Porta-Bote
Submitted: Wednesday, Jan 26, 2011 at 18:15
Member - Julio C (VIC)
Hi, I have been looking in purchasing a 12ft Porta-Bote with a suzuki 4 stroke 5hp outboard.They look so easy to put together and transport. I would like to hear from someone that has one, or has something to do with one. Thanks.
Reply By: Member - Josh- Wednesday, Jan 26, 2011 at 19:04
I went out fishing in one sometime ago with merv (a member from EO). It was a weird feeling having the bottom move with the waves. It got really choppy while we were out to the point waves were just coming over the front. All though I was crapping myself it was surprising stable. They are a great concept. I was a bit sceptical but after fishing out of one I would reccomend them.
Josh
443143
Reply By: Member - Myles F (QLD) - Wednesday, Jan 26, 2011 at 19:38
Julio, I’ve got one. Just bought it. Put it together for only second time today and it took eight minutes including mounting the motor. I have experience as my father bought a 10 footer and my brother bought a 12 footer. I think they’re brilliant. Is there anything in particular you want to know?
Myles.
443147
Follow Up By: Member - Myles F (QLD) - Wednesday, Jan 26, 2011 at 19:40
Image Could Not Be Found
715202
Follow Up By: Member - Julio C (VIC) - Wednesday, Jan 26, 2011 at 20:22
How stable are they to stand up and cast lures all day?
715204
Follow Up By: Member - Julio C (VIC) - Wednesday, Jan 26, 2011 at 20:24
do they need some special kind of bracket to fit rod holders or fish finders?
715206
Follow Up By: Member - Myles F (QLD) - Wednesday, Jan 26, 2011 at 20:40
Surprisingly stable. The floor flexes a bit, but it’s meant to. I currently have four boats – one is a similar sized tinny. I find the portabote more stable at rest for casting. It does have some unusual characteristics but you get to understand them and realize they’re designed that way. You will also find it easier to negotiate trees and submerged branches.
Myles.
715209
Follow Up By: Member - Myles F (QLD) - Wednesday, Jan 26, 2011 at 20:47
Yep, that’s a problem. For rod holders you will probably have to modify with some sort of clamping system. I had (gave to a mate) a fish finder that ran on batteries and had a suctioned cup transducer. I’ll probably get another one.
Myles.
715210
Follow Up By: Member - Julio C (VIC) - Wednesday, Jan 26, 2011 at 20:57
Thanks...very useful info.......Cheers
715212
Follow Up By: Member - Myles F (QLD) - Wednesday, Jan 26, 2011 at 21:07
You’re welcome. Just another thought… there are oar lock sockets that could easily be utilized for rod holders.
715214
Reply By: Madfisher - Wednesday, Jan 26, 2011 at 20:07
I looked at buying one but balked when I found out dear they are. Ended up buying a big canadian with a 1m beam 2nd hand for $500 and a 4.2 Quintrex explorer for not a hell of a lot more.
Cheers Pete
443150
Follow Up By: Member - IdahOz - Thursday, Jan 27, 2011 at 16:42
any info on brand name etc so i can google it? thanks
715274
Follow Up By: Madfisher - Thursday, Jan 27, 2011 at 19:11
I guess you mean the canoe Australis if memory serves me correct, and the tinnie is a Quintrex, but it is a trailer job, but their are heaps of tinnies around 2nd hand for $500 to $1000 as against $3000(and that was about 5 years ago)
Cheers Pete
715290
Reply By: silkwood - Thursday, Jan 27, 2011 at 07:42
I've had
mine for about three years. Putting the basics together is quick, but adding all the bits and pieces can take a while.
Mine is in my lounge at the moment as I'm tidying up a few add-ons. I have made a wooden bow plate which holds the extinguisher, roller for the anchor rope, anchor reel (I made this from a cheap hose reel) and various s/steel attachements for ropes etc. I'm also making seats from kayak seats and a padded base, as
well as modifying
my home made
wheels (the standard
wheels are useless in soft ground).
If you go down the path of modifying, just make sure it is simple to add or remove. The more bits you have to put together the less keen you are to put it up for a quick run. Many things for normal boats need modifications for the Porta Bote. I use a rod holder which clamps onto the transom.
Overall a great product. 12 footer will go in most
places, including bays and calm offshore conditions. It actually handles a swell very
well, better than comparable size tinnies I've been in. Just takes a while to get used to the fact it is supposed to flex and twist!
Mark
443175
Follow Up By: Member - IdahOz - Thursday, Jan 27, 2011 at 16:41
love to see a pic of yours with mods
715273
Follow Up By: Pete Jackman (SA) - Friday, Jan 28, 2011 at 14:14
Ditto, especially the bow plate.
Pete
Another happy PB owner
715376
Follow Up By: silkwood - Wednesday, Feb 02, 2011 at 20:31
Sorry, people, I've been working on some minor changes to my Bote and I've decided to redo the
wheels and bow plate. I changed the way I attach the bowplate but now there are more holes than swiss cheese! When I've finished the upgrades I'll post some pics.
I'd like to re-emphasise.. if doing mods make sure they are easy to fit. It's a little like putting up a tent, lots of features are great but the feeling fades if it takes an age to set up.
Mark
716027
Reply By: Member - Paul S (VIC) - Thursday, Jan 27, 2011 at 16:45
G'day Julio,
We have a slightly smaller model, 10' I think, and holds 3 people. Our 5hp 4 stroke Honda comfortably brings it up to plane with 2 average bodies on board...struggles a tad with 3.
The hull is easy to transport on top of the camper or lux roof, although the seats are quite bulky being hollow plastic (good bouyancy but); they actually take up more room than the motor.
If you've got the room to cart it all, it's certainy easier than lifting a tinny on & off the roof......very tough too; I'd recommend it.
Paul
443214
Follow Up By: Member - Duke (TAS) - Thursday, Jan 27, 2011 at 22:10
I have owned a 12ft PortaBote for 3 years and love it. If you want to check out some modifications Google PortaBote
Forum and it will bring up an American
Forum. Man do they know how to go overboard with Mods.
Duke
715312
Reply By: Pete Jackman (SA) - Friday, Jan 28, 2011 at 14:34
Wow there are a few PB owners on here.
We have had a 10' one for a few years with a 8 HP Yamaha now. We picked it up second hand from an add in a local
Canberra paper for $3,000 with all the accessories and a motor - don't bother with the Bimini, but the other bits are OK.
Very stable and easy to launch. You can plonk one in anywhere you can walk to the
water. They are very tough as
well and quieter on the
water than a tinny, especially in a chop. With the 8 HP they get up and plane without a problem.
On the roof of the jack - hull and seats:
On the Murray with the original 2.5 Mercury:
Pete
443326
Follow Up By: Member - Paul S (VIC) - Friday, Jan 28, 2011 at 15:58
I don't mean to sound like the 'Fun Police' Peter, but you should check to see what size motor is allowed in SA.
We have the same boat in VIC and were advised it can be fitted with a max of 5hp.
Paul
715391
Follow Up By: Pete Jackman (SA) - Friday, Jan 28, 2011 at 16:38
Specifications in the manual say max 25.5kg for the motor.
All power boats in SA must be registered and this one is.
Because it lacked a Boat Code (like a maritime VIN) it had to be inspected before registration and they approved the motor then.
Pete
715394
