Portable generators
Submitted: Tuesday, Jan 18, 2011 at 21:08
ThreadID: 83735 Views:10044 Replies:10 FollowUps:47
About to head up the west coast of WA for next 5 months and expect to be doing a bit of free camping. I think I need a generator but being a non tech head am confused on the choices available. I have narrowed it down to a Honda EU20i at around $1900 or a BBT inverter 4.4Kva at around $600. Both sound like they will run my caravan air con, microwave etc but there is obviously a huge difference in cost. Can anyone tell me the difference and whether the BBT would do the job as well as the Honda. Would appreciate some comments.
Colin
Reply By: oldtrack123 - Tuesday, Jan 18, 2011 at 22:51
Hi Colin
While I can not comment on the BBT genny,It does appear you are new to their use
I would just like to point out a couple of points for you to remember regarding using any 240v source, portable genny or inverter.
[1]240v from any source is potentially DEADLY.
[2]your van RCD if fitted is not functional with a standard portable genny connected via the van power inlet socket
[3]The portable RCDs[plug in type}also will not function, despite some forum articles saying they will!!!
[4] Any RCD fitted to a genny MUST be permanently fixed & wired with some wiring mods required BY AUS Standards
[5]An EARTH stake is neither required or recommended by AUST Standards.
Manuals & some forums may say otherwise,THEY ARE INCORRECT!!
[6]It is generally recommended that only one devise requiring a 3pin plug [earth connection] be connected at ANY TIME,to minimize risk.
[7]Your van has a three pin plug it is the first devise, each additional devise increases the risk
[8]Multiple devise with 2pin plugs can be connected with care
Take great care,240v id potentially deadly .
Deaths HAVE occurred.
AnswerID: 442285
Follow Up By: Member - bungarra (WA) - Tuesday, Jan 18, 2011 at 23:35
Hi oldtrack
Could you please expand on your comment
"Any RCD fitted to a genny MUST be permanently fixed & wired with some wiring mods required BY AUS Standards"
How do we go about this.........legally and safely?
What are your recomendations as to the safe use of reputable Geni (say Honda EU20i) feeding into a carvan 240v inlet?
VKS 1341
FollowupID: 714363
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 09:18
Hi bungarra,
Unless you are an electrician with experience in this area – leave it alone and run your portable genset like anyone else. Just realize that even though you have RCD (earth leakage breaker) on your caravan, it won’t be operational.
FollowupID: 714380
Follow Up By: Member - colin M (NSW) - Wednesday, Jan 19, 2011 at 12:18
Peter and Dennis,
I greatly appreciate your opinions but taking up Bungarra's point how do I use the generator if I am not plugging in to the 240 inlet on the caravan.
I definitely want to do it safely & legally and do not want blow up my van or appliances.
I can live without the microwave and the air conditioner as gas will cover the fridge and my weber will cover the cooking.
What do I connect the genny to. Sorry I realise I am obviously electrically ignorant even after reading the exploroz article above.
At least I have a month or so to keep asking around.
Thanks again for the replies as usual members of Exploroz are very helpful.
Colin
FollowupID: 714392
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 12:37
Just plug your genset into the caravans inlet as you would to any other 240 supply.
Your caravan's RCD will work on town power but not when on the genset’s power.
I have the ability to rewire the genset to an MEN system similar to town power.
I won’t do it because the risk is very small. There is greater risk of electrocution if non experienced people try to set up MEN systems, and the Electrical Authorities advise against it.
FollowupID: 714396
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 12:41
Hi Colin
The " explore AUs" articles on genertor & inverter section on "safety "has serious errors which are misleading & potentially dangerous
This was pointed out to them some time ago.
I am suprised they have not checked the FACTS supplied to them & corrected the articles.
I guess it just goes to show uou cannot believe everything posted, even in what appears to be a well written & proffesional article.
