Aftermarket cruise control
Submitted: Monday, Oct 25, 2010 at 09:51
wortgames
Another speeding fine this weekend. Now that I'm driving interstate every couple of weeks I need to protect what few points I have left and cruise control is looking like less of a luxury.
I don't know
where to start, obviously there are plenty of hits on Google and eBay but can anyone recommend anything specific?
I plan to fit it myself into a 1987 Range Rover.
Reply By: Robin Miller - Monday, Oct 25, 2010 at 09:59
Many have fitted the AP50 diy kit from Autron , usually around $200
There are a few versions (models) like Ap60 AP150 etc - all available ebay.
I don't like cruise for avoiding fines though - they can still let you overspeed going over top of
hill - which is often where there is someone waiting ahead.
Best thing is a good GPS with accurate big speedo and ability to program your own proximity zones for hot spots - I use a now discontinued garmin 276c , has been worth its weight in gold.
434139
Follow Up By: Simon C - Monday, Oct 25, 2010 at 11:06
Agree Robin....My 100 series will acelerate that hard on an up
hill road so much that it will actual go over the set speed limit beofre it backs off. Great on straight level streaches of road, but in hilly areas.....will not stop the speeding fines. Also on long down hills....it won't stop you going over the limit. GPS with a speed alarm would be worth the money as
705182
Reply By: garrycol - Monday, Oct 25, 2010 at 10:21
I put an AP50 system into an early Discovery (similar to your RR) - worked
Was at the time about $220 from K mart.
Garry
434144
Reply By: Member - Andrew C (WA) - Monday, Oct 25, 2010 at 12:25
Hi Robin,
I have cruise control fitted to my Ute and don't use it anymore found that it uses a considerable amount more
fuel than when I drive.
I have fitted a hillspeed head-up display. easy to install just needs 12 or 24 volt power, supplied with a lead for hard wire and also a cigarette lighter plug,
The unit operates via GPS which means it take out any variables like tyre size etc sits on the dash has a large L,E,D display which make it easy to keep an eye on your speed basically you don't have to take your eye of the road you can see the display in your peripheral vision. has 3 different alarms audible visual or both easy to set with the press of a remote button. can be swapped to another vehicle in just seconds.
mine is velcro to the dash mat centre of the steering wheel.
Image Could Not Be Found
434155
Follow Up By: Mike DiD - Sunday, Oct 31, 2010 at 18:09
GPS is very accurate at steady speed travelling straight, but if you're accelerating, it will still say you're under the limit when you've gone over it.
705801
Reply By: dbish - Monday, Oct 25, 2010 at 13:41
Another option Ive used is a VDO speed alert just program the speed you want & it beeps when exceeded. Ive found cruise control in my vehicle is good on reasonably level going but in hills uses more
fuel & will sometimes exceed set speed on downhill runs in an automatic. Daryl
434158
Reply By: Honky - Monday, Oct 25, 2010 at 13:45
Cruise control is not just for
fuel savings.
If you are doing long trips it reduces fatigue as you can move your feet around.
there may be a few hills but most of your travels will be flat roads where you WILL get reduced
fuel usage as you will not be slowing down or overspeeding.
I have never been booked with the cruisr set.
Just be carefull on hills.
Sorry cannot recommend a setup as standard in all my cars
Honky
434159
Reply By: Member - Boo Boo (NSW) - Monday, Oct 25, 2010 at 15:24
I've got an auscruise in my troopy.
It cost $700 fitted and it's great.
The wife and I travel a fair bit and it does reduce fatigue.
I rarely use it in hilly country as I prefer to have control of the accelerator while driving up and down and around curves.
In 3 weeks we head back to
Scone NSW from Bunbury WA and cruise control is great for a trip like that.
434167
Reply By: Member - Ian F (WA) - Monday, Oct 25, 2010 at 18:26
G'day,
I am all for cruise controls as I had them on my two previous vehicles, unfortunately not now. The only problem if you are tired, which you should not be driving anyway, definitely do not use. A lot of people do drive tired and I have been guilty of this myself but not over the past few years.
Ian
434184
Follow Up By: Member - Ian F (WA) - Monday, Oct 25, 2010 at 18:35
I forgot to say that my two other cars were automatics and latest is a manual.
Has anyone had experience with cruise controls on manuals.
Ian
705238
Follow Up By: Member - Paul F (INT) - Monday, Oct 25, 2010 at 20:19
I have an auscruise fitted to my hdj 79 manual and have found it to be a valuable asset in the following ways.
I set it to required limit I am comfy with and it stay's there on flat or slightly undulating roads.
I REFUSE to use it in any metro areas ( including freeway or major thoroughfare ).
Reason for this is traffic can never be ' predictable ' in this situation.
I actually DO save on both fuel and time when travelling on long distance, because I am not constantly up/down on the right foot to maintain my desired speed.
Paul
705257
Follow Up By: Robin Miller - Monday, Oct 25, 2010 at 20:31
My 4800 Patrol has cruise control and is a manual Ian - it works a little better than the cruise control on my other 4800 an automatic.
Probably because the manual has a little more power thru the gearbox, and retardation on overspeed is brought under control quicker.
705259
Reply By: Gramps - Monday, Oct 25, 2010 at 18:37
In my experience, all cruise control systems, factory or aftermarket, advise against their use in hilly or winding terrain. Has this proviso been removed ?
434185
Reply By: MobiCondo - Monday, Oct 25, 2010 at 22:25
We have found that our GPS has an option of speed alert - so good old GPS is set at Zero Speed tolerance and we get "Girt" or "Willie" telling us that "You are over the limit" the instant we go over what ever the local limit is (if it is catered fr in the system that is)
Mobi
434214
Reply By: wortgames - Wednesday, Oct 27, 2010 at 19:22
Thanks everyone. I'm wary of generic eBay electronics but I'll suss out Autron and Auscruise.
I've been using my iPhone as a satnav and I know many will knock it, but I've found it fantastic. I need to pay for a better app to get the speed alerts but it sounds like that would be worth doing.
434378
