Prado bad breaks
Submitted: Thursday, Jan 06, 2011 at 01:46
ThreadID: 83462 Views:4142 Replies:7 FollowUps:3
I have a 90 series auto without ABS breaks and for the weight of the vehicle it takes a distance to slow down. Had it checked out and everything is okay, was told replace with different disc and or pads. I would like to hear from people who have changed disc or pads so i can compare best brand with your experience. Thanks you.
Reply By: billborric - Thursday, Jan 06, 2011 at 06:31
I have owned a 90 series since new in 98. I have run original and DBA rotors but cannot tell the difference. The biggest difference is in the pads. I have tried a number of brands over the years and the BEST by a long shot are TRW/Lucas. They are European made ISO certified and nothing comes close.
The only drawback with them is that they do produce dust, but apart from that I haven't experienced any fade and they are brilliant through water crossings.
Have a look at http://www.4x4galore.com and you will see how involved in the 4WD scene I am and that I speak from experience.
AnswerID: 440829
Reply By: Bushranger1 - Thursday, Jan 06, 2011 at 06:49
I had a Magna a few years ago with the same problem. Put in a new set of softer grade pads & problem solved.
Like someone said more brake dust & you have to check them for wear more often but thats a small price to pay.
AnswerID: 440830
Reply By: PradoMad - Thursday, Jan 06, 2011 at 07:00
must say I'm surprised as I have the same Prado (no ABS). Brakes are excellent, not sure what disc I have on.
JS.
AnswerID: 440831
Reply By: Member - rick g (NSW) - Thursday, Jan 06, 2011 at 09:14
g'day mate i own a mechanical business and found the same with my 120 series prado when under load it would not like to stop, so i fitted slotted and drilled rotors with hd bendix pads and fitted braided brake hoses and as if by magic it stops like magic especially with unbraked boat on the back
not a cheap fix but if you keep your car for a long time as i do it's a worthwhile fix.
ps. did the same to my old gq patrol
rick
AnswerID: 440839
Follow Up By: Member - Christopher P (NSW) - Thursday, Jan 06, 2011 at 09:42
totally agree, i pay top dollar for bendix, as i am a heavy braker. and i have had problems with other so called top quality brake pad. I never use anything but bendix. my ford laser run bendix, and i can flog it around my area delivering pizza's.
Love em.
FollowupID: 712740
Follow Up By: Member - MYPRADO - Saturday, Jan 08, 2011 at 03:02
To all of you much thanks, i will try bendix. Was told soft pads has stopping power but must replace regular.
FollowupID: 712988
Reply By: Kimba10 - Thursday, Jan 06, 2011 at 16:36
Have had 2 90 series (still have one diesel) and have always used Bendix 4wd pads, never had an issue BUT both my 90's have/had abs. The abs on the petrol 90 I had was a different set up on the diesel 90 I have now, it runs its own pump, doesnt get its vacuum from the engine, I think any thing with traction control is the same even the 120 series petrol or diesel, and boy do they stop, if you wernt wearing a seatbelt and hit the brakes you would end up through the windscreen, fantastic system but apparently expensive to fix if it goes bang, I believe in the vicinity of 3g's to replace it. Regards Steve
AnswerID: 440876
Reply By: prado-wolf - Saturday, Jan 08, 2011 at 22:23
i have a 90 without ABS and i had the same issue , could step onto the brake pedal and nothing happened.
i paid the money and had ARB replace all the rotors with the slotted once and put the bendix 4 x 4 pads in.
In all honesty , the improvement was small , i still have to always remind myself when i use the Prado after i have not driven it for month that it is not like my commodore , it is heavier and needs a lot longer to stop.
As i said , the new rotors and pads did make a small difference but i am still disappointed with the result.
Hope this will assist you.
AnswerID: 441174
Reply By: billborric - Sunday, Jan 09, 2011 at 17:26
To all those people suggesting Bendix pads. If you check the Bendix site you will note that Bendix say their 4WD pads will still work at temperatures of around 380 c where other cheaper pads work at under 300 c. Check out the TRW/Lucas site where their pads operate between 100 c and 650 c.
Better still have a read of this... http://web.ace.net.au/soarer/lucas_trw.html
My Prado gets used a lot in the mountains of Victoria and I can tell you from experience, some of those cheap pads will continually fade on long steep downhill sections, leaving the only option to descend very slowly in 1st low. And water fade with a lot of pads is a real issue.
billborric
AnswerID: 441271
Follow Up By: Member - MYPRADO - Monday, Jan 10, 2011 at 01:22
I could not follow story, was OEM better or Lucas, please help.
FollowupID: 713338