RE the connection of the genny to the van
[1]If the genny only has a10amp outlet, the legal requirement is for an APPROVED Adaptor
Ampfibians are an APPROVED DEVISE.
NOTE. The power boeards such as Clipsal are specifically not approved for this application.
There is NO APPROVED WAY of having your genny or inverter operate your van RCD unless it complies with the standards
Permanently fitted & in the van wired OR permantently fitted & wired into the genny /inverter
JUst read my 1st post It is not illegal to connect a non RCD protected genny/inverter to your van inlet socket[
In fact probably thousands do just that.
BUT PLEASE JUST BE AWARE THERE ARE RISKS.
FollowupID: 714397
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 13:01
Hi Dennis
RE:
"I have the ability to rewire the genset to an MEN system similar to town power.
I won’t do it because the risk is very small. There is greater risk of electrocution if non experienced people try to set up MEN systems, and the Electrical Authorities advise against it."
I hope no electrician would rewire a portable genny or inverter [asused by RVers to a MEN
To a floating earth neutral, YES.
M.E.N. NO,
NO earth stake no M.E.N.
I totally agree NO unqualified person shall perform 240v electrical work !! end of story
This is the reason I refrain from posting TOO MUCH detail doing so may encourage some toTHINK they know what is required.
THe unfortunate fact is that even many electricians,with limited experiance may also not know what isrequired.
FollowupID: 714405
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 13:43
When I was a boy MEN systems had an earth stake
FollowupID: 714410
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 14:14
Oldtrack,
I am not sure we are on the same wavelength.
The connection I was talking about is bonding the neutral, and using an earth spike - then the RCD would work. I don’t do this as it takes much time to do it correctly, plus the risk of electrocution from a genset without RCD protection is very low.
FollowupID: 714415
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 14:15
Dennis Ellery posted:
When I was a boy MEN systems had an earth stake"
Hi Dennis
Exactly , correct!!
BUT ,Portable gennys & inverters as used by RVers should not be M.E.N.ed
simply earthed neutral within the gen wiring .not MEN
AS /NZS 3001 says :
AN EARTH STAKE IS NEITHER REQUIRED OR RECOMMENDED
Some states legislation forbid earth stakes with small portable generator & inverters!!
FollowupID: 714416
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 14:17
Hi Dennis
Exactly , correct!!
simply earthed neutral within the gen wiring IF FITTED WITH A PERMANENT RCD . not MEN
AS /NZS 3001 says :
FollowupID: 714417
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 14:27
Hi Dennis
I do understand what you are saying .
IT is relevant to a MEN system ,BUT as above the portable genny/inverter should not be M.E.N.ed
NOT delibertately connected to ground[terra firma]by an earth stake.!!!
ALL that is required for satisfactory operation of the RCD is a correctly wired genny or inverter & permantently fitted /installed RCD.
Ground /terrafirma connection is not required for correct operation.
FollowupID: 714419
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jan 19, 2011 at 14:48
Peter, regarding your expression "ALL that is required for satisfactory operation of the RCD is a correctly wired genny or inverter & permantently fitted /installed RCD."
Some readers here possibly regard that they DO HAVE a "correctly wired genny" and a "permantently fitted /installed RCD." So they may feel assured that all is right when it may well not be so.
Whenever this subject arises on here it evolves into technical advice and argument largely incomprehensible to a layman. Surely it would be better to simply express of the danger and advise leaving it to a licensed electrician?
FollowupID: 714420
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 15:28
HiAllan
Yes,I tend to agree with you .
I certainly agree that such work SHALL only be done by a licensed qualified electrician & I think have made that point many times.
I have also repeatedly made the point that THE RCD cannot operate with a standard of the shelf portable generator.
It must be specially modified & wired by a capable qualified electrician when fitting a RCd
The installation SHALLl comply to the standards.
It is also the reason I do not believe in being TOO detailed in explaining what is required,just in case some one thinks they understand & tries to carry out such work.
