pajero vs outlander?
Submitted: Sunday, Oct 17, 2010 at 23:33
3cooperplace
We want to drive around Australia, will be mostly on bitumen but would like the option of hitting the dirt. I don't see myself as a hard-core offroader, but if I went down onto
the beach, I would get bogged in a 2WD.
Am I correct in thinking that something like Outlander, which has clearance within 10mm of Pajero, and AWD if you need traction, will be fine? The 2.4 CVT is going to be a lot lighter on
fuel than a full size 4WD, and it's a LOT cheaper to buy new or near-new. Besides, they seem nice to drive (altho' so is a Paj).
Thoughts, anyone? All advice appreciated.
Reply By: dereki - Monday, Oct 18, 2010 at 00:12
My 2c worth...
Quoted clearance is just 1 measurement of the lowest point. It doesn't give any indication of how high the bottom of the doors are (
water crossings), or ramp over or approach/departure angles. The other thing is that it does not give an indication of what is low... something solid or something that might get damaged.
Eg. a low measurement is usually on a 4wd something like a diff, which is between the
wheels so less important than something dangling down in the middle of the car which might belly out. On other cars the low point is more uniform.
I am not familliar with the car models in question so you will have to go have a look under them to make a judgment. From my experience with a RAV and a Prado.
1. Rav had a lot of vunerable items low down... sump, exhaust, oil filter. Damage to these things could stop you. Prado has all of this stuff high up with tougher components like axles/diffs down low.
2. Rav.. plastic under body protection. Prado steel.
3. Rav. Not designed to wade in any depth of
water (eg air intake down low and at the front of the car). Prado has obvious design to help waging depth. (eg extended front diff breather from factory, electronics high up in the cabin)
4. Rav. Nothing solid to bolt a bull bar to. Prado proper chassis.
So. I am a saftey nut, so I like things to be designed to cope with the edge cases, so I went for a 4wd. Heaps of people will do it in all sorts of cars, motorbikes etc. without any trouble.
For me,
Fuel is more about range than consumption. What is the touring range of a fully laden outlander, compared with a fully laden Pajero?
2.4 in my Rav used more
fuel than the turbo diesel prado does. Rav 50lt
tank. Prado 180Lt
tank...
D
433420
Reply By: steved58 - Monday, Oct 18, 2010 at 13:26
I drive a NL pajero have had it for 8 years mainly drive on bitumen however on the odd occasion I have taken it off-road it looked ok a couple of times but soon turned nasty the pajero had no trouble on these unexpected conditions I have my doubts that the outlander would have done the same
I believe that it is better to have more ability than less but hey each have their opinion on the risks they take on beach etc
all the best Steve
433454
Reply By: landed eagle - Monday, Oct 18, 2010 at 13:52
If you're looking at buying new, why not split the difference and have a look at the new Mitsi Challenger?
Basically he same as a Triton underneath but coils in the rear susp instead of leaf springs.
I've used an ML Triton to tow my van for approx 16,000kms so far and hasn't missed a beat.Had the challenger been available when I bought the Triton I probably would have gone that way instead.
433457
Follow Up By: 3cooperplace - Tuesday, Oct 19, 2010 at 18:39
I drove a new Challenger and found the diesel clatter v obtrusive & unpleasant whereas the Pajero is fine. So no Challenger for me.
704501
Reply By: Member - Graeme M (VIC) - Monday, Oct 18, 2010 at 20:51
I have a 2008 Pajero and during the short time we have had the vehicle it has performed extremely
well in all types of terrain. We tow a 2 tonne van and have experienced all road conditions and the Paj has come through each time. I have confidence to tackle any road surface knowing my chances of getting through are good.
The vehicle is important of course but good tyres and adjusting of pressures to meet road conditions can also make a considerable difference as does a good four wheel drive course before you take off (assuming you have no experience)
You are going to see a range of surfaces as you travel our great country.
My daughter has an Overlander and it is also a good vehicle for hard roads and city travel. In my opinion there is no comparison betweeen the two vehicles for your application. Some time, some where as you travel around Oz you will need the grunt and flexibilty the Paj offers with true low range.
The Challenger may also be a solution but I dont have any experience with this model and it seems to me that price wise you may be able to get a good used Paj for similar dollars.
I sound like a salesman for Mitsubishi but my experience is all good.
Hope this helps
433490
Follow Up By: 3cooperplace - Tuesday, Oct 19, 2010 at 18:53
thank you yes it does help; I'm tending towards the Pajero.
704507
