2004 Hilux - what to look for
Submitted: Wednesday, Feb 23, 2011 at 14:49
ThreadID: 84563 Views:4713 Replies:3 FollowUps:9
G'day. I'm hoping to get a 2004 dual cab 3 litre turbo diesel 4x4 Hilux and am looking at one with 200,000km on the clock. Could the Hilux experts please let me know what sort of specific things I need to keep a watch for in this model at this km in terms of engine and drive train.
Thanks for the help. poitr
Reply By: River Swaggie - Wednesday, Feb 23, 2011 at 14:59
To be honest i cant think of much.Make sure the belt has been changed (cannot think of the name bugger it,its like a cam chain but belt)...Sure it comes on around 150k.
Change oil and filter every 5k..I use Penrite 15w-50 Synthetic.
Fuel pump every 10k and air cleaner depending how much bush driving u do,If alot do it when needed.Check after every trip if dusty..
Dont blow it out with air if really bad,replace it.
Here is some stuff i have done in my Hilux..
You will love it.
Picaso Pics
Youtube
Pano Pics
AnswerID: 446375
Follow Up By: poitr - Wednesday, Feb 23, 2011 at 15:10
Think I get the drift of why you are "River Swaggie". Greta sequence floating down the river!!
Poitr
FollowupID: 718724
Follow Up By: Baz&Pud (Tassie) - Wednesday, Feb 23, 2011 at 16:44
Me thinks River Swaggie might be thinking of the timing belt.
Baz
FollowupID: 718728
Follow Up By: River Swaggie - Wednesday, Feb 23, 2011 at 17:20
Thats the one Baz (cheers,Mental block lol)..
Poitr
I use Mickey Thompson MTZ's on 31's on original rim's..They have taken me everywhere i needed to go.
If you are going to take it 4wdriving through rivers etc.The first thing i would do is sort out diff breathers (Piranha sell them).Dont forget your transfer case as well as the diffs.The original ones that will be on it are of poor quality and dont trust them.
Secondly i would get a snorkel (I hav Safari and are very happy quality wise).The air filter has a rubber grommit in it,remove and silicone it up.
Sort out your own recovery gear,ARB have a nice bag,well the contents are great the actual bag is crap quality.
If you want some info ask anytime at riverswaggie at gmail dot com
P.S Yeah if i had the the Kaymar Rear Bar then i wouldnt have floated..
Goodluck
FollowupID: 718729
Follow Up By: TerraFirma - Wednesday, Feb 23, 2011 at 20:08
River Swaggie is on the money, timing belt at 150,000, service history and then get an independent test if you like. Low KM's well looked after and you should be fine.
FollowupID: 718756
Follow Up By: poitr - Thursday, Feb 24, 2011 at 09:57
Swaggie,
Realise this is pretty ignorant but I'm fairly new to this. What are the diff and transfer case breathers ? Are these complicated to replace?
Poitr
FollowupID: 718807
Follow Up By: River Swaggie - Thursday, Feb 24, 2011 at 17:03
Hiya Poitr
This will explain it better...On your diffs and transfer case Toyota have an end cap.To allow these parts too breath,now if you are crossing a river and they decide to breath they will suck water into the diffs etc etc,they are made very cheap with a bleep ty spring in them...What you do is put the lines up under your bonnet...
Its not hard,just use a screwdriver to lift the original caps off,The transfer case is harder between the floor and case..Now for the rear diff allow hose for travel,Suspension up and down...
Or get a mechanic to do the three..I used a T piece for front and transfer case connection.
Piranha
If i was to do mine again i would use these fancy ones
Billet Racing
Goodluck
FollowupID: 718841
Reply By: Member - John R (cQld) - Wednesday, Feb 23, 2011 at 21:40
See if you can find out whether there's been any rear wheel bearing seal problems. I'm on to the 4th set on the drivers side in only 60k. No problem other side.
Cheers, John
AnswerID: 446401
Follow Up By: poitr - Thursday, Feb 24, 2011 at 09:54
Thanks for the tip
Poitr
FollowupID: 718806
Reply By: Madfisher - Thursday, Feb 24, 2011 at 13:05
Check to see if injectors have been done. Usually due around 200000ks. If its a d4d that could be $4000.
Cheers Pete
AnswerID: 446435
Follow Up By: River Swaggie - Thursday, Feb 24, 2011 at 16:52
bleep e theres always a downside to new technology.
FollowupID: 718840
Follow Up By: poitr - Friday, Feb 25, 2011 at 08:25
Something to look forward to. I'll try to be prepared.
thanks guys
FollowupID: 718898