However Dennis has raised points that need some clarification,I am endevouring to explain without going into too much detail.
To ALL those who may believe that their RCD may be functional with THEIR generator or inverter.
I WOULD STRONGLY SUGGEST YOU HAVE YOUR RCD OPERATION CONFIRMED BY a qualified electrician testing AT ALL POWER POINTS IN THE VAN.!!
MY initial post was to make generator & inverter users aware of THE POTENTIAL RISK
SOME may say the risk is low, BUT deaths have occurred due to a certain combination of faults.
While a fully isolated geny or inverter remains fully isolated there is little risk.
,BUT if an undetected earth fault developes ANYWHERE in the system[wiring, appliance,etc] the system is no longer isolated.
BUT the RCD will not be functional.
The risk of a person being the next fault is then exactly the same as in the MAINS supply situation but with an inoperational RCD
THAT IS THE MESSAGE I AM TRYING TO GET THROUGH.
FollowupID: 714423
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jan 19, 2011 at 16:12
Hi Peter, it's good to see that we have some agreement on the hazards of giving electrical advice on here. I have got deeply involved in the past but came to realise that I may just be leading a layman in deeper than helping him to understand the technical elements of 230v installations. Heaven forbid that someone may consider themselves knowledgeable as a result of something I have said and cause grave injury. One could even find oneself in the witness box justifying to a coroner about the "advice" given to the deceased! This is even more likely if this advice came from a person who has qualifications in electrical matters.
I am quite convinced that we would be wise to simply state that there are serious and unseen dangers in electrical installations and the enquirer should consult a licensed electrician.
In saying that however I see no harm in advising that the use of an approved plug-in proprietary appliance such as the Ampfibian is appropriate or that fitting 10A plugtops on a 15A extension is dangerous and illegal but without qualification or argument.
I hope that I do not succumb to chiding you again...... you may come to think that I don't like you. Not so, I do appreciate that you are concerned about the welfare of others.
FollowupID: 714433
Reply By: bluefly - Tuesday, Jan 18, 2011 at 23:54
Colin
First of all I’ve never heard of a BBT, but I can imagine where it comes from.
Ask yourself one thing (which never seems to be discussed on this site) do you want something that is reliable, or cheap?
The Honda for example will last about 25 years at a cost of $76. It will also run your air conditioner provided you don’t have all sorts of other gadgets going at the same time.
There is also a lot of carry on about 10-15amp conversions. If you’re worried about that, there is a new product on the market (details of which I don’t have at hand). It’s a basic 10-15amp converter.
There’ll be other blokes coming on here talking about their bargains, but at the end of the day it doesn’t mean much. Go for a Honda or Yamaha.
AnswerID: 442294
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 09:12
I tried a 2 kva genset on my air conditioner and it used to shutdown on very hot days. I had to go for a 2.4kva unit
If you search previous threads you will see that people have reported problems running 2kva’s and conditioners on very hot days. Of course it all depends on the size of your airconditioner.
Also realise the 2kva is only about 1.6kva continuous and 2.4kva is approx 2kva.
FollowupID: 714379
Follow Up By: Road Warrior - Wednesday, Jan 19, 2011 at 11:32
BBT is 'Big Boys Toys' and are an ebay seller.
FollowupID: 714387
Follow Up By: Member - colin M (NSW) - Wednesday, Jan 19, 2011 at 12:28
Yes thats correct I found the advert via ebay and it is a supplier called Big Boys Toys
Colin
FollowupID: 714395
Follow Up By: Harry and Ann (WA) - Wednesday, Jan 19, 2011 at 12:59
Colin , Sorry to high jack your thread but i hope my questions will also benefit you .cheers H & A.
