Hot water for showers
Submitted: Wednesday, Feb 09, 2011 at 11:55
LOCKER
Hi Guys,
Looking at getting some sort of shower system together for the camper. Is the coleman or companion hot
water on demand systems worth looking at ? Whats everyone using any feed back would be appreciated
Hope everyone is surviving this crazy weather, makes planning trips around the country a little difficult if you are trying to stay to a timetable.
Reply By: tg123 - Wednesday, Feb 09, 2011 at 12:07
Boil approx 1.5L
water on your stove/ cooker, add to approx 4L cold
water = enough for a good shower at around 39 deg C - deliver the
water via pump in bucket, gravity feed bag etc etc. I've appliedthe KISS principle to a lot of my
camping gear and have learned that lots of fancy gizmos often turn out to be a PITA!!
TG
444755
Follow Up By: racinrob - Friday, Feb 25, 2011 at 20:58
TG, I agree with all you say, I've done a lot of remote area travelling over a lot of years with all sorts of pumps and heat exchangers and am now back to basics , a shower bucket and heat the
water over a fire or on the stove, works for me.
Rob.
718964
Reply By: LOCKER - Wednesday, Feb 09, 2011 at 12:22
I used to keep things simply prior to kids, was trying to come up with something to allow the family ( kids aged 2 and 4 ) to have a shower without setting up the camper or getting much gear out. Plug and play so to speak.
On trips when we are trying to cover big distances we were intending to stop give the kids a shower and then stick them back in the truck and continue as the kids just go to sleep. Most peaceful time to travel.
Have used the bucket and pump method in the past but didn't have much luck with finding a good pump that survive more than a couple of trips. Anyone know of a good robust pump that doesnt flow too fast?
444756
Follow Up By: kev.h - Wednesday, Feb 09, 2011 at 18:37
I use a small Johnson bilge pump cost about $25 have had it for years they are about the same flow as the 12v shower type but last 10 times as long.
I also have a Whale in line pump which is small enough to fit through
the neck of a plastic jerry can very handy about $50/60
Would recommend both as good replacement for the 12v shower pumps
Cheers Kev
716927
Follow Up By: Member - Christopher P (NSW) - Wednesday, Feb 09, 2011 at 20:26
the BCF or primus has a shower with an adjsutable flow rate.
also get a big tray to catch the
water to reuse and save.
KISS principle. portable shower, battery and tray. heat the
water on a stove. hot as you want!!!
716948
Reply By: Member - Craig F (WA) - Wednesday, Feb 09, 2011 at 13:01
Hi Locker,
I also have two
young children and had the same issue with the 12v portable showers.
I have set up a 12v pump (pressure activated) in my van. (pic attached) I have since added a 12v switch to turn on and off from the ensuite tent and a valve on the pump to restrict
water volume. I attach the hoses with garden hose fittings. I draw
water from a 25l
water container that can be filled via my colman HWS or tap at the caravan
park.
regards CraigImage Could Not Be Found
444761
Reply By: Eli J - Wednesday, Feb 09, 2011 at 13:35
I use the coleman instant hot
water system. As the standard shower head is pretty crap i went and bought a $25 shower head and pump from BCF. Heaps better spray than coleman one. I pretty much just take a 15L clean paint drum, fill it with
water, throw the coleman pump in the bucket as
well as the return shower head of the coleman and just recycle the
water until reached desired heat. It doesnt take that long, far less than boiling a jug. Once desired heat is reached i just use the Bcf shower to wash. Its amazing how little
water you use when you dont have it running out of a tap.
We have great showers when
bush camping, and is hassle free. Depending on where i go, sometime i even take one of those plastic
bins (old style
bins) and use it as a
water tank, so if it is a trek to get
water i just fill that sucker, and leave it outside shower tent to fill smaller bucket from.
If you dont want to spend the $$ on a coleman then get the BCF pump and just boil
water, either way you will feel great after it.
444764
Reply By: Eli J - Wednesday, Feb 09, 2011 at 13:37
bins (old style
444766
Reply By: Member - John and Val - Wednesday, Feb 09, 2011 at 14:38
Locker,
This topic has been covered a couple of weeks ago, Thread number 83914
here
Our preference is for the simple system of 12v pump in a bucket of
water heated on the gas or over the fire. Works for us.
Val
| J and V
- Albert Einstein
444771
Follow Up By: chris han - Wednesday, Feb 09, 2011 at 21:57
yes guys,, the bucket with a 12V bilge pump connected to the hand held shower.. with a simple shower tent ( like the "throw-up ones" ) is a nice cheap solution.
I did buy a shower heat-exchanger for about $120 many years ago ( Glint brad I think !) and it has been in 3 diffreernt vehicles. currently in the shed, but will mountit in my Nissan Patrol before the next trip... very useful to get plenty of hot
water, especially after you have just pulled up... plenty of hot
water at idle speed
.. just throw the pump in the
creek, or in a bucket !!
716972
Reply By: sweetwill - Wednesday, Feb 09, 2011 at 16:27
G/day locker.
don't forget the huggies baby wipes, or wet ones, i never leave home without them they do the trick when
water is scarce cheers bill.
444781
Reply By: higgos - Friday, Feb 11, 2011 at 01:50
check before you buy if replacement parts are available. My coleman hws system is useless because Coleman told me they do not supply replace parts
445014
Reply By: Member - Michael & Jill - Friday, Feb 25, 2011 at 07:21
G'day Locker,
I made a hot & cold
water system for my
camp trailer last year which gives me hot & cold
water to my kitchen & my shower. I'm now making more of these for people that have seen my system. All that is required to run this system is 12v power supply
water supply & gas supply & you can have instant hot
water up to 70 deg. If your interested I will give you the full details.
Regards, Michael.
446507
Follow Up By: katepaul - Monday, Feb 28, 2011 at 16:06
Michael & Jill
I would love to know more about your systemfor hot and cold h2o can you contact me with details paulkatie@optusnet.com.au
thanks kate
719238
