Butane Gas Heater - Am I going to Die?
Submitted: Monday, Oct 11, 2010 at 13:46
mintrax
Just bought a Gasmaster Butane Gas Heater which are currently available at Big W.
Same specs as Kovea "Little Sun" and Companion heaters and is complete with oxygen depletion switch.
I know heaps of people use these in motorhomes, caravans etc. but the manual says...."CARBON MONOXIDE
HAZARD - THIS APPLIANCE CAN PRODUCE CARBON MONOXIDE WHICH HAS NO ODOUR. USING IT IN AN ENCLOSED SPACE (FOR EXAMPLE CAR, TENT, CARAVAN, MOBILE HOME) MAY CAUSE DEATH."
Any opinions?
Michael
Reply By: Alloy c/t - Monday, Oct 11, 2010 at 13:55
Just make sure you leave a window open , recon that by the time the fabled "oxygen depletion switch" kicks in you could be permanently asleep as was the family of 4 tenting in the
Vic high country a few years back,,
432695
Reply By: TerraFirma - Monday, Oct 11, 2010 at 14:03
Arrgh, The price of keeping warm..! Nothing like a nice cold night IMO..!
432698
Reply By: Steve63 - Monday, Oct 11, 2010 at 14:05
Yep carbon monoxide is a killer. It basically attaches to the haemoglobin in the red blood cells and stops the normal co2/o2 exchange from happening. It has lasting effects until the red blood cell dies naturally. Prevention is the best solution. So make sure the area is
well ventolated.
Steve
432699
Reply By: Honky - Monday, Oct 11, 2010 at 14:26
I do use one of those in my campertrailer which has gaps galore so no problem with enclosed room.
Only uses about 3/4 of the gas cartridge.
Would not use in a caravan as totally enclosed
I only use when awake or when raiining outside.
Not sure what the difference would be in regards to gas stoves and gas heaters in a house.
My main concern if I did use it when I was asleep ( wouldn't anyway ) would be the fire
hazard as they put out about 2 KVA in heat.
Honky
432700
Reply By: Member - John and Val - Monday, Oct 11, 2010 at 15:57
Michael,
Carbon monoxide, as others have said can be lethal. It is also slightly heavier than air so make sure that you have some ventilation holes down low so that the carbon monoxide can "drain" out - especially if you are sleeping close to the ground.
Val
| J and V
- Albert Einstein
432705
Follow Up By: Member - John and Val - Monday, Oct 11, 2010 at 16:03
Oops the better half and google dispute this - so best ignore the above post!
| J and V
- Albert Einstein
703471
Follow Up By: Mick O - Tuesday, Oct 12, 2010 at 07:09
The ventilation holes are still a great idea John. Both Carbon Monoxide and dioxide are not heavier than air. The butane is though so any gas leak will pool on the floor of a camper/tent. There have been a lot of deaths in Europe and eastern block countries in bathrooms as they use an internally mounted, gas fired instantaneuos hot
water system that produces monoxide. Eclosed bathroom...carbon monoxide, sleepy time for sure.
703530
Follow Up By: Member - John and Val - Tuesday, Oct 12, 2010 at 07:51
Hi Mick,
Must disagree with just one point you make (and risk getting off topic!). CO, carbon monoxide is very close to the same density as O2, oxygen and N2 nitrogen, the major components of air. In fact the 3 elements C,N,and O are adjacent in the periodic table so have very similar mass. CO, O2 and N2 molecules each consist of 2 atoms. BUT the CO2 molecule consists of 3 atoms, so it is roughly 50% heavier than the others. Consequently it tends to fall and can even pool like a liquid in depressions. Fortunately it's non toxic.
I once had a near death experience with CO2. We were filling a huge grain shed with it to displace the air and hence control grain insects. CO2 had leaked and filled the underground area where wheat was tipped to feed the elevator. Without thinking I started to climb down to retrieve a dropped tool. It was just like climbing down into a swimming pool filled with invisible
water. Once my head went below the surface the breathing reflex, usually triggered by our own CO2 production kicked in. Fortunately I realised what was happening (CO2 plus saliva goes to carbonic acid which tastes pretty sharp!) and managed to avoid more than that one breath while taking that one step up the ladder to clear air. No long term effects, but, believe me, CO2 is heavier than air!!
| J and V
- Albert Einstein
703531
Follow Up By: Member - John R (cQld) - Tuesday, Oct 12, 2010 at 10:15
Hi John, still not quite right, more than 5% CO2 in air can be lethal even if there is oxygen available. But you're certainly right about CO2 being heavier than air, as what you describe in the grain silo can happen naturally in
limestone caves if there is no air circulation.
Normally in rooms, etc there is enough stirring of the air to get the gasses to mix up, but if conditions are very quiet then a gas leak can pool.
And if you had a gas heater going in an enclosed space, you'd probably find it would start "raining" in the morning, from condensed
water vapour!
Cheers, John
703549
Follow Up By: Mick O - Tuesday, Oct 12, 2010 at 18:13
Thanks John and John,
great answers. Carbonic acid as an indicator is a worthwhile tip.
Cheers Mick
703568
Reply By: Jeffie - Monday, Oct 11, 2010 at 16:43
We have a "Little Sun" and use it in our caravan, but only when necessary.
We have it by the doorway where there is a permanent ventilation vent and with the 4 seasons hatches open, and only use it until we get into bed.
Have been using it for last 3 years - until we escape from the cold - usually for the first 3 days from home and same coming back ( to Vic).
(We freecamp most of the time)
You should get 2 hours heating per cylinder and make sure you buy them at K Mart or Bunnings at about $5.00 or else you could pay $10.00 to $12.00 for pack of 4 elsewhere.
Jeff,
432709
Reply By: rosie bell - Monday, Oct 11, 2010 at 23:46
This post has been read by the moderation team and has been moderated due to a breach of The Inappropriate Rule
Forum Moderation Team
432762