FollowupID: 714403
Reply By: Member - Porl - Wednesday, Jan 19, 2011 at 01:51
Well not exactly what you want to hear but gee whiz it's not all as straightforward as it may seem. I was in the war zone of the brisbane floods and the water got within a couple meters of my house but I lost power for 6 nights. In an effort to save my fridge I invested in an inverter as my Yamaha 1kw gennie could not start my fridge. I had the gennie running a battery charger attached to a battery connected to a 1000w inverter with a 2000w surge capacity - worked fine for a few days now I have one dead battery and the inverter overloads every time I start that system up.
My advice is the less components in the system the better, go for a good generator for piece of mind.
While everyone is here, this Forum advertised a new Generator series a week or so ago with 10% off for Members, but I can't find their advertisement anymore, does anyone recall the name of that importer?
AnswerID: 442301
Reply By: Ol' Bunky - Wednesday, Jan 19, 2011 at 09:44
I don't see why an RCD wouldn't work on a genset. It works by looking for a difference between outgoing current (down the active) and returning current (down the neutral). If there is a difference of usually 30mA, it will trip.
AnswerID: 442317
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 12:20
Hi Bunky
I can assure you ,as a qualified electrician,IT CANNOT /IT WILL NOT WORK
Pressing the "TEST"button also does not indicate it is functional under an earth fault condition.
TO the OP, YOU cannot make the necessary changes,THESE SHALL be carried by a qualified electrician.
I would suggest ALL those who do not believe/agree with my post to just do a bit of searching on some other forums using "RCD", "Inverter safety " "generator connected to van. " ETC
FollowupID: 714393
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 13:00
Old Bunky,
When on town power, where there is a difference between current flowing through the active and the neutral, that difference flows down the earth wire.
On a small genset there is no connection between the earth and its output , so there is no difference in the current flowing in and out of the gensets active and neutral, as you put it. It doesn’t know the difference in whether it’s frying you or the bacon.
FollowupID: 714404
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jan 19, 2011 at 14:18
So Dennis, if there is "no difference in the current flowing in and out" of the genset's line conductors how can it be "frying you"? Unless of course you are connected between the pair of line conductors which is not what the discussion is about.
Whilst there remains isolation (ie no connection) between the genset's output and earth then there can be no potential for electric shock from the genset output lines and earth.
Yes or no?
FollowupID: 714418
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 14:48
Hi Allan,
I’m having a bad day,
Oldtrack is getting stuck into me and now you’re in for the chop.
Of course he would be connected between the genset’s live conductors.
This can occur with earth faults on two separate appliances.
He couldn’t be fryed with one earth fault as there is no connection between the live conductors and earth.
FollowupID: 714421
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 15:38
Hi Allan,
Oldtrack is getting stuck into me and now you’re in for the chop. "
Hi Dennis,
Sorry ,we do looove you.
Allan must be in a mood he's just had a chop @ me too.
But at least we are gentlemen , not calling each other nasty names.
Wish I could put SMILES on this forum
It might take the edge of some of my posts
FollowupID: 714425
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jan 19, 2011 at 15:40
Sorry Dennis, yeah, here I am saying that we should not be advising or discussing 230v electrical matters in front of laymen and I go and do just that with you. We need a "Private Room" for that maybe LOL.
It really does concern me that unqualified people consider that they may be capable of fooling around with 230v stuff. You, I, Peter and some others here are aware of the perils yet we get involved in advice. Even though it may be considered justified on the grounds of telling the laymen what not to do it still represents expression about a subject that has lethal consequences. And it would be dreadful to be involved in a situation of severe outcome as a result of discussions made here.
We should simply say that the proposal has elements of severe risk and the enquirer should refer to a licensed electrician. I cannot imagine a cardiac specialist giving advice on here!
FollowupID: 714426
Reply By: Member - Graham H (QLD) - Wednesday, Jan 19, 2011 at 10:00
Simple answer is buy a Yammy 2.4 and the 10-15amp unit mentioned is an
Amp-fibian and costs about $245 and is the ONLY legal way to run a caravan
off 10amp feeds
See the two models here
http://www.ampfibian.com.au/products.htm.
