Which Swag style
Submitted: Monday, Nov 29, 2010 at 06:49
ThreadID: 82749 Views:9731 Replies:8 FollowUps:14
I am looking to get a swag and didn't want to hijack the recent thread.
My question relates to the pro's and con's of a simple fold over traditional design verses a dome design.
As I see it the dome style has the advantage of keeping the swag high off you but it seems the downside is unzipping and getting in and out. Is this right for an old codger? I imagine having to reach above my head to zip, get in and out
Is the traditional style easier to get in and out of? Do they provide adequite protection for use in the high country?
I am leaning to a traditional style for these reasons. Have I got the worng idea?
Any info on these 2 styles wold be great.
Reply By: Robin Miller - Monday, Nov 29, 2010 at 07:49
We spent weekend at Sheepyard flat near Mansfield and about 3pm it started to rain and it did not stop , even a little bit, till 7am next day.
Some tenters ended up sleeping on water beds etc
I'm in no doubt that the high dome combined with a strong PVC base which comes up the sides a little such that in can sit in water is mandatory.
One person without a dome , but had a tarp cover , kept most water off but internal humidity cused him to get almost as wet.
AnswerID: 437228
Reply By: Richard W (NSW) - Monday, Nov 29, 2010 at 08:09
Boobook,
This is may setup which I have used for many years and works well for me.
I previously had the old stile swag but got sick of insects and other nasty's crawling in. On the stretcher it's easy to sit down and roll in, even after a few reds. ;)
Early morning @ North Pool on the CSR:
AnswerID: 437229
Follow Up By: Member - Captain (WA) - Monday, Nov 29, 2010 at 08:17
What a classic photo, luv it. And I reckon your setup is about as good as it gets, well done :)
Captain
FollowupID: 708666
Follow Up By: Richard W (NSW) - Monday, Nov 29, 2010 at 10:51
Thanks Captain.
FollowupID: 708684
Follow Up By: Wilko - Monday, Nov 29, 2010 at 11:45
2nd the swag on top of the stretcher Is the best way to camp.
Cheers Wilko
FollowupID: 708696
Follow Up By: ben_gv3 - Monday, Nov 29, 2010 at 12:13
Absolutely love the photo.
FollowupID: 708698
Follow Up By: Diesel 'n Dust - Tuesday, Nov 30, 2010 at 01:23
Brilliant photo!!
One reason why I HAVE to travel the CSR.
On the swag issue - it's personal choice
Matthew Clements
I just love the Pilbara!
1HDJ79 RV
FollowupID: 708829
Reply By: Andrew & Jen - Monday, Nov 29, 2010 at 09:19
Hullo Boobook
You might like to have a look at www.mrswagman.com - he makes a swag that combines the 2 concepts and is flexible wrt setup - can use it flat or with a ridge.
Have one myself (Classic). 210cm x 80cm; 60cm high at head, 36cm at foot with insect mesh both ends.
No affiliation.
Andrew
AnswerID: 437235
Follow Up By: AGNI4x4 - Monday, Nov 29, 2010 at 22:21
Yep I like his products BUT how do you get a call back ? I rang and left a message and no reply back ? It's been about 5 days sadly.
FollowupID: 708799
Follow Up By: Andrew & Jen - Tuesday, Nov 30, 2010 at 14:07
You might have better luck with his email - Mark@MrSwagman.com.au
FollowupID: 708878
Reply By: Member - edwin (QLD) - Monday, Nov 29, 2010 at 10:45
after spending many years in a swag as a tour guide,i found the best and quickest simple setup
- a traditional type swag that has a tarp and a mozzie/midgee net rolled up with it (net fits an old sleeping bag cover)
this way you get the best of all worlds, a tarp to put your swag on that can also fold over you if it unexpectedly rains
-if it is already raining ,can set it up as a cover
-the mozzie net i have an occy strap attached to the top that you can hook to the bullbar mirror, window or tree what ever you can find, then just tuck it in around you under the edges of the swag,..if you dont like the creepy crawlees this work perfect , i only use this when there are mozzies or midgees around,but it may help you feel at ease if your not used to a swag
-best to get a queen size hoop style net,gives you tons of room and the net doesnt touch you(about $25-$30)also good to get some chemspray home pest control concentrate(BIG W )permethrin about $10,soak the net in this stuff and let it dry out,bugs then dont want to to come near the net,it is 100% safe and non toxic if used as per directions,we learnt and used this in africa to keep the malaria mozzies away,works a treat and still use it today
this setup takes about 1 minute to do ,youll have finished a few beers off by the time your friends are set up
-i took my father and father in law on a desert trip ,both 78 years old and they used and loved this set up ,they hate setting up and breaking camp as much as me ,they now reckon if your going to have a dome style swag you may as well have a tent because they take as long to set up
i know all dome swag lovers will strongly disagree with these views,but each to their own ,i spend about 8 months of the year in a swag and i love it
AnswerID: 437242
Follow Up By: Member - edwin (QLD) - Monday, Nov 29, 2010 at 10:52
ive used this set up in the high country and desert winters to -7 C, where you wake up and your swag is white with ice, as log as you have a good sleeping bag, ,i use a single fitted sheet on the mattress and a good quality down doona in the swag and it is very warm and cozy,the mattress insulates from the cold very well ,as long as its a high density foam which most good quality swags use
FollowupID: 708685
Follow Up By: get outmore - Monday, Nov 29, 2010 at 23:52
disagree setting up a dome swag takes as long as a tent
Ive done both and its not even close
I used to have to set up the geos tent then set up my swag
admitadly i had the tent dowwn to a fine art so that didnt take all that long either but the dome swag doesnt take more than a minute, alot of the poles can be left in place and just rolled up
only thing ive done with mine was replace the mattress with a thick self inflating one. makes a big swag - bit its just me so plenty of room
FollowupID: 708814
Reply By: Flynnie - Monday, Nov 29, 2010 at 20:00
Boobook
In the other thread I mention I have a Saul Swag traditional type. I did not mention that I also got the optional insect screen that I find handy, mainly in warmer areas.
