Do you need an airconditioner if you have fantastic fan?
We are preparing a wishlist for a new van. Do you need an airconditioner if you have fantastic fan?
Reply By: Notso - Monday, Jan 24, 2011 at 11:47
Depends where and when you are planning to travel I guess. Also how well you tolerate sleeping in a lather of sweat.
Some places if you don't have air con you won't sleep at night. A fan only helps if the atmosphere isn't saturated with moisture.
AnswerID: 442882
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 12:30
Thanks Notso,
Cheers Peter
FollowupID: 714930
Reply By: Member-George (WA) - Monday, Jan 24, 2011 at 11:47
That depends on how hot it gets. Most of the time, up to 35c, we use a fan and that is quite adequate. Over 35c the wife starts to feel the heat so we switch on the air con. We also use the air con when the humidity is high. Hope this helps. Cheers
AnswerID: 442883
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 12:31
Thanks George,
Cheers Peter
FollowupID: 714931
Reply By: MrBitchi (QLD) - Monday, Jan 24, 2011 at 11:52
If you plan on being up north during the wet season then you need an aircon. Fans just don't cut it in high humidity.
AnswerID: 442884
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 12:32
Thanks MrBitchi
Cheers Peter
FollowupID: 714932
Reply By: Motherhen - Monday, Jan 24, 2011 at 11:53
Hi Peter
What climates will you travel in?
How well do you cope with the heat?
Will you be in the van during the heat of the day or driving in air conditioned comfort?
If you will travel in hotter climates (and to me our north can be hot even in June/July) and you don't like the heat, have an air con as well as a fantastic or two, even if you only use it occasionally.
If it is 40º outside, a fantastic won't bring it down to 22º like an air con might. I don't cope well with heat, and even though we travel at optimum times of the year for the region, it can still get hot. However on our last trip of five months, we didn't use our air conditioner at all when independently camped, but did welcome it when in caravan parks in Darwin and Mt Isa. Otherwise if we stopped early we found it quite comfortable sitting outside in the shade, and much nicer than sitting shut up in the caravan.
AnswerID: 442885
Follow Up By: Motherhen - Monday, Jan 24, 2011 at 11:55
At lot of similar answers while i was typing! We also have a good 12 v fan which we do use when we come inside on a hot evening.
Mh
FollowupID: 714925
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 12:33
Thanks Motherhen
Cheers Peter
FollowupID: 714933
Follow Up By: Member Boroma 604 - Monday, Jan 24, 2011 at 15:04
Gooday,
Most of all are you going to stop in Caravan parks all the time as they need electricity.
Know of several caravaners who have fitted household air conditioners, either at build or afterwards, they say they are so much quieter and efficient, a lot cheaper and can be easily run from a 1 Kva Generator when not in a park.
We have a 12 volt fan in our caravan which is fabulous. Seldom use the Electrolux air on top of the caravan.
Cheers, Boroma604.
FollowupID: 714951
Reply By: Member - Vince M (NSW) - Monday, Jan 24, 2011 at 12:14
There are still a lot of people who live in the top end of Australia that don't have Air conditioning & our pioneers did not have it, I did not have it on my 1st trip several decades ago but it was also unbearable some nights due to the heat & it became standard practice on sleep on the roof of the cruiser without mossy nets as that would stop the breeze & that alloy hot box on wheels called a caravan became a storage unit on wheels as no one could have lived in it & it was a insulated model
we still travel to remote Australia without air con in the camper but try to not be there in the hot months of the year (Did the cape & the Simpson late October that was bad enough some nights)
good luck with the fantastic fan as that will probably turn it in to a fan forced hot box but if your got the power to feed Air Con go for it you wont look back
& it may even save your life as i know of a few accidents caused by fatigue due to the lack of good sleep due to the heat
Good luck
Vince
AnswerID: 442888
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 12:35
Thanks Vince,
Cheers Peter
FollowupID: 714934
Reply By: i'machocoholic - Monday, Jan 24, 2011 at 12:19
Hi Peter,
As others have already written, it depends on where and when you'll be travelling.
My guess is that you are considering a 240v air con - have you considered a 12v one?
Our van has a 240v and 12v air conditioner...the 12v acts like an evaporative air conditioner. All I can say is IT IS BRILLIANT!
We have recently got back from a 7 week trip in central Queensland. Initially, we got the 12v air con to help sleep when free camping, but its uses are much more than that. We drove with the 12v air con on as it pressurises the van and keeps the dust out, it keeps the van cool so when we pull up for a morning coffee or lunch, the van is nice and comfortable to sit in, it's quiet, and pulls very low amps. We will also sleep with it on and with the extra use of a couple of 12v fans by our bedsides to keep the air moving (and also acting as a bit of white noise...I sleep light), we sleep really well.