I doubt a genny will start a microwave due to the high startup current draw
The cheap stuff ruins more appliances than it runs.
It is illegal to run a van off a 10 amp circuit either by making a short adapter.
or changing the plug on one end or filing the earth pin.
It is also illegal to make a cable loop and feed two inputs on a van as in some
Boromas and other large vans which run the aircon on a separate circuit
Others will tell you they do it and have done for years but the fact is
ITS ILLEGAL .
AnswerID: 442319
Follow Up By: rooster350 - Wednesday, Jan 19, 2011 at 10:46
Our 1kva Honda runs the microwave in our caravan without any trouble at all....
FollowupID: 714385
Follow Up By: Harry and Ann (WA) - Wednesday, Jan 19, 2011 at 11:01
HI GRAHAM. we have a Honda eu2000 do we need a amp fibian to power our caravan safely.
FollowupID: 714386
Follow Up By: Member - bungarra (WA) - Wednesday, Jan 19, 2011 at 11:56
Harry and Anne
The later model EU20i have the 15 amp power outlets as standard......have you checked yours?
VKS 1341
FollowupID: 714389
Follow Up By: Harry and Ann (WA) - Wednesday, Jan 19, 2011 at 12:06
Yes we have the 15 amp outlets on the gen set , but will the rcd in the van still work when we power with the gen set, or do we still need the amp fibian.
FollowupID: 714390
Follow Up By: Member - colin M (NSW) - Wednesday, Jan 19, 2011 at 12:25
Ok so it looks like I should go for the most popular Honda and make sure its the new model with 15 amp out put but I would also like to know if I need this amp fibian and do I plug the genny into my 240 inlet on the caravan?
Colin
FollowupID: 714394
Follow Up By: Dennis Ellery - Wednesday, Jan 19, 2011 at 12:48
Harry and Anne
There is an RCD in the Fibian, but it is useless when used on a genset.
The RCD in the caravan is also useless when run from a genset.
I am talking about the portable genset carried by a caravaner.
If you come across a caravan park running off a genset, both RCD’s will work as these gensets have an earth connected neutral in the same fashion as town power.
FollowupID: 714399
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 12:50
" Hi Harry and Ann (WA) posted:
Yes we have the 15 amp outlets on the gen set , but will the rcd in the van still work when we power with the gen set, or do we still need the amp fibian."
Hi Harry
If your genny has a 15amp outlet you do not need an Ampfibian.
YOUR VAN RCD WILL NOT WORK EVEN WITH AN Amphibian
See my POSTS.
The RCD cannot work no matter where it is ,with a standard of the shelf fully isolated genny /inverter[the only type you should have]
FollowupID: 714400
Reply By: Member - Graham H (QLD) - Wednesday, Jan 19, 2011 at 16:34
All these technicalities are confusing the newbies.
To summarise A Honda EU20i would probaly do for the OP
as they are really only 1600w and 2000w peak A
Yamaha 2.4 WOULD BE BETTER as its 2000w and 2400peak load.
You DO NOT NEED A AMP-FIBIAN if your genny has 15 amp sockets.
It will run your aircon but may not run the microwave due to high start up current Depends on the model of the microwave..
The basis is You get what You pay for Experienced campers use good reliable equipment
Buy cheap and wonder what it is doing to your systems as it could provide very dirty power.
Both the Honda and the Yammy will look after things like computers and TV's The cheap one may well run over voltage and fry them.
So go and buy a Yamaha 2.4 and you will be set up nicely.
If the difference in price is an issue it may well be nowhere near as much as replacing stuff the cheap one fried.
