Landcruiser Broken Wheel Studs
Submitted: Thursday, Nov 04, 2010 at 14:56
Member Dick (Int)
Question for Mick O
Mick, did you find out why your wheel studs broke? Have you found a solution for the problem.
Dick
Reply By: Member - Jack - Thursday, Nov 04, 2010 at 20:27
Hi Dick:
I won't steal Mick O's thunder apart from saying that Landcruiser wheel studs are notorious for breaking. I have an 80 series, and have broken 4 to date by simply tightening them up with a wheel brace. That is why most 80 series owners discourage garages using rattle guns to tighten up their wheel nuts.
There are a few on this
forum who use tension wrenches to do up their wheel nuts.
Jack
435085
Follow Up By: Member - Phil G (SA) - Thursday, Nov 04, 2010 at 22:28
Yep, the 6 stud Landcruisers were notorious, but with the 5 stud it is a rarety.
Mick's were 5 stud - the studs are bigger (14mm instaed of 12mm) so are stronger and have a higher clamping pressure when correctly torqued.
One thing I've noticed is that the factory Toyota
wheels are a firm fit where the centre hole slides onto the hub, so there's very little movement when nuts are loose. The aftermarket
wheels have a centre hole thats about 2mm bigger and if nuts work loose, theres some play between wheel and hub.
706224
Follow Up By: Member - Johny boy (NSW) - Friday, Nov 05, 2010 at 09:14
I have broken one on 7 yrs on my 100 ser with factory alloys and I went down to Don Kyatts and bout some spare stud and nuts which I leave in the tool kit of the 4B
Cheers john.
706254
Follow Up By: ob - Friday, Nov 05, 2010 at 13:29
Having owned various FJ 40's, FJ 55's, HJ and FJ 45's, FJ 73 and HZJ75 all with 6 stud pattern and heaps of overloaded trips such as CSR, GRR a few of Mr Beadell's "highways" and never having broken a wheel stud my advice is when you need new tyres remove your
wheels at home, take them to the tyre joint of your choice for fitting and balancing, then re-fit at home without a rattle gun. If you know how to tighten by "feel" fine, if you don't, use a torque wrench.
Then re-torque after a short run.
ob
706272
Follow Up By: Richard W (NSW) - Friday, Nov 05, 2010 at 19:50
Phil,
Must be a rarity as I have done two studs on one front wheel and one in the rear. All replaced under warranty. Now carry a few spares. ;)
706289
Follow Up By: Member - Phil G (SA) - Friday, Nov 05, 2010 at 23:27
Well there ya go........
I guess that makes it almost a rarety :-))
706313
Follow Up By: ob - Saturday, Nov 06, 2010 at 12:41
Not proposing that it doesn't happen, just what I have done and the end result.
IMVHO the other possible contributing factor is much larger tyres and rims than standard.
ob
706341
Reply By: Member - Graham H (QLD) - Saturday, Nov 06, 2010 at 09:20
A tongue in cheek comment but wouldnt overloading contribute towards this.
Some of the loads I have seen on some vehicles its a wonder some dont just expire on the ground.
Not suggesting its anyone here but must be a factor to be considered.
435178
