Sand Flag Height
Submitted: Thursday, Nov 04, 2010 at 09:48
CraigFox
On a recent trip into the dunes of
Beachport etc, I could not help but notice the different heights (and lack of) sand flags.
We have our EO flag mounted onto the flat of the ARB Bull Bar, which would put it
well over 3.5 metres from ground level to the top of the flag. Is this too high? Some people had a token flag onto their 1.2m UHF aerial, I even saw one flag on a 12" rubber ducky aerial off the roof rack! Majority did not have any flag, whilst some had flag on about 2m pole.
How high should the flag be? Low enough to miss trees etc, but high enough to be seen approaching the crest of the dune/or through/over the top of the scrub?
Craig
Reply By: Member - Mark G Gulmarrad - Thursday, Nov 04, 2010 at 10:25
Craig
i think that a little heigher than a little bit low is better.after all,the reason why you have one is so is that other vehicles can see you approaching
well b4 they see your vehicle.
435044
Follow Up By: CraigFox - Thursday, Nov 04, 2010 at 10:46
That was my thoughts exactly! We had a few close calls with oncoming vehicles with a flag lower than roof height or no flag at all.
706154
Reply By: Member - Duncs - Thursday, Nov 04, 2010 at 16:14
I mounted a flag on the bull bar for the
Googs Track trip. It seemed high enough to me at about 3m but I did not meet any oncoming traffic.
The biggest problem I had was with overhanging trees. My flag got caught up and ripped to pieces in just a few short k's where there were a lot of overhanging branches. It was mounted on the left because the way I did it that was easier. Next time I will mount it on the right hand side of the car to minimise such contact.
The other thing I thought was that it would be better mounted leaning forward so that it was in front of the car. When climbing a dune the flag is actually behind the car if mounted vertically I question how much warning it actually gives. I accept it is better than none but probably not much.
Duncs
435064
Reply By: Member - Bucky - Thursday, Nov 04, 2010 at 17:57
Craig
Look at what I used for the
Canning Stock Route
............................... A squid pole ($25)
................................A "Bra".. purchased from St Vinnies
................................Very strange stares female staff are free
................................trying to explain yourself is priceless
I have a thoery......... 95%+ drivers in
the desert are male
...............................We can spot a "Bra" at 500 mts, with no effort at all
...............................For a male, it's better than a
beacon
...............................SAFETY plus achieved
Image Could Not Be Found
and of course you need this configuration
Problem solved
Bucky
435072
Follow Up By: Member - Mark G Gulmarrad - Thursday, Nov 04, 2010 at 18:31
Bucky
straight out of your cross dressing draw are they??
LMAO.
706193
Reply By: Member - Stephen L (Clare SA) - Thursday, Nov 04, 2010 at 19:10
Hi Craig
I am not sure if there is a set ruling, but from a safety angle, some reports of at least 3m from the ground or higher is recommended. The higher the distance from the ground, the easier on coming vehicles will see you approaching from the other side of a dune. A flag mounted on the 1.2m aerial will offer no or very little safety, as the vehicle will be on top of a dune before the flag will be see = no warning to the other vehicle and a head on collision. I see you also use an EO flag, which are great, as their
bright safety
orange make them easy to see from quite some distance, which is what you want to happen, to be seen.
435080
Reply By: Big_Fisho - Thursday, Nov 04, 2010 at 19:42
well the usual height ive seen them is around 3.5m and they are telescopic...in regards to tree's etc you could mount a spring base on it so it folds over like a UHF aerial OR if you wanna be a bogan like me have 12ft uhf aerials on ya ute and mount it on the top of that lol
435083
Reply By: aussiedingo. (River Rina) - Friday, Nov 05, 2010 at 20:12
G'day, it can't be too high! - it can only be too low! regards,
435145
Reply By: Flynnie - Friday, Nov 05, 2010 at 22:01
I heard that it should be a minimum of 3 metres from the ground to comply with C.A.M.S. (mining not auto) standards. I have not been able to confirm this.
My Black Widow sand flag reportedly complies.
I go full height unless there are too many hits on trees and then I take out one section. It would still be over 3 metres.
Flynnie
435158
Reply By: Crackles - Friday, Nov 05, 2010 at 22:13
While a min of 4m is the accepted height for some dune buggy clubs, this is far too tall for many of the coastal tracks covered in low scrub & generally ends in the thing being ripped off. The ideal position is central on the bull bar & 3m off the ground would be sufficient. If playing in the Millicent buggy
park on some of the large dunes then add another length.
Cheers Craig...............
435159
