Polyair bag claim procedures?
Submitted: Tuesday, Nov 11, 2003 at 09:28
JohnR
Folks have read the comments on here since Sunday when I had a Polyair bag blow with the sound of a gunshot. Nice 3" split in it. So the GU tray topper came home lopsided with the
camp box on on top. Pressures were 26-27 psi
There is recognition given elsewhere to heat and heat shielding, but can't see any installed.
I have neen told I will have to buy a new bag and the other will be sent for testing and I should be reimbursed. I am wondering if others have been faced with this procedure for a warranty claim.
I will put the bags back inside new TJM heavy duty 50mm extended springs too. The local workshop has done about 30 sets of spring replacements and only 2 have the extended shockers Truckster talks of.
Reply By: Member - Tim&jan - Tuesday, Nov 11, 2003 at 18:48
was thinkin of puttin the polyair bags on my patrol ute i belive they make 2 types a general and a heavy duty onegu bush basha
36889
Follow Up By: JohnR - Wednesday, Nov 12, 2003 at 10:08
Tim & Jan, They have been great but have the feeling this one must have heated. Is on a GU ute and the exhaust must be too close or something. Is a 4.2 intercooled current model.
In other sections of the
forum there are comments on shielding in a Pajero of the exhaust. I was travelling at 100kph in Brackstate on a made highway so should not have overheated I would have thought.
As stated below will go with heavier coils from now too and adjustables in the form of bags at lower pressure and some form of shielding too possibly.
I have seen on another site that Queensland will be barring height adjustment while travelling, meaning in cabin air adjustment stopped, also some forms of extended lift stopped too.
26739
Follow Up By: Member - Tim&jan - Wednesday, Nov 12, 2003 at 17:58
it dosent sound like a heat problem ?was it cracked or cracking from heat or was it because the manafactuer made it thin on one side ive seen this lots in rubber products,tyer tubes especialy.gu bush basha
26772
Reply By: Pappas - Tuesday, Nov 11, 2003 at 21:29
I Think the maximum you should inflate them is 25 psi.
36918
Follow Up By: JohnR - Tuesday, Nov 11, 2003 at 22:26
Some run them at 30 psi, indeed a friend went to
Cape York at that this year. The friends heard at Mt Isa mines they tend to throw them out at 2 years at 50 psi.
This one actually seems thin in
the spot by the tear/cut so I guess the heat of the exhaust may have allowed the stretching so it opened up three inches or so with a real bang!
26701
Follow Up By: joc45 - Wednesday, Nov 12, 2003 at 00:17
My doco says 30psi max, 4psi min.
No probs in 10yrs on a GQ, 3 yrs on a GU
Gerry
26717
