Patrol 4.2ltr or 3ltr diesel
Submitted: Thursday, Feb 17, 2011 at 12:59
ThreadID: 84427 Views:6275 Replies:13 FollowUps:22
Hi Folks. I have a question. I currently own a Patrol DX 4.2ltr diesel (no turbo) and tow from time to time my 21tf Van which has an ATM of 3000kgs. Probably really weighs max when loaded about 2800 - 2900kgs. I am thinking of upgrading to the latest Patrol with a 3ltr diesel, with turbo and putting a power chip in it. I know my economy without towing around town will be better, and I feel I will have more power when I am towing when I hit the hills. By the way, my current Patrol is running fine, just dies on inclines. I have owned it for 10 years. Any thoughts ? Is it a good move ? Cheers Bob.
Reply By: Member - John - Thursday, Feb 17, 2011 at 13:09
Bob, in my opinion, you would be much better off to turbo and maybe intercool the 4.2. You know the vehicle, probably have it set up to suit your self and will probably be much cheaper to turbo than change over.....
John and Jan
AnswerID: 445769
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 13:14
yep John I have looked at that also and it still is an option for me. But I may update the whole vehicle and run with that for the next 10 years, like I have this one. I know it gets back to dollars, but I am thinking down the track and updating. The next model of patrol will be out of the question as I think they will be really expensive. Chhers, Bob.
FollowupID: 718075
Reply By: Member - Jan B (VIC) - Thursday, Feb 17, 2011 at 13:13
Hi bobldo, my suggestion would be to keep the old war horse 4.2 add an after market turbo plus a 3 inch exhaust and a pyrometer. I have a old 98 4.2 and still going fine now i put these items on, oh yes it helps buy changing gear earlier going up hills when towing, i tow a kimberly trackmaster van and have no problems. my old girl has 334,000 on it and still goes fine,hope it helps.
cheers Jan and pete
AnswerID: 445771
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 13:17
Thanks for the advice Jan B. how long have you had the turbo on etc. How many K's have you done since the upgrade.
Cheers, Bob
FollowupID: 718076
Follow Up By: Member - Jan B (VIC) - Thursday, Feb 17, 2011 at 13:25
Hi Bob, we put the turbo kit with exhaust on around about 175,000 and my mechanic believes the old girl will keep going for at least another 200,000 plus if i do all the right things, oh yes we also put airbags on for towing they help as well.
cheers jan and pete
FollowupID: 718080
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 13:42
Cheers Jan, geez mate that is good news. I had a suspnesion upgrade a while back and the van and patrol sit perfect when hooked up. I also have a WDH as well. regards, Bob.
FollowupID: 718082
Reply By: Member - peter h (SA) - Thursday, Feb 17, 2011 at 13:17
Hi Bob
I have a 4.2 with a turbo and intercooler fitted and i tow a 23.5 ft caravan no problems . It is also alot heavier than your van. We get somewhere between 6 to 7 .5 kms per l. With the intercooler added has stopped the gear changing all the time. This changes to my 4.2 was a lot cheaper than change over and i know about my car
AnswerID: 445772
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 13:20
Hi Peter - that consumption - is that what you get when towing ? Cheers, Bob.
FollowupID: 718077
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 14:11
Hi Pete - who did your upgrade ? - I assume it was in SA. I know of Cross Country 4 x 4 and Alltrac 4WD - both have been around a while.
FollowupID: 718088
Follow Up By: Member - peter h (SA) - Thursday, Feb 17, 2011 at 17:13
yes these figures are towing i keep records of every fill up. I only tow at 85 to 90 kms this keeps the revs at 2200 -2300 rpm in 4th gear. Cross country have added the intercooler and altered the fuel pump.
FollowupID: 718120
Reply By: Member - Graham H (QLD) - Thursday, Feb 17, 2011 at 13:36
My experience with a 3.0 Patrol was that it was at least 1 gear worse than the Cruiser and my van wasnt as heavy as yours.
How bad does it die on hills After all on holiday its not how fast you get there its how much you see on the way..
AnswerID: 445777
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 13:48
Hey Graham. To be honest I am never in a hurry. The longer it takes the better when the van is hooked up. Ha Ha! You know what its like after driving one for a while and with the van on I just wouldn't mind a bit more grunt. Sure up a decent incline, I have to drop back to 3rd, sometimes second if its something like our Willunga Hill in SA (4kms long incline and fairly steep) regards, Bob.
FollowupID: 718084
Follow Up By: Member - Graham H (QLD) - Thursday, Feb 17, 2011 at 14:08
Thats Ok I was in 3rd last time up there and EGT was getting up over 500deg as well last January 2010
FollowupID: 718087
Reply By: Madfisher - Thursday, Feb 17, 2011 at 13:46
Mate I dont own a patrol, but I do know you presently own one of the most durable motors in a 4wd, and you want to swap it for one that has a very bad history?. Unless your present vehicle has over 500000ks stick with it.
