Bush Mechanic Course??
Submitted: Thursday, Sep 09, 2010 at 11:36
Frankie Paj
Hi All,
I have been really enjoying getting into the 4WD scene over the last year or so. I'm getting more adventurous and feel I really need to know my vehicle better. If something goes Twang or Bang I want to give myself every chance of fixing it. I know very basic things like changing the oil but there are still things in the engine bay that I don’t really know.
What are your suggestions for learning more? Would a one day bush mechanic course such as
http://www.getabout.com.au/shopexd.asp?id=48 do the trick? Can anyone recommend a good course? Alternatively should I just get some books out at the library and go over the vehicle myself? I have a ’98 Mitsubishi Pajero 2.8TD.
Frank
Reply By: dazza62 - Thursday, Sep 09, 2010 at 12:19
Great idea Frank as it is good to have some knowledge and experience when everything goes pear shaped.
Don't know anything about the course operators or course content but would be worth exploring further. Others on here may know more.
You can at least feel safe in the knowledge that you are driving a Pajero, from my experience they are almost bullet proof.
429745
Follow Up By: Frankie Paj - Thursday, Sep 09, 2010 at 15:38
Thanks Dazza, it has been a top vehicle so far, touch wood!
Frank
700547
Reply By: Moose - Thursday, Sep 09, 2010 at 13:18
Get yourself the workshop manual and start servcing the vehicle yourself. There's probably heaps of stuff you can do on the Paj that doesn't involve having to own super expensive equipment.
429749
Follow Up By: Robin Miller - Thursday, Sep 09, 2010 at 14:43
I was thinking just that before reading your reply Moose.
I began by just going thru the manual and ticking off service items , each time I came to one I didn't know you just work thru it , sometimes with external help.
A course like that though would be worth doing , we can always learn new tricks or just have things we have heard of confirmed.
But even a course like that is just one extra step and the bush will always throw up something new , like my clutch pushrod disconnecting and no-clutch the other week.
700536
Follow Up By: Frankie Paj - Thursday, Sep 09, 2010 at 15:40
Thanks guys. Might start off getting the workshop manual and servicing the vehicle. The savings there can pay for a course further down the track! The Haynes workshop manual seems quiet good.
Frank
700548
Reply By: bks - Thursday, Sep 09, 2010 at 17:07
4wd clubs are worth looking at, the bigger ones run courses in all types off off road 4wd related issues. The Toyota Land cruiser club (you dont have to have a Toyota to be a member) have a specific bush maintenance course.
429767
Follow Up By: Frankie Paj - Friday, Sep 10, 2010 at 12:46
Will check this option out as
well after I have learnt a little more about the vehicle.
Frank
700653
Reply By: Member - Stephen L (Clare SA) - Thursday, Sep 09, 2010 at 22:12
Hi Frank
You have good replies above, but just different, we had a 98 2.8 Pajero for 9 years and the motor will go just about for ever if serviced regularly. The only thing that I found would not last and that was the glow plugs, both genuine and after market and would usually only get about 12 - 18 months out of them before I would replace all 4. In the end I would always have a spare set of Bosch after market glow plugs on hand, which I could pick up for under $100 for the 4, compared to around $200 each for the genuine.
I used to change the oil and filter every 5000 kilometres, and the coolant every 2 years.
They were a great reliable vehicle and it never let us down, and it had been to some very remote locations.
Image Could Not Be Found
429805
Follow Up By: Frankie Paj - Friday, Sep 10, 2010 at 12:50
Great to hear some positive feedback on the Paj Stephen. A few of us took the Paj across the French Line last year and it loved it! Will keep up regular servicing and the glow plugs are a great idea. They have already been replaced once! My Dad fitted a dash switch in the vehicle though so I can turn them off once the 4WD is running. Saves them glowing for 4-5 minutes!
Frank
700654
