50A andersen plugs hard to push together and pull apart
Submitted: Sunday, Feb 13, 2011 at 16:57
ThreadID: 84322 Views:7086 Replies:4 FollowUps:12
Related Pages
I have been using 50 amp andersen plugs, but they seem very hard to push together and pull apart. They seem to be foolproof when putting them together, and i dont think i have assembled them incorrectly. Any suggestions on what I my have done wrong ...or could do to make them easier to use??.
Thanks Kc
Reply By: Member - Andrew (QLD) - Sunday, Feb 13, 2011 at 17:29
One of the tradeoffs for a good contact with lower resistance is that they will take more force to disconnect ;) The genuine version has a Contact Retention Force of the equivalent of approximately 23kg. There are (red) handles you can buy as an extra that will assist with the process of joining/unjoining.
One thing to make sure is that the contact is fully inserted to the point where it clips over the little retainer/spring. Insulation from the cable can stop this happening and may stop the 2 sides connecting correctly.
Hope that helps,
Andrew
AnswerID: 445306
Follow Up By: Member - Andrew (QLD) - Sunday, Feb 13, 2011 at 17:34
I should add that the connection/disconnect force is around 10-15lbf, not too much.
FollowupID: 717567
Follow Up By: kcandco - Sunday, Feb 13, 2011 at 17:36
Hi Andrew
When pushing the terminals in, there was a click as they went in, and the groove in the terminal sits nicely against the metal flap.... so all that looks good. 23 kilos force is probably about what is needed. My Brother in law had the same size on his van (already fitted) and he said they were not difficult to push and pull apart. Maybe his were not a good fit. I think i will look into the handles for assistance. Thanks for your help.
Thanks Kc
FollowupID: 717569
Reply By: ABR - SIDEWINDER - Sunday, Feb 13, 2011 at 17:32
Hi KC
Use some Dielectric Grease on the plugs if needed, it is a very good product for this application.
If you have crimped and deformed the lugs they can be a bit stiff. Here is a picture of how they should be inserted into the housing.
Derek from ABR
AnswerID: 445307
Follow Up By: kcandco - Sunday, Feb 13, 2011 at 17:40
Thanks Derek
This is exactly as i have installed them and I have not deformed the terminals and the cable is not interfering in any way. Will Dielectric Grease make it easier to pull apart and push together?
Thanks Kc
FollowupID: 717570
Follow Up By: Member - Graham H (QLD) - Sunday, Feb 13, 2011 at 17:43
Sometimes they get corrosion on them and make them hard to pull apart
I have two screwed one above the other and have bought one of the T handles from Derek which makes them much easier to pull apart
A good clean may help if they look a bit greenish
FollowupID: 717571
Follow Up By: kcandco - Sunday, Feb 13, 2011 at 17:47
Hi Graham
Thanks. These are brand new plugs. Looks like I will get handles to assist.
regards Kc
FollowupID: 717572
Follow Up By: ABR - SIDEWINDER - Sunday, Feb 13, 2011 at 17:49
Yes it works wonders, I saw an old guy battling with plugs one day and all I had on me was lip-ice, I took a stick and placed some on the contacts and flat surfaces of the housing of just one plug and the plugs snapped together with very little force.
He was very grateful, I told him that grease attracts dust do he must keep them clean.
FollowupID: 717574
Follow Up By: V8 Troopie - Monday, Feb 14, 2011 at 02:13
Just out of curiosity I googled 'dielectric grease' http://www.wisegeek.com/what-is-dielectric-grease.htm
It is an *insulating* grease, not exactly the stuff I would want to put on conducting surfaces.
There are conducting greases available, I use 'Alminox' for such an application.
FollowupID: 717629
Follow Up By: ABR - SIDEWINDER - Monday, Feb 14, 2011 at 08:18
I know it is safe on rubber and plastic and works well.
"Dielectric Grease is a silicone dielectric compound used to insulate, lubricate and protect electrical fittings. It protects against salt, dirt, moisture intrusion and stray current in electrical connections.
Dielectric grease extends bulb and housing life of navigation lights, masthead electrical connections, trailer lighting and harness or any electric connections exposed to moisture and the elements. Prevents voltage leakage around any electrical connector thereby insuring a strong spark in high energy engine ignition systems."
I am not sure I want the conductive type in a sand filled wet Anderson plug, trailer plug etc.
I can only recommend what I have used in the past with good results.
Derek
FollowupID: 717637
Follow Up By: wayne b2 - Monday, Feb 14, 2011 at 08:21
I have sprayed Lanotec inside the Andersen plugs, works well.
When not in use I have a zip lock plastic bag over them then used a cable tie to close the bag off, Hope this helps.
FollowupID: 717638
Follow Up By: ABR - SIDEWINDER - Monday, Feb 14, 2011 at 08:32
Hi V8
I just had a look at alminox and I would not recommend it at all. It is for component assembly. It is also petroleum based which will damage the plug housings.
"ALMINOX
Recommended for aluminium to aluminium bolted or
compression connections. Alminox contains sharp,
conductive zinc granules suspended in a viscous petroleum
base. Under pressure these granules make high pressure
contact points with the parent metal to effect a sound
electrical connection, whilst the base material seals the joint
to prevent further corrosion. Catalogue number ALM325G,
supplied in 325g squeeze tubes"
Derek
FollowupID: 717640
Follow Up By: Racey - Monday, Feb 14, 2011 at 09:02
For lubrication of the contacts good old vaselene is hard to beat. In a past like we used it to lubricate the drum controllers on DC electric cranes.
Racey
FollowupID: 717641
Follow Up By: Member - Bruce Y (Vic) - Monday, Feb 14, 2011 at 10:57
I'm in full agreement with Racey, I did my Sparky apprenticeship in the early seventies and part of our toolkit was Vaselene for used for any contacts that had to slide against each other. But I would advise just a light smear as too much would probably collect dust on your travels.
FollowupID: 717651
Reply By: landseka - Monday, Feb 14, 2011 at 10:53
What about a spray of good old CRC , WD40 or such like when assembling. Won't corrode terminals or attract dust.
Cheers Neil
AnswerID: 445388
Reply By: Mike DiD - Monday, Feb 14, 2011 at 23:33
Anderson make two types pf contacts for the SB50
High detent - 15 lbs
Low detent - 10 lbs
If you have clones it could be anything
AnswerID: 445470