Good luck Pete
AnswerID: 445780
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 13:53
Cheers Madfisher, copy that - thats what my darling wife is telling me. The 4.2 has never missed a beat. The old wagon is looking at me with that "don't sell me" expression on its face !! regards, Bob.
FollowupID: 718086
Reply By: bobldo - Thursday, Feb 17, 2011 at 14:07
Cheers folks folks for your input. Its seems overwhelming that I stick with the 4.2, and get an upgrade with a turbo/exhasut/EGT - thanks again, Bob.
AnswerID: 445784
Reply By: Wilko - Thursday, Feb 17, 2011 at 14:23
Hi Bob,
Stick with the 4.2 over the 3lt. But have you considered a 6.7 Chev replacement. Not sure of the costs or ins and outs but I'm told they can give better fuel economy ( If driven correctly) then the turboed intercooled 4.2 with more power to boot when needed.
Cheers Wilko
AnswerID: 445789
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 14:27
Hi Wilko, yes I did enquire a little while back about the 6.7chev diesel. If I remeber correctly its about $20K + with all the mods, gearing done etc. Didn't pursue it any further. Cheers, Bob.
FollowupID: 718094
Reply By: Robin Miller - Thursday, Feb 17, 2011 at 14:50
Only you can know your whole senario Bob, for me I thought it was time to get in before chassis like the GU's become obsolete, but I need real reliability
and performance and got the 2010 Petrol so everything is new and tight and quiet from the belts to the brakes, power steering hoses and radiator etc.
Reliability means different things to different people, their is no way I could accept the brakes on the diesel patrols (and I don't tow) and the lack of performance I find dangerous.
Let alone driving a car these days short on airbags.
With new Patrols at sub $50,000 they are a steal but you would have to get the manual 3lt to get your bowser economy, or gas up a petrol.
However cost of ownership, not just bowser fuel price, is a different equation.
My mates 3lt hung out for 195,000km towing 3 ton but I believe my existing manual petrol 4800, over its 8 year history has proved to be of equal or lower total life cycle cost than the 4.2 turbo diesel and a lot safer along the way.
AnswerID: 445792
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 15:07
Hi Robin, yes I understand. I did have previously the 1998 4.2 petrol Patrol. It was great tug. But it did get thrirsty. I also considered the 4.8ltr petrol, but again I think its a bit thirsty. I am not a lead foot, I am too old for that these days. However once I got a diesel, my preference has stayed that way. Hence my original thought of having a 3 ltr with a power chip - purely that little bit extra grunt for when I tow and only when needed for some xtra push up some hills, and the economy of the 3ltr around town etc when I do not tow. I also felt that the series 7 (i think it is now) would be a better 3 ltr than the first ones after all the dramas they had with turbos etc. I know what your saying, new car, new everything - that was orginally why I put up the post to hopefully here from some 3 ltr owners and there experiences with putting in a chip, towing etc with the recent model. There would be plenty out there. regards, Bob.
FollowupID: 718106
Follow Up By: Robin Miller - Thursday, Feb 17, 2011 at 15:33
They can be tricky decisions Bob, we had a 4.2turbo for a month but couldn't live with it and again this time tried out a 3lt extensively.
The manual version doesn't really need a chip as its tuned higher at 380nm of torque.
I accept the reports on them but there are more happy long term owners out there than some would like to believe, but I would stick to the extended warranty scheme.
A big influence on me was that my wife loved the 4800 auto and enjoys driving it.
We often do 1000+ km days and this was important.
Its got such quiet smooth power and grace that she doesn't care that its longer term quietly driven full use looks like about 17.5
FollowupID: 718110
Follow Up By: Member - Mark E (VIC) - Thursday, Feb 17, 2011 at 23:46
...the lack of performance I find dangerous. ...."
Whilst I agree with much of what you comment on Robin, you had me giggling at that one.
I know it's a personal thing and lots to do with the way you drive, but I've been driving underpowered diesels for 29 years and I have never found a lack of power "dangerous". I simply drive the vehicle within it's limits, which are well known to me. Perhaps it is possible that the diesel vehicle may in some ways be 'safer' than the petrol variant? Slower, thus less temptation to try to outrun traffic, perhaps?? volatility of fuel issues, for when carrying jerry cans or in a collision situation???, more prone to underbody fires when in spinifex areas?? I could go on..
My next 4WD may well be a petrol for all the reasons you mention, but certainly not because I feel they are safer.
Mark
FollowupID: 718164
Follow Up By: Robin Miller - Friday, Feb 18, 2011 at 08:18
Hi Mark
We could translate your arguement into "I know someone who has owned a 3lt patrol forever without engine problems " or "I know someone who has smoked forever etc" , but their are many people who seriously drive to the situation , and like you do not have a problem.
Unfortunately over the long haul and a large population it doesn't work that way and drinking and driving is more dangerous wether or not someone made it home saftely via the back streets last night.
This is why we have airbags , despite most of us spending a good part of our driving lives without them - and will spend the rest of our driving lives hoping we never use them.
A good way to look at it is like this - when I'm out passing someone and underestimate the passing difference , well in my 4800 patrol I have options that a slow car simply doesn't have.
