Friday, Jan 14, 2011 at 09:14
William,
You are right of course about inefficiency of any energy transformation. I said above that MPPT controllers are very efficient - they are not 100%, but most are over 90%, and some manufacturers claim 97%. If only we could ignore the laws of thermodynamics!
Marty is not right though.
He says
1)"Al see vanners and campers getting sold MPPT controllers with claims of 30% more power and they are not told the complete story. To get anywhere near the extra power requires specific conditions and panels need to be tracking at correct angle."
No - the improvement is there regardless of panel orientation. Correct orientation provides optimum capture area.
2)"MPPT controllers are no benefit with flat mounted panels."
No - The improvement is there regardless of panel orientation. Horizontal mounting is not optimal for most locations in Australia. For maximum sun capture the panel should be mounted perpendicular to a line drawn to the sun. At solar noon in midsummer on the
Tropic of Capricorn, horizontal is in fact optimal.
3)"MPPT controller should have maximum efficiency on 12V panels charging 12V battery. If you go to 24V panels charging 12V battery efficiency drops. The higher the panel voltage charging 12V batteries the lower the efficiency."
No - What we speak of as 12V panels actually produce their maximum energy output at about 18 volts, which is too high for directly charging a 12V battery. When a panel is connected DIRECTLY to a partially discharged battery, the battery draws sufficient current to pull the panel voltage down. An equilibrium is established where the panel voltage is sufficient to maintain the charging current. Once the battery is fully charged and draws less current the voltage rises - this is when we need a controller (even just a simple one) to turn off charging and prevent the panel delivering excessive voltage to the battery.
With a SIMPLE controller and a "12V" panel charging a 12V battery we are losing about 30% of the available energy. With a "24V" panel and a 12V battery we lose far more. Marty is quite correct in saying that, BUT, an MPPT controller overcomes this by converting the voltage at better than 90% efficiency. There is benefit too in using the higher voltage panel, since current (and hence resistive loss) is halved in the wiring from panel to controller. This is not a function of the controller so no manufacturer's graphs or specs, just simple application of Ohms Law.
I respect your opinions, and Marty's too, but I don't share all of them!
| J and V
- Albert Einstein
713872
