Waeco Fridge/Freezer Mods
Afternoon all. Although the search function doesn't answer my question, I think it was on this forum that someone contributed a Waeco portable fridge mod where a larger fan was fitted, internally, to the condenser to improve fridge performance. Can someone point me in the right direction?
Thanks.
Mark
Reply By: Lucko - Friday, Oct 01, 2010 at 13:37
Found it! Found it! As you were!
Search function didn't find it but I should have realised that Google is my friend.
Mark
AnswerID: 431900
Reply By: Allan B, Sunshine Coast, - Friday, Oct 01, 2010 at 14:08
Hi Lucko,
You seem to have found the forum thread you were seeking but just in case, I suggest thread 74817 as one that fits your description.
In that thread I described an extra fan modification to my Waeco. Two lengthy trips have confirmed that the fridge performance has improved with the modification.
AnswerID: 431902
Follow Up By: Lucko - Friday, Oct 01, 2010 at 14:18
Thanks Alan, that's the thread I was looking for. Excellent stuff!
Still struggling with the 'shroud' concept, must be oldtimers disease as I just can't visualise it. I have both the 50 and 30L fridges, very happy with them, but if they can be made more efficient, I'm all for it. You can carry just so many batteries!
Cheers, Mark
FollowupID: 702692
Follow Up By: Allan B, Sunshine Coast, - Friday, Oct 01, 2010 at 14:46
Mark, the "shroud" referred to in that thread is in the form of a baffle with the fan mounted over a hole in the baffle so as to discourage the recirculation of air from the fan outlet to its inlet. A good idea if it can be managed. Somewhat similar to the shroud associated with an engine radiator fan.
In practice I tested the airflow pattern with and without a baffle by using a small strip of thin paper to reveal the flow and did not find any recirculation using a computer fan possibly because it already has some degree of shrouding in its construction.
FollowupID: 702693
Follow Up By: Lucko - Friday, Oct 01, 2010 at 15:57
Thanks Alan, now I understand. Will go with the fan mods first and see how I go.
Mark
FollowupID: 702700
Follow Up By: Lucko - Monday, Oct 04, 2010 at 10:08
G'Day Allan,
One more question please - in the original thread, there was discussion about the thermistor (the green gizmo). When you swap out the fan, did you leave the thermistor in circuit or did you remove it? Anything else I should note?
Mark
FollowupID: 702885
Follow Up By: Allan B, Sunshine Coast, - Monday, Oct 04, 2010 at 14:05
Hi Mark,
I had another look at the original thread to see what was said about a thermistor and I can see the photo with a green device (possibly a thermistor) connected closely to the fan.
I did not observe such a device on the original fan in my fridge, a Waeco CF35. In any case, I left the original fan intact and merely added a second fan electrically connected in parallel with the wiring supplying the original fan, crossing my fingers that the driving source would handle the added load. It seems to have done so as this fridge has now run some 14 weeks since the mods, and with improved performance.
I puzzle at the merits of having a thermistor to reduce fan current when the fridge is operating at a lower environmental temperature, if in fact that is what it does. The fan consumes so little energy compared to the compressor motor that any power savings in fan current would be negligible. In fact the more fan cooling of the condenser would provide more benefit in energy consumption at any ambient temperature.
The only other thing to note is to take GREAT CARE. Any damage to either the electrics or the refrigerant components could be VERY EXPENSIVE.
FollowupID: 702895
Follow Up By: Lucko - Tuesday, Oct 05, 2010 at 12:21
Thanks Allan, I appreciate your assistance. I hear your warning.
Mark
FollowupID: 702971
