Drive a new diesel HARD?
Submitted: Sunday, Feb 27, 2011 at 20:28
Member - Dave B1 (QLD)
A lot of people I've been talking to lately about my buying a new troopy (the one with the 60 cent discount - thanks for the replies) say to me "Mate drive it hard when ya get it, best thing for a diesel". I sort of gather that the 5 hour drive home should be at full throttle. I may be overdoing it a bit there but is there any truth in what they are saying about pushing a new diesel hard early? As I am not in the slightest way mechanical your thoughts appreciated. I am however a good
cook and the BIG yabbies I caught today are going down a treat.
Dave
Reply By: vk1dx - Sunday, Feb 27, 2011 at 21:01
I reckon what they say is rubbish.
446777
Reply By: Members Paul and Mel - Sunday, Feb 27, 2011 at 21:01
I do a mix of both,give it heaps but drive it sensibly. does that make sense?
446778
Reply By: TerraFirma - Sunday, Feb 27, 2011 at 21:02
Drive it hard is not the case although Diesels like to be worked. Earlier model diesels suffered from glazing if idled for long periods or not worked. Not sure it is an issue with more modern products, full throttle did someone say.? I wouldn't think so,,
446779
Reply By: Member - Chris & Debbie (QLD) - Sunday, Feb 27, 2011 at 21:36
Hi Dave
In my opinion yes, within reason of cause, as in any new vehicle/engine you do not want to baby it, but avoid high rpm no load, excessive labouring the engine or constant load/rpm.
Since you are doing a 5 hour drive you should avoid sitting on a constant speed, for example if you are sitting on 100km/h every so often drop back to 80km/hr then go full throttle and accelerate upto the 100km/hr.
After this initial run-in just drive as you normally would.
Chris
446782
Reply By: Member - Joe n Mel n kids (FNQ - Sunday, Feb 27, 2011 at 21:41
best all rounder for running in new deisels is to push them hard but for short periods of time, hold it flat to the floor and make it work on hills ect and then back it off for a few secs and then cruise as per normal, dont baby it...
Most important thing is DO NOT over rev it, keep the revs down as that is what kills any new engine............
446785
Reply By: Ruffy-Dan - Sunday, Feb 27, 2011 at 21:50
As with a internal combustion engine, most of the wear occurs before the engine reaches operating temperature. Accelerating to speed quickly decreases cold runnning time. I'm not saying rev the engine hard, but using extra throttle is a good thing.
Apart from that, as mentioned, don't over rev, don't over labour and try to avoid idle for extended periods.
DAN
446787
Reply By: Nutta - Sunday, Feb 27, 2011 at 23:25
I picked my 3.0l patrol up new 7 years ago and drove it straight to
melbourne and back, i was worried about possible engine damage but its never used oil and ive never put a spanner to any part of it, runs like a gem!
446802
Follow Up By: Nutta - Sunday, Feb 27, 2011 at 23:36
I suppose it might help if i mention i live on the
gold coast!
719168
Reply By: get outmore - Monday, Feb 28, 2011 at 02:14
might be a totally crazy idea
- but id read the owners manual
its in there
446807
Follow Up By: Rockape - Monday, Feb 28, 2011 at 07:11
Get outmore,
you is crazy, what would the maker of the engine know about it. LOL.
Have a good one
719187
Reply By: cycadcenter - Monday, Feb 28, 2011 at 04:47
I've always run them in with varyng load and throttle for the first couple of thousand kms then drop the oil and filters and
fuel filter incase there are any little greebles floating around from manufacture.
I would think that driving at full throttle with no load wouldn't be the best thing to do to a new Troopy.
Bruce
446808
Reply By: Wilko (Parkes NSW) - Monday, Feb 28, 2011 at 08:43
Hi Dave
I'd vary your speed and accelerate differently (hard to slower) to ensure the moving mechanical parts bed in correctly and don't over rev (exactly what others have replied)
Some of the farm utes around here only idle around the paddocks checking stock etc and that can glaze the
bore. They need to be driven a bit harder at time to ensure that it doesnt occur.
Cheers Wilko
446822
Reply By: guzzi - Monday, Feb 28, 2011 at 08:45
Dave,
Do an internet search on the toyota V8 diesel and oil usage.
It appears the engines that have been lightly loaded are suffering from excessive oil use and those that have been driven harder aren't, although this doesnt appear to be a hard and fast rule either.
Dont baby it, dont flog it, dont lug it around at low rpm, dont over rev it, vary load and speed for the first 500 to 1000km general city driving is good for this, accelerate up hills, dont sit at the one rpm range for long periods.
Diesels do like to be worked, but there is a difference between working hard and abuse, also full throttle in a V8 diesel will only see you donating money to the speed obsessed govt and little else.
Also as mentioned above read the owners manual and have a talk to the service department about what they recommend.
446823
Reply By: baza - Monday, Feb 28, 2011 at 16:24
A 'race' mechanic at a ride day (motorcycles) gave a few of us his take on the whole run in thing (the aim being to get max hp out of the engine).
He believes that the honing on the cylinder bores only last the first 50 Km or so. This means you have to load the engine up (once everything is up to temp) within this period to get the rings to
seat correctly, as the honing 'wears' the rings in. Sounds reasonable, but I'm not an expert.
The other thing he said was re the engine revs, we are talking high piston speed engines here, so may not be relevant to 4x4 diesels. He said they need to be taken to the red line frequently, but not held there. The theory behind this one is that at the top end of the piston speed (high rpm) the conrods stretch that poof'teenth on an inch more, so the ring get higher in the
bore. If you don't they bed in a tad lower, so you never get that tiny extra stoke.
I'm not 100% sure it is all technically correct, but use a conservative version of that and have always had 'good' engines.
446888
Follow Up By: SDG - Monday, Feb 28, 2011 at 19:07
I've been told basically the same thing by bike mechanics.
719261
Reply By: SDG - Monday, Feb 28, 2011 at 19:10
I was told by a diesel mechanic to drive it like you stole it.
446912
