Monday, Jan 24, 2011 at 18:50
hi Leon, as Graham has said it will make it ride harder ...... re-setting is the best or go to the likes of the bigger off road shops and talk to them, they do spring kits that have "lift" built into them .... check out e-bay for price ideas ....
The things to think about is your expected load and ride you want, if you expect to carry heavy loads then you will need get a "stronger" spring and you will lose some comfort, if you simply want it lifted you can get higher but nice and soft,
the springs are there for adsorbing the bumps and taking the stress away from the body and contents, the harder you make it the harder it is going to be on your car body and chassis, dont be scared of going on the soft side as long as the quality is good they will last and so will the car and contents ........
714982