We have used the 240v air con when it's really stinking hot, but the 12v gets a lot more use for us.
I think if you can afford it, add at least one air con to your wishlist - 2 if you can go the whole hog - you won't regret it!
AnswerID: 442889
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 12:28
Thanks i'machocoholic,
what type of a 12v air conditioner do you have? What current does it require?Does it also run on 240v?
Cheers Peter.
FollowupID: 714928
Follow Up By: i'machocoholic - Monday, Jan 24, 2011 at 13:10
The airconditioner is a TurboKool - they come from the USA. Most caravan accessory places should be able to order them in.
It's purely a 12v airconditioner and not 240v - it can be used as a fan (blowing air), as an evaporative air con with water going through it, or even as an exhaust fan (to eliminate cooking smells). It's very versatile. It only pulls 2.4 amps and weighs about 5kg.
One thing to point out - if you're having a van made and decide to go down the 12v air con route - ask for some roof reinforcing where the 12v air con would go otherwise you will need to pay for a reinforcing kit at time of installation which isn't cheap.
FollowupID: 714937
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 13:51
Cheers Peter
FollowupID: 714943
Reply By: funnyfarm - Monday, Jan 24, 2011 at 14:12
I say "go the air conditioner" all the way. Our last trip we took a portable air conditioner with us (camper trailer) and used it. It was a life saver for sleeping on hot nights. We have little kids, including a baby, and found it invaluable. Best thing we took with us. A good night sleep is soooo precious LOL.
AnswerID: 442903
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 14:18
Thanks Funnyfarm
Cheers Peter
FollowupID: 714946
Reply By: Member - David M (SA) - Monday, Jan 24, 2011 at 16:29
Peter. Weigh up all the advice and options then fit the Aircon. You won't regret it.
Dave.
AnswerID: 442913
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 16:38
Hi David M
Thanks. After consideration of feedback and my wife thoughts we will probably both appliances. Cheers Peter.
FollowupID: 714962
Reply By: CJ - Monday, Jan 24, 2011 at 17:10
Some replies above ask the obvious question on "how hot"
I suggest that the real question should be "how hot AND how humid"
If it is hot with low humidity a fan may suffice. If it is really warm and you dampyourself with a wet towel a fan will work even better in low humidity
BUT if you go to the Tropical summer areas where it is only 33 degrees but with 95% humidity, mate it fels like 40 degrees, and a fan just blows sticky air at you. Damp yourself and you make it worse. This is where the AC is king
CJ
AnswerID: 442918
Follow Up By: Peter Eltham - Monday, Jan 24, 2011 at 17:30
Thanks CJ.
I think I will get both.
Cheers Peter
FollowupID: 714966
Reply By: glenok - Monday, Jan 24, 2011 at 21:39
Dont forget that it can get very cold aswell and a reverse cycle may also come in very handy.
Glen
AnswerID: 442942
Follow Up By: Peter Eltham - Tuesday, Jan 25, 2011 at 09:31
Hi Glen,
Thanks.
Cheers Peter.
FollowupID: 715027
Reply By: Member - Graham H (QLD) - Monday, Jan 24, 2011 at 22:48
My attitude is you cant use what you havent got do its an aircon for me.
You can use it as just a fan or cooling or heating.
Wouldnt take a second similar appliance as weight comes into it and if you
take a backup of everything you wont be able to move the van except with a
Mack truck.
We had to leave 190kg of stuff behind when we set out Thought we would need it. Never missed any of it.
AnswerID: 442950
Follow Up By: Peter Eltham - Tuesday, Jan 25, 2011 at 09:33
Thanks Graham,
Cheers Peter
FollowupID: 715028
Follow Up By: Member Boroma 604 - Tuesday, Jan 25, 2011 at 10:36
Gooday,
Would also advise that when the time comes to sell it again, (always think ahead), most buyers will EXPECT air conditioning. So many of these things like a shower and toilet on board were once a dream, with the current standards of living they are now an expectation.
Boroma 604.
FollowupID: 715031
Follow Up By: Peter Eltham - Tuesday, Jan 25, 2011 at 14:17
Thanks Boroma 604,
Good point. My wife agrees.
As we will be getting a poptop I was concerned about the heavy load on the roof and leaks. After consideration of all comments we will get both a 12v Fan-tastic Roof Vent and an airconditioner because someplaces we go are hot and humid. The 12v Fan-tastic Roof Vent will be good when we do not have power.Cheers Peter.
FollowupID: 715047