AnswerID: 442360
Reply By: ob - Wednesday, Jan 19, 2011 at 16:42
OK guys, some of you seem to know what you are talking about so could you please explain (genuine question, not trying to be a stirrer) what the small connection point marked on several gennies as an earth or ground is for??
ob
AnswerID: 442362
Follow Up By: oldtrack123 - Wednesday, Jan 19, 2011 at 17:06
Hi Ob
I am going to follow Allan's advise
I wiil simply state The AUS STANDARDS,THE ONES WE ARE CONCERNED WITH''
"AN EARTH STAKE IS NEITHER REQUIRED OR RECOMMENDED"" when used as a portable unit
However ,OOOPS ,I was going to go further but I had better not .
LOS for Allan
FollowupID: 714441
Follow Up By: ob - Wednesday, Jan 19, 2011 at 18:06
OK Peter, point taken about "a little knowledge being a dangerous thing" it just always intrigued me
ob
FollowupID: 714446
Follow Up By: dbish - Wednesday, Jan 19, 2011 at 20:11
God only knows how this thread turned into arguments about 10/15 sockets & RCDs. The orig question was should he buy a $1900 honda or a cheep $600 geny at mutch greater capacity. The cheep generator of today usually have 15A sockets. The price difference is 3 to 1 for me its a no contest. You would be dam unlucky to have 3 faulty generators. Mine is a 3year old Kipor 2600W when bought it, it was one third of the price of a Honda. Its still going & gets used when camping & for extended power outages that we seem to get.
FollowupID: 714457
Follow Up By: Member - colin M (NSW) - Tuesday, Jan 25, 2011 at 18:27
Thanks to all of the technicians for the advise but unfortunately I am still confused. Do I just hook the Honda or Yamaha to the 240 outlet that I I hook up to in when in a normal caravan park? Do I need anything else to be safe?
The aim I am thinking at the moment is I will forgo free camps and stick to caravan parks.
FollowupID: 715073
Follow Up By: Member - Graham H (QLD) - Tuesday, Jan 25, 2011 at 19:28
As usual this has degenerated into a he said she said
Buy a Yamaha 2.4 and a 15 amp extension cord
Plug 1 end into the gennie and the other into the normal caravn input..
Put the choke on and pull the cord.
Everything will work and you will be fine.
Dont be dazzled by the technicalities.
Thats all we did and I am still alive and nothing blew up in the Van.
The van doesnt know if the 240 is coming from a gennie or a camp power outlet.
Just be considerate and dont annoy others when you use it.
You will be fine.
Have fun.
FollowupID: 715079
Follow Up By: oldtrack123 - Tuesday, Jan 25, 2011 at 23:28
Hi Graham B
I do [NOT] admire your complacency with 240v
The supply from mains IS RCD PROTECTED & THE VAN RCD IF FITTED WILL BE OPERATIONAL
You did not give any sort of warning to even treat with care.
YOUR POST IS ERREPONSIBLE.!!!!!!
THINK TWICE BEFORE POSTING SUCH CRAP.
FollowupID: 715095
Follow Up By: Member - Graham H (QLD) - Wednesday, Jan 26, 2011 at 08:20
Oh dear we are upset.
The guy asked which he should use and got about 15 foot of technicalities which he obviously didnt understand.
Of course it goes without saying electricity should be treated with respect.
However for many year houses and vans didnt have RCD's and most of us got on OK.
I was trying to simplify the answer to the question which a few of you definitely werent.
All you did was confuse the poor guy.
From GRAHAM H and im not IRRESPONSIBLE.
FollowupID: 715113
Follow Up By: dbish - Wednesday, Jan 26, 2011 at 08:27
What amazes me is the orig question was which generator to buy!!!
FollowupID: 715114
Follow Up By: Member - Graham H (QLD) - Wednesday, Jan 26, 2011 at 08:48
Exactly and look what it turned into.
FollowupID: 715119
Follow Up By: oldtrack123 - Wednesday, Jan 26, 2011 at 08:48
Hi Graham
RE :'However for many year houses and vans didnt have RCD's and most of us got on OK. ""
Many did not & unfortunately are not with us to tell what it's like.!!!