I used my swag at minus 9.3 once with a sleeping bag and it was good. With blankets only, it is a bit cool below minus 5. It has been used many times at around minus 5 to minus 7. It is a bit intimidating when it has frost on it before you get in it. :)
I found no problem with "keeping the swag high off you". One of the advantages of the traditional type is you have a lot of flexibility with how the canvas is arranged and this makes it suitable for a lot of temperatures and rain or no rain. The canvas can be domed into self supporting shapes. Very versatile. Several times I have been in the tent during heavy downpours and many times in drizzling rain. No problem! It is a bit tricky if it is raining heavily when you are trying to get in it. Of course a tarp or bit of shelter will fix that.
Mostly I use the swag straight on the ground. Sometimes put a tarp under it. Sometimes use it on the tray of the cruiser. I would not bother with a camp stretcher but that is just me.
On something as personal as choice of a swag I think you have to make your own call and be prepared to try again if you are not happy with the first choice. It took me about six weeks solid to learn enough about the swag to get the best out of it. A bushie mate of mine goes for a dome or mini tent type. I come more from an urban background and prefer the traditional. Personal choice!
Nothing like being in the swag looking up at the stars on a dark desert night.
Flynnie
AnswerID: 437316
Reply By: Bazooka - Monday, Nov 29, 2010 at 20:45
Dome style I think is a little more versatile, plus keeps out the crawlies better. Camped by the sthn Darling last year in a 'standard' flold-over swag and had ants crawling over me during the night. Didn't bite thank heavens but annoying enough to wake me up a few times.
AnswerID: 437327
Follow Up By: get outmore - Monday, Nov 29, 2010 at 23:56
many a time ive woken up to see ants crawling all over the mesh of my dome swag
also a guick view around the campsite at night will show the eyes of 000s of wolf spiders.
Im not afraid of spiders and there not dangerous but they do keep you awake at night crawling over you if you have an open swag
FollowupID: 708817
Follow Up By: Bazooka - Tuesday, Nov 30, 2010 at 00:56
There have been many (mythical) statements about the number of spiders we all swallow during sleep. Scary thought if you are already arachnophobic. Wolf spiders can/will bite but you'd be very unlucky I suspect. Love looking into their big eyes - from a distance. Picture and story in the Australia's Dangerous Creatures book (great gift for o'seas visitors :-)) is food for thought though. Shows ulceration from a spider bite - very possibly from a Wolf spider (not confirmable though, so they may have got a bad rap there).
Here's my Wolf spider story: When I was a kid playing 'wars' in the scrub with some mates I laid down in some lush green grass. Felt the grass gently touching my face, or so I thought, as I waited to ambush my mates. Trouble was ,when I sat up the feeling was still there. Alarm bells rang in the brain, shivers were sent down the spine, and I shook off a giant Wolf spider. Took off outa there like a scalded cat (so did he/she probably). Boy was the adrenalin pumping.
Back on topic - Dome sags are a cinch to set up and only marginally slower to get in and out of in my experience. Mine only has loops at the ends and could probably do with a few more inches of height at the hip (plenty of width, which I like). Buy them on special and you will save $100 (good ones are anywhere from $250-$400 and worth every penny. Same goes for sleeping bags - one bad sleep from cold/discomfort will quickly confirm whether you've made the right choice).
FollowupID: 708825
Follow Up By: get outmore - Tuesday, Nov 30, 2010 at 01:24
these wolf spiders I speak of are quite small. typically the size of a big fingernail including legs as the biggest ones and go right down to small,
When i use a head torch to look around their eyes shine back like a sea of crushed glass,
Pretty sure i dont consume them in my sleep but they will crawl all over you as they hunt around for insects or whatever they eat
FollowupID: 708830
Follow Up By: Bazooka - Tuesday, Nov 30, 2010 at 01:32
Right, I'm only familiar with the giant chappies which can move like the wind - especially when they inadvertantly lob in the house somehow!
FollowupID: 708831
Reply By: AGNI4x4 - Monday, Nov 29, 2010 at 23:10
On the swags subject which is better and why ? The canvas floor or pvc type ? Thanks
AnswerID: 437343
Follow Up By: Bazooka - Tuesday, Nov 30, 2010 at 01:18
Canvas probably breathes better (so less condensation underneath) and possibly a little more durable but vinyl is lighter (?), marginally more water proof, and easier to clean. Plenty of the top quality canvas touring tents which have heavy wear and last for decades use vinyl floors. Purely personal preference but there's a bigger range of swags with vinyl floors.
FollowupID: 708828
Reply By: AGNI4x4 - Thursday, Dec 02, 2010 at 09:09
Just an update re Swags ..............ended up going with the Burke & Wills Redgum at a great price from Wild Earth. One does need to shop around as the price varied from $550 for the single 800 wide to the XL single 1100 wide that I ended up getting for $520 postage included.
Cheers and happy trails.
Merry X-mas
AnswerID: 437593
