GU Patrol TD42. To Turbo or not to turbo
Submitted: Monday, Jan 31, 2011 at 17:11
ThreadID: 84024 Views:11565 Replies:5 FollowUps:1
Hi everyone. I have had a 1999 GU 4.2 diesel naturally aspirated wagon for over 9 years and whilst I still love the ole girl, I get so frustrated with the lack of power when towing or overtaking.
There's nothing like white knuckle fever every time I want to pass a road train or another van.
I have heard soooo many people have good and bad things to say about after market turbo charging that ranges from fantastic experience through to highly disappointed. This, of course, has made me very cautious.
My bus still runs sweet at 170 000km but I really wonder sometimes if iturboing is the right thing to do or just enjoy it as it is whilst showing a bit more patience!!
Realistic reponses from members with first hand experience will be valued.
Reply By: member - mazcan - Monday, Jan 31, 2011 at 17:36
hi jimbo
i would suggest you may find this article of interest thread 83987
as
there is imfo in it relating to a 4.2 nissan patrol that has been supercharged with the owner being very happy about its towing performance
AnswerID: 443687
Reply By: Dave(NSW) - Monday, Jan 31, 2011 at 18:35
If you check on here http://www.patrol4x4.com
GU/GR section in the sticky TD4.2 Engine failure you will see what can happen.
Cheers Dave.
GU RULES!!
AnswerID: 443695
Reply By: Member - Duncs - Tuesday, Feb 01, 2011 at 15:13
My GQ had an aftermarket turbo fitted at 80,000km by the previous owner. It was quite early in the scheme of things 1990 I think. It was actually used by Safari snorkels in the development of their GU kit.
The car was fantastic. I sold it with 385,000km on the clock an no problems with the engine. A couple of other things were a bit tired but the engine was fine.
I have only ever once driven a GQ TD42 without a turbo once and I was amazed at how slow it was.
Duncs
AnswerID: 443814
Reply By: kiwicol - Tuesday, Feb 01, 2011 at 19:59
Hi Jimbo,
I have a 92 4.2 diesel patrol, had the same problems as you, tried extractors, bigger exhaust, and oil filters, they all helped to a small degree, but not what i was looking for. I tried a few patols which were turboed, but still was not happy with what they put out. I then tried a supercharged of road racing patrol and it offered exactly what i was looking for.
The tourge that is on offer is what a 4x4 really needs, at idle i am getting 8psi, and then that goes right through the revs , but starts to petter out after about 3200 revs unlike a turbo which keeps on winding up. Towing and slow driving in the bush is were this set up comes into its own. Out of this i have also lost the chatter at low revs, common to the 4.2.
Around town i can stay in fith and go right down to 900 revs and put the foot down and she pulls away no problems.
I get about 12ks/100 around town and about 14 towing the camper.
The S/C runs its own oil so i can service it when needed.
I also still have the extractors and bigger exhaust and foam filters.
This set up has done close to 300,000ks trouble free.
Two downfalls, more expensive to set up, and the fan is 20mm closer to the radiator, which can be aproblem when crossing deep water, but i have had no problems there, and have had water crossings going over the bonnet and no blind.
My opinion its worth while looking into if you intend to keep the wagon.
The S/C is the same unit fitted to the early commodoers.
Hope this helps
Cheers Col
AnswerID: 443847
Reply By: Jimbo - Tuesday, Feb 01, 2011 at 20:49
Thanks everyone so far for your input. The patrol forums horror stories still left me uncertain whether to take the turbo step for more power.
Do the engines in the non turbo patrols in the GU differ at all from the GQ??
Does the GU turbo engine have different pistons, larger gudgeons, con rods etc despite the modest increase in power the vehicle gains?
The Super charger option sounds good especially due to lower heat build up but I agree is quite costly.
Getting back to the turbo option, I have also read that over fuelling as well as under fuelling a diesel when turbocharging will both increase engine temp to unacceptable levels and is the main culprit for GU turbo charging catastrophes. Does anyone have thoughts on this?
AnswerID: 443853
Follow Up By: Member - John - Wednesday, Feb 02, 2011 at 14:49
Over fueling any turbo diesel will harm it, if you do decide to turbo it, and there are a hell of a lot more happy turbo people than unhappy, fit an EGT gauge and drive by that, it will tell you when you are over fuelling and you can back off as required. An EGT gauge should be standard on every turbo diesel. Just My two cents worth.......
John and Jan
FollowupID: 715984