Why do you think RCDs are now mandatory in all homes caravans etc.??
One reason because accidents/deaths have occurred!!!
Why do you think it is mandatory for all portable generators used in industry must be fitted with RCD???
Because deaths have occurred!!
IN my opinion YOUR POST IS ERRESONSPIBLE!!!
FollowupID: 715120
Follow Up By: oldtrack123 - Wednesday, Jan 26, 2011 at 08:55
Hi Graham & Daryll
Strange, the OP & several of the follow ups showed some interest in my original warning
I wonder WHO realy turned it into a mess???
Can you honestly say my original & replies are not valid. ??
FollowupID: 715122
Follow Up By: Member - Graham H (QLD) - Wednesday, Jan 26, 2011 at 09:01
You are entitled to your opinion.
However if the original question had been answered we wouldnt be having this liitle spat
The question was which of two items should he buy.
You guys went on for several days about things which, while sensible did NOT answer the question.
As usual the thread got sidetracked and ended up like this.
It happens on numerous occasions when a simple answer that one or the other would be better for his use.
Thats all he wanted to know.
He obviously is not technically minded and now is so confused he is talking about only staying in van parks.
A good way to ruin what he thought was going to be a nice holiday.
Actually Errisponsible starts with an I
FollowupID: 715123
Follow Up By: oldtrack123 - Wednesday, Jan 26, 2011 at 09:07
Hi Colin
Just re read my 1st post to you.
Do not forsake free camps ,you will find them the best part of your trips.
JUst remember my points & treat 240vwith care.
ANY SUGGESTION OF PROBLEMS HAVETHEM CHECKED IMMEDIATELY
Also remember you do not have a functioning RCD /safety switch with the genny plugged in
FollowupID: 715124
Reply By: Allan B (Sunshine Coast) - Wednesday, Jan 26, 2011 at 11:04
Good God, it is no wonder that Collyn Rivers quit this forum a while back. Here are a couple of extracts of his final contribution:
"Sites such as this are sought by people confused (particular in the electrical area) by the mass of misinformation, campfire mythology, and often seriously misleading advice from sales people. They seek simple solutions that work - not ongoing wrangling."
"It has also not infrequently caused others to state my advice is flawed or wrong and this is a serious issue for a professional engineer and professional writer/publisher offering advice in the same field. People are thus left wondering about my competence in the very area in which I publish - but with no way of judging it."
"I have therefore and reluctantly decided to cease, as from now, to respond to all questions on this site......"
And thus we lost the valuable contributions of a competent professional member.
Collyn's full expression can be found here in thread 31345. His point is totally relevant and particularly so to this current thread. If this initiates argument about his assertion it only serves to validate it.
Thank goodness that at least a couple of respondents answered the original question as to choice of generator without getting on a soapbox on a side issue. I would suggest that those who wish to "bang a drum" as an aside to the topic become a member of ExplorOz and so permit argument by means of Member Messages rather than air their passionately-held opinions on a thread opened by someone with a simple non-technical question. Either that or write and submit an authoritative Article on the subject as have some others and leave it at that.
AnswerID: 443083
Follow Up By: oldtrack123 - Wednesday, Jan 26, 2011 at 22:24
Hi Allan
RE:"Either that or write and submit an authoritative Article on the subject as have some others and leave it at that."
Unfortunately some of those "AUTHORITIVE" articles have some serious & misleading statements
TRY reading the safety section on the articles about "generators"&"inverters"
I have reported BOTH these articles but it seems someone is content to leave such misleading & potentialy dangerous statements stand.
EVEN though the article was recently updated.!!
FollowupID: 715229
Follow Up By: oldtrack123 - Wednesday, Jan 26, 2011 at 22:31
HI Allan
A PS since I cannot edit
MY very first reply to the OP was to ensure he did not believe ALL that was written in that :"AUTHORITIVE ARTICLE" to the top right of this thread.