So many things are not what they seem when under real scrutiny , like your feeling the diesel may be a safter fuel.
The reality is otherwise - and its not from flammability its from oiliness.
I.E. a lot more accidents etc occur from "Oil spills on road" than are caused by car based fires caused by petrol.
FollowupID: 718172
Follow Up By: Peter Y - Saturday, Feb 19, 2011 at 11:13
"Oil spills on road"...what's that got to do with distillate?
Distillate is mildly 'oily'..but petrol on the road(dissolving tar) would be just as dangerous.
There are many on this forum who are tired of hearing your pragmatic and judgmental nonsense.
FollowupID: 718277
Follow Up By: Robin Miller - Sunday, Feb 20, 2011 at 09:02
Hi Peter
If you disagreee with someone you should try presenting an alternate arguement - difficult as that might be.
Do you really not know the significance of "Oil on Road"
Its a standard sign used for diesel spills in Vicroads here in Victoria, and its all to common particularly on truck routes.
Petrol evaporates quickly as is a significantly less of a problem.
If you have never had too drive thru , it comes as quite a shock and causes some serious accidents , equivalent to driving on black ice.
FollowupID: 718327
Reply By: Begaboy - Thursday, Feb 17, 2011 at 16:44
If you change your 4.2 for a 3 ltr - i will personally come to your house and scream at you ;)
AnswerID: 445800
Follow Up By: bobldo - Thursday, Feb 17, 2011 at 16:53
you're a very funny barsteward, Begaboy. Ha Ha !!!!
FollowupID: 718117
Reply By: Member - Mark E (VIC) - Thursday, Feb 17, 2011 at 23:58
This is my 02 worth.....
Vehicles all WEAR OUT. Yes your trusty 4.2 engine may last for 199999999999k km but think about the viability of the rest of the car.
Gearboxes, transfer cases, diffs, bearings of all sorts wear out. Even simple things like door hinges, door locks, electrical components, internal fittings, seats etc...ALL wear out.
I'm not a huge fan of electronics in modern 4WD vehicles, but I think I am going to have to accept them to some extent fairly soon, as it seems as if it's the way of the future.
I have last interest in trying to keep old clunkers on the road as I no longer have the interest to continually tinker and repair things that break. I accept a degree of accelerated wear on 4WD vehicles, given their intended usage and I do some mechanical things myself, but I don't really enjoy it. I'd rather be out touring somewhere.
I have the N/A 4.2 Toyota version of your engine and it is also underpowered for the vehicle, given the accessories I have bolted on and some towing duties. I have also contemplated a raft of "power-up" options, such as turbo/intercoolers etc and even engine swaps to something more powerful. But at the end of the day, the $$ that would need to be invested in the car to achieve a reliable result (reliable enough for extended outback touring) outweigh the value of the car, given its probable service life (to me). So I stick with the lack of power, promising myself to get a bit more when I upgrade to the next car.
If you can afford it....get the newer car with more power. You'll be happier in the end.
The earlier Patrols were plagued with ZD30 blowup-itis, but I am fairly certain the newer variants are more reliable.
Cheers and good luck deciding.
Mark
AnswerID: 445831
Follow Up By: muzzgit - Friday, Feb 18, 2011 at 01:35
I vote the 3.0 patrol but yes get the manual version. My second choice would be the 100 series TD.
FollowupID: 718166
Follow Up By: Member - Graham H (QLD) - Saturday, Feb 19, 2011 at 11:34
Had a 3.0 Patrol Upgraded to a 100 ser TD.
There is no comparison about how much better it is than the Patrol.
In all ways, comfort, power, towing ability Everything.
FollowupID: 718279
Reply By: bobldo - Friday, Feb 18, 2011 at 09:08
Cheers folks. I will do a bit more research, on both upgrading the current model and looking at putting a chip into the new 3ltr model. I did ring country 4x4 and they said a chip would increase the killa wasps from 118 to 136 - interesting. an ehaust upgrade would also help. cheers, Bob.
AnswerID: 445848
Reply By: Member - Captain (WA) - Friday, Feb 18, 2011 at 11:38
Putting aside the 4.2 vs 3.0 reliability discussion, there is the saftey aspect to consider. Older vehicles do not have ABS or airbags while newer ones do. Once you have had a family member saved by these devices you will never buy a vehicle again without them.
Just my 2c worth.
Captain
AnswerID: 445867
Follow Up By: bobldo - Friday, Feb 18, 2011 at 12:09
Cheers Captain. My DX has 2 x air bags (steering wheel and above glove box) But you are right the new ST would have more. regards, Bob.
FollowupID: 718183
Follow Up By: bobldo - Friday, Feb 18, 2011 at 12:10
Captain..woops ... I think its drivers side only. cheers, Bob.
FollowupID: 718184
Reply By: 4wdr - Monday, Feb 21, 2011 at 23:53
If you want to get from a to b every time,stick with the 4.2...had an03 with zd30,self destructed,long story short 03 now has a trusty 4.2.
AnswerID: 446224
