Polishing aluminium.
Submitted: Saturday, Oct 30, 2010 at 16:38
ThreadID: 82205 Views:4086 Replies:5 FollowUps:2
During the week Wilko asked about dulling aluminium, I want to go the other way. The chequer plate on my off road van is looking pretty sad with streaks and general dulling, what is an easy way of polishing it ? I say easy as this is an 18' van with chequer plate 3' high on all sides.
Rob.
Reply By: Hairy (WA) - Saturday, Oct 30, 2010 at 16:59
Gday,
Try some autosol or something similar on a buffing pad (7 inch polisher).....otherwise, take it to a polisher.
Polisher
AnswerID: 434623
Reply By: Alloy c/t - Saturday, Oct 30, 2010 at 17:32
CT18 truckwash ,let soak for awhile then hit with the gerni / karcher , comes up a treat.
AnswerID: 434625
Reply By: Member - Stephen L (Clare SA) - Saturday, Oct 30, 2010 at 18:24
Hi Rob
Chemtech make products for many applications and for aluminium here are a couple of their quality products
Blitz and Alushine. For full details, here is a link to the page:
http://www.chemtech.net.au/page16.html?site_search_results_2=blitz&depth=0
Cheers and happy cleaning.
AnswerID: 434627
Reply By: Member - Carl- Saturday, Oct 30, 2010 at 18:40
Rob,
I posted a thread a few weeks ago asking the very same thing. So I am now the offical guru on polishing checkerplate. After 12 months around Australia, like you the van was looking a little worse for wear.
There are currently 3 types of checkerplate on caravans so my treatment is only for my type. I am of course not certain, what type of van your have? Pic my checkerplate below.
I tried everyone's suggestion and autosol was the clear winner. The most expensive as well but value for money. The other ingredient was the Mk 1 finger and hard work.
In the end I got my orbital sander and smoothed off the rough edges of the checkerplate. Used wet and dry 400, I found was the best. It did some scratching but this came off with just 2 polishings. From then on in the checkerplate is much smoother and easier to polish.
I tried a 7inch sander polisher and then a 100mm cloth buffer (normally used on bench grinder /buffer) on and angle grinder but the old finger worked the best.
Tried washing first with Al cleaner but this really at the end of the day, made little difference to the polishing effect. In polishes I also tried Septone and Purple.
Not finished yet as it is a really really big job. It is really a work in progress. Good luck.
Image Could Not Be Found
AnswerID: 434630
Follow Up By: racinrob - Saturday, Oct 30, 2010 at 19:03
Thanks Carl for your comeback. Your chequer plate is known a "propellor plate", mine is another type with five bars in an opposing pattern but at the end of the day I suppose it is all aluminium plate.
You certainly went to a lot of effort, I was looking for the easy option but realise I will probably have to use a bit of elbow grease.
Rob.
FollowupID: 705715
Follow Up By: Member - Carl- Sunday, Oct 31, 2010 at 08:31
Thanks for that info, I was wondering what it was called.
I had that type on the old caravan and found it a bit harder to polish. So not good on info on that one.
There is certainly a market for a easy to use polish. Something that repels sandflies and a way of giving politicans intelligence and honesty. Cannot have everything. Good luck. I am going to have a look at the Chemtec product as I had not heard about that one.
FollowupID: 705747
Reply By: silver bravo - Sunday, Oct 31, 2010 at 22:49
Just food for thought....
I use a scotchbrite lathered up thick with Velvet brand soap, and rub in light circles all over aluminium...always comes up awesome!
AnswerID: 434729