He would have left with A TOTALLY FALSE SENSE OF SAFETY
FollowupID: 715231
Reply By: Member - Captain (WA) - Wednesday, Jan 26, 2011 at 11:07
Hi Colin,
Like most electrical threads, this one is out of control by the usual suspects. Hopefully these comments will aid and not confuse you further.
Your original questions...
1. Go the Honda IMHO, you will not regret it. You may get away with the BBT but the thought will always be at the back of your mind... should I have bought the Honda?
2. The Honda is a proven unit and has a good reputation. The BBT is cheap and has a tech sheet that looks good, but is not proven nor has any reputation...
Arising RCD questions...
Simplistically (and this is in layman terms so not 100% techncally correct), an RCD works by measuring what goes in and out and trips if there is a difference. In a failure mode for normal power, think of the power coming thru one of the wires, thru the appliance and then thru YOU. Now because you are standing on the earth the current also goes thru to the earth and back to the power supply. But it didn't pass thru the RCD so it measures the difference and saves your life by tripping! All good :)
Now, on generator power, there is no connection to earth so even though you are standing on the ground in a failure mode, all the power goes thru you and back to the generator. The RCD doesn't see any difference (none "leaked" to earth) so it doesn't trip. End result is you fry!!!
While the above sounds like generator power is dangerous, the circumstances required for that to happen are very, very, very hard to reproduce and unlikley (but not impossible) to happen. As others have said, just take extra care and you will be fine. 1,000's do it all the time and have no issues, there is FAR more chance statistically that you wil have a vehicle accident on your caravan trip than have a electrocution issue if you use a quality generator and take the normal sensible precautions.
Hopefully I have not added to your confusion.
Captain
AnswerID: 443084
Reply By: Allan B (Sunshine Coast) - Wednesday, Jan 26, 2011 at 13:06
Hi Colin, Even still the technical expressions re 230 volts continue. I only hope that you can comprehend it but fear that you may not.
As an Electrical Engineer, in respect to electrical safety, I would say to you as follows:
1. Purchase only quality appliances including generators. One measure of quality is the manufacturer's reputation and multiple recommendations.
2. Wherever possible use only Double Insulated appliances. These are so marked on the appliance and usually on the packaging and generally indicated by the absence of an Earth Pin on the connecting cable.
3. Maintain your appliances in good electrical condition. No broken parts, frayed cords, or wet connections.
4. If your chosen generator does not have a 15 Amp socket (with larger earth-pin) for electrical connection to your van use a device such as an Amp-Fibian which allows you to connect the 10 Amp generator to the 15 Amp inlet socket of the van. Connect to the van only with a 15A rated cable. Note though that 15A will not be available at the van, only the generator rating.
5. If in any doubt or to carry out any 230V electrical wiring consult a licensed electrician.
AnswerID: 443101
Follow Up By: oldtrack123 - Wednesday, Jan 26, 2011 at 22:14
HI Colin M, Bungarra
AND others who wish to have what I believe is the BEST available safety measure AT THIS TIME for RVrs using ALL sourcesof power via power inlet socket
Contact this link:
info@powerstream.com.au
Explain you wish to use a genny &/'or inverter by means of your power inlet .
The APPROVED devise solves the problem of universal protection from earth faults when using MAINS ,genny or inverter power via the power inlet socket .
It replaces your RCD if fitted [& performs the function of an RCD when fitted to a van which has not had one fitted previously!
IT also gives A VERY HIGH LEVEL OF PROTECTION when using of the shelf non RCD protected gennys & inverters WITHOUT THE NEED FOR THEM TO BE MODIFIED IN ANY WAY.
IT MUST BE INSTALLED BY A LICENSED & COMPETENT ELECTRICIAN.
I have no interest in any of the COs involved in this product, EXCEPT I have followed its development & am very impressed
FollowupID: 715227
