Fridge box vents
Submitted: Thursday, Oct 21, 2010 at 17:59
ThreadID: 82049 Views:7517 Replies:5 FollowUps:3
I wish to build a box to enclose my Waeco fridge in . My major concern is the ventilation for the fridge. I am also keeping in mind the rain getting in through the vent holes. The box will be mounted on the tray of my ute.
I have not started to build the box yet so looking for design ideas. The box will have side opening door with fridge slide.
Please help Brian.
Reply By: Joe n Mel - Thursday, Oct 21, 2010 at 20:16
intersting you have brought this up, i have been looking at various set-ups of cars with fridges and some of them blow me away, i have lived "out bush" for some time and used to seeing the good old Engle just floating around in the back of the ute, out in the full rain and sun and lasting for YEARS ....
Now i see people building boxes, slides, covers and so on that MUST cost nearly 4 times the value of the fridge and MOST seem to have it contained in a sealed box so how ever it works i dont know, up north in the full sun i just simply can not see how it would get rid of the heat build up from the condensor and still work, yes a cover over the fridge is a very good idea (Fridge bag) but to seal it in is with no airflow is going to make that fridge work way beyond what it can possibly do ... shade will improve it, slides are not a bad idea but getting costly, so how you build one that cover all requirements ????
I am still yet to see one and trust me i have looked at heaps in the last few months ...
With that i mand i also am waiting for some replys :-)
AnswerID: 433799
Reply By: Gossy - Friday, Oct 22, 2010 at 08:54
http://www.fairlite.com.au/qubelok.html
try this also
inserting a link doesn't seem to be working. This stuff you can buy from hardware stores and is brilliant for this type of work.
AnswerID: 433857
Follow Up By: Gossy - Friday, Oct 22, 2010 at 14:04
forgot to mention there is 2 types. One which just builds the blocks together. the other one looks exactly the same but all poles have the ability to slide wood into the grooves. Basically build a box in minutes :)
FollowupID: 704890
Reply By: Member - RobnJane(VIC) - Friday, Oct 22, 2010 at 13:07
Hi Brian,
If I was doing this I would ensure ventilation holes included a filter to ensure only filtered air gets into fridge box. I think you need two ventilation points. (Air in & air out?)
Any exposed surface should be insulated to give the fridge half a chance at being efficient.
Door design needs to ensure it can open without obstruction and when open not interfere with access to the fridge, to me that means opening way beyond 90 degrees.
Hope this is of interest.
Rgds
Rob.
RobnJane
AnswerID: 433889
Reply By: Member - mazcan - Friday, Oct 22, 2010 at 14:37
hi brian p
i know there isan offrd one here in wa somewhere that has a turbo snorkel and aircleaner element for intake and then an exit vent and was told it works well
did see some photos and it looked impressive but it was on an off rd trailer that already had a front drawbar box as part of the trailer equipmt
i built one for my on rd trailer
the 40ltr engel is held down onto the base a/frame board by a slidelock plate
then i built a 3 sided 9ml thick marine plywood and aluminuim angles and flat bar for the frame work with only the lid having welded corners for a box around it that is bolted down to the a/frame base board with a hinged lid with
gas truts
and a hinged locked down mesh security screen at the rear
i put 2 5/8 copper pipe breathers/drain holes in the floor at the front
i have made it so i can just get the fridge up and out through the top of the box after releasing the slide lock there is a 25ml air space on all sides of the fridge bag this was limited by the aframe size but is adequate i believe.
it has traveled through some very heavy rain for 3 hrs on it's inaugural trip and the fridge and electrics remained dry
also did a trip bunbury to esperance in 38degree heat and the fridge kept cool the fridge is inside the engel bag as well inside the box and the box is treated with a special heat resistant paint that i bought after seeing it
demo 'd at a caravan show in perth
i have travelled on quiet a bit of dusty road and only a very light film of dust got in which i admit is different to the 4wd scenario
the design of it uses the slip stream to draw the dust past the box
the box has some vents either side at the rear external to help with slip stream effect
i thought about it for a long time then just went ahead and built it for on rd use
i'm very happy with it considering it was just something that was designed in the my top cavity
i have also mounted a small solar panel on the top of the lid together with a solar driven fan that draws air up through the box while stationary at a camp site
and have my twin charger and solar controller in under the box lid out of the weather and harms way the lid is locked down with security key locked latches
i also mounted my camper battery power control box on the rear side of it incorporating amp and volt meter and switches/and fuses
i have also added a small led strip light with a a pressure switch that come on as i lift the lid and shines down into the fridge
i might add that it would probably get a dam site more dust into it if the same design was put to use behind a big 4wd traveling slower and stirring up the dus ton outback tracks as i know they do from personel experience
but it could have a solar and/or 12v driven fan mounted in the front of the box and a more substantial air intake system but the box would have to be longer to incorporate this
sorry no photo's
AnswerID: 433895
Follow Up By: Member - Brian P (SA) - Saturday, Oct 23, 2010 at 07:12
Hi mazcan. How big a solar fan did you use? Brian
FollowupID: 704961
Follow Up By: Member - mazcan - Saturday, Oct 23, 2010 at 16:12
hi brian p
the one i used is this one look up
www.solarmade.com
and then click on solar vent
it shows pictures and gives specs and prices
i bought mine from a caravan show in w.a
think it was either from george days maddington and/ or cara spares in welshpool
but you could get it online direct from the above site and cut out the middle man
mine is the plastic one and it shifts a fair bit of air in bright sunlight and stands up to the onrd travel and has done some corregated gravel on southern beach rds in w.a and has never failed or fell to bits
but dont know how long it would last on severe csr type tracks
when i dont want it running on cold winter days its just a matter of covering it to stop it
FollowupID: 704996
Reply By: Member - Brian P (SA) - Monday, Oct 25, 2010 at 07:48
Thanks everyone for your input. All your ideas will help. Brian
AnswerID: 434125
