the Rover drums they would supply. My understanding is that the RRC wheels are interchangeable with other Land Rover models such as Series, early Disco and Defender.
The wheels I have are all the three-spoke Highline/Vogue type:
Are you saying these wheels need a special hub/drum which is different to what Alko/Carac can supply?
FollowupID: 699604
Reply By: Rangiephil - Sunday, Aug 29, 2010 at 20:35
No , I am saying that your special Rover mag wheel wheel nuts will not go onto the studs on the hubs, as the studs if ALKO will have an AF thread not the metric thread of a Land Rover stud.
Believe me I know.
You should verify very carefully with whoever supplies the hubs if they are not ALKO, that the studs are metric.
AND the next problem is that you just cannot knock out the AF studs as the hole will be too big for the Land Rover studs, so you will have to have new holes drilled in the hubs.
There is no problem if you want to use steel wheels as they can supply steel wheel nuts to suit.
BUT there are no aftermarket AF nuts to suit Range rover MAG wheels.
Regards Philip A
AnswerID: 428882
Follow Up By: Rangiephil - Sunday, Aug 29, 2010 at 20:41
ALKO Parallels are stub axles which are heavy duty and have inner Falcon wheel bearings at each end of the stub axle.
To try to clarify even more, I have emailed ALKO about 3years ago when I did mineand they told me that all their studs are AF " as they are not in the car business but the caravan business"even though Rover has had metric studs since about 1970.
The PCD will be correct but AFAIK all ALKO hubs and drums have AF studs, so while the wheel will fit the studs you cannot do up the nuts.
Regards Philip A
FollowupID: 699623
Follow Up By: Rangiephil - Sunday, Aug 29, 2010 at 20:43
BTW for parallel bearings the only hub available is with electric drums. That is why I had to cut mine off.
Regards Philip A
FollowupID: 699624
Follow Up By: wortgames - Sunday, Aug 29, 2010 at 22:12
Thanks Phil, I think I get it now.
As far as I know they will be made to order so I'll suss out the stud options. Presumably the worst case is that I'll have to try and find the studs elsewhere and see if Alko will manufacture the hubs/drums to suit them.
Where did you get your studs from? Any other suppliers you can recommend?
FollowupID: 699632
Follow Up By: Member - Ed C (QLD) - Sunday, Aug 29, 2010 at 22:47
FYI,
GalPro Engineering
will make for you any type of wheel stud that you may require, and from my experience at very competive prices..
Regards,
Ed C
Confucius say.....
FollowupID: 699635
Follow Up By: Rangiephil - Monday, Aug 30, 2010 at 09:13
Any Land Rover speciialist can get the studs.
IMHO the best thing to do is get the hubs undrilled then take the hubs to a machine shop who can drill the hubs and fit the Lanrover studs.
The studs have to be countersunk to give the same EMERGED length as on a Range Rover hub, as if too long the nuts wiill not do up as they are capped, and if too short are illegal.
Regards Philip A
FollowupID: 699647
Reply By: wortgames - Monday, Aug 30, 2010 at 14:13
Thanks for all the tips, I suspect you guys are saving me a packet!
Surely most landrover studs would not be metric? Which models would I need to get studs from?
I'm told that getting blank drums machined to accept my own studs may have its own dramas - the aftermarket drums are relatively thin and depending on the thickness of the stud flange it may not be possible to recess them enough to clear the brake shoes. That's without even considering the amount of protrusion out the front of the drum.
Another solution to all this is to just get the regular Alko rover hubs and a set of alloy wheel adaptors. I don't think I'll have any problems accomodating a slightly wider track on the existing trailer, and any new axles for the trailer and caravan can be specified with the adaptors taken into account.
I'll continue my enquiries and let you know how I go, but thanks again for all the feedback.
AnswerID: 428925
Reply By: Rangiephil - Monday, Aug 30, 2010 at 16:39
Surely most Landrover studs would not be metric? Which models would I need to get studs from?
All Land Rover studs from about 1970 on are metric. Strange but true.
And AFAIK they are all the same size and pitch. Certainly all RRC and Disco are the same although you would have to get studs for mag wheels RRC 1987? onwards as they are a different length AFAIR.
Regards Philip A
AnswerID: 428942
Reply By: wortgames - Wednesday, Sep 01, 2010 at 13:10
I now have a solution and I want to give some props to a couple of people.
Steve at Eastern Wheel Works was ridiculously helpful and gave me a whole list of places that might be able to help.
The first name he gave me was Melbourne Trailer & Caravan Supplies in Chelsea Heights. I have just got off the phone with Chris and they can supply 10" drums with 16mm Rover studs for $220 a pair +GST. Just takes a couple of days to make them up.
Thanks again for everybody's help!
AnswerID: 429104
