RELIABILITY of the small diesel tow vehicles
Submitted: Wednesday, Mar 02, 2011 at 21:46
ThreadID: 84738 Views:3955 Replies:10 FollowUps:9
Just after some feedback from travellers who use vehicles such as Isuzu D Max, Colorado, Rodeo, Navara D40, Triton, Hilux DIESELS to tow vans around the 2.5 tonne weight.
Reliabilty? Problems?
I am not after comments on clutches. I have an auto Navara D40..
I see plenty of these vehicles on the road.
I am not disputing that the Landcruisers and the Patrols (3 litre??) are better suited to tow vans around 2.5 tonne plus.
These smaller diesels are working harder but do they last? Do people trade them in before they run into problems?
Look forward to comments,
Regards,
Ian
Reply By: TerraFirma - Wednesday, Mar 02, 2011 at 22:21
I think the issue of towing is almost irrelevant to your question. Towing itself does not shorten the life of a vehicle. I can't comment on the other brands but my Hilux is an Auto and tows beautifully (06 TD D4D). If your question relates to towing 2.5 Tonnes well you can't with a Hilux. Diesel's working hard and serviced well should last as long as one that only does some towing IMO.
AnswerID: 447164
Reply By: nick b - Wednesday, Mar 02, 2011 at 22:25
Gooday ian ; A wise man once said theirs not substitute for cubic inch.
AnswerID: 447165
Follow Up By: The Explorer - Thursday, Mar 03, 2011 at 00:36
A few wise women have also said that....:)
FollowupID: 719473
Follow Up By: nick b - Thursday, Mar 03, 2011 at 00:38
sorry i cant see how 4cyl turbo 3 lit can last as long as 4.2 lit pulling 2.5 ton van in the same conditions & situation . 3lit would have to be working hard to pull that weight , but i'm not suggesting it cant do it .
FollowupID: 719474
Follow Up By: nick b - Thursday, Mar 03, 2011 at 00:54
yes i did say "A" wise man (didnt say there was any more) forgot the 10 wise woman
FollowupID: 719475
Follow Up By: The Explorer - Thursday, Mar 03, 2011 at 02:19
...no you didn't ..but I didn't say you did either...however only 10 wise women? Not sure who is in more trouble - you, for proclaiming there is only 10 or me, for being married to one of them :)
FollowupID: 719481
Follow Up By: nick b - Thursday, Mar 03, 2011 at 21:57
hay Greg it sounds like i'm in the ...... again only the depth that varies
FollowupID: 719571
Reply By: Rob J - Wednesday, Mar 02, 2011 at 22:56
Towed my 18ft Jayco around Oz in 2005-06 with a 3litre manual Patrol, 30,000
ks no problems; it had done around 80,000 when I sold it.
Towed my 18ft Jayco around Oz in 2010 with a D4D auto Prado, similar ks and on returning to Busselton WA with 70,000 on the clock and 1 month left on warranty, Toyota replaced all the injectors. the Prado seems to be a lot Quieter than when it was newer.
Both are good towing vehicles, both have done a good job and wouldn't hesitate to buy either again.
Hope this helps
Rob
AnswerID: 447168
Reply By: TrevorMR (WA) - Wednesday, Mar 02, 2011 at 23:01
Most of the utes you list have 3 litre diesels, the same capacity as the Patrol and would have much lighter bodies than the Patrol. Apart from the fact that a heavier body vehicle might have more control when towing a heavier van, I don't see that a Patrol would necessarily be better suited.
AnswerID: 447169
Reply By: Robin Miller - Thursday, Mar 03, 2011 at 07:42
From a similar question I answered a couple of years ago ------------------
Hi Huggy
Have to be brief as gearing up for another dash into the bush.
There are lots of misconceptions in 4wd field and many are feed by
general dumbing down of specs and more interest by buyers in multiple seat
memories than performance.
Typical case is that "diesels have more torque" when all the customer has to
do is turn over the brochure to see the figures.
It is a big field but following generalization is worth while.
The main game in engine life is determined by how much it does
over how big it is. This makes it hard for a 3lt to last as long as a
4800 pulling the same weight.
Indicators of engine wear are the Engine Life Factor (ELF) and the
Brake Mean Effective Pressure (BMEP)
ELF = RPM X Compression ratio
BMEP = Power / (size X RPM)
BMEP is more appropriate for lower reving/output engines like Patrols.
Relative figures for 4800 ,4.2TDI and 3LT GU Patrols are -
4800 = 8 4.2TDI = 7.7 3LT= 10.7
I.E. The 3lt has much higher internal pressures than the others.
This makes it a lot harder to keep temperatures in the cylinder
walls and bearings under control.
The engine pressures resulting from combustion, transfer the
power thru the crankshaft via the main bearings, and heat is
dissipated into cylinder walls and oil etc.
Don't take the above to mean I wouldn't have a 3lt , in fact I think they are great cars , the fact that engine life is shorter than other patrols doesn't mean they cannot give great service for several years.
You just need to work towards an honest apprasil of the products offered and get what most fits your requirement.
Robin Miller
AnswerID: 447183
Follow Up By: gbc - Thursday, Mar 03, 2011 at 10:32
Diesels are a high compression motor and are designed that way - you're ratios would only be of any use comparing petrol/petro and diesel/diesel. Also take into account sleeves etc that diesels have to cope with high compression.
FollowupID: 719493
Follow Up By: Robin Miller - Thursday, Mar 03, 2011 at 11:13
Hi GBC
They are industry standard formula's , not mine , and they set the overall scene , individual variations below this do cover a wide range though.
Basically they say what most except - that cubic inches and low revs last longer.
FollowupID: 719498
Follow Up By: Dust-Devil - Thursday, Mar 03, 2011 at 11:58
You are Sooooooooooooooooooooooooooooooooo! a 'petrol head' Mr Miller. (ROFLMAO)
FollowupID: 719504
Follow Up By: nick b - Thursday, Mar 03, 2011 at 21:47
Robin you mite be a petrol head but i think your spot on ."cubic inch & low revs".
FollowupID: 719570
Reply By: MEMBER - Darian, SA - Thursday, Mar 03, 2011 at 09:53
Just an aside - I wonder how hard the components in the new VW 4 door ute's motors will be working (2.0L ... single or twin turbo)... and how long they could last, when regularly towing the max load of 2.8 tonne. That scenario makes a huge contrast with the huge number of 4.0L+ TD's towing decent loads in Australia at present.... less so, with the many 3.0L's of course..... but still, that is a small motor.
AnswerID: 447192
Reply By: Shaker - Thursday, Mar 03, 2011 at 10:44
I towed extensively with a Nissan Terrano II 2.7 TDI diesel, it had done 400,000km when I sold it & still going strong.
AnswerID: 447197
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Mar 03, 2011 at 15:44
I think that it can have beneficial results too. If a diesel is working harder it will warm up to it's correct operating temp and stay there longer. The biggest problem is that most "Jap type" diesels actually don't get worked hard enough to get to the correct temp. This causes fouling of the rings and can help to cause glazing of the bores leading to oil consumption and a premature rebuild because of gunk. The v8 toyota's are a prime example. If worked hard (not flogged) when new they tend to use minimal oil compared to those that have been babied.
But being fully warmed up and stressed to the max are two completely different animals. personally, give me more cubes anyday.
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 447220
Reply By: iijmartin - Thursday, Mar 03, 2011 at 21:00
Thanks for the replies and the point of views.
Regards,
Ian
AnswerID: 447264
Reply By: Tonyfish#58 - Thursday, Mar 03, 2011 at 21:21
I would not like to be towing that weight full time that's for sure. I tow my boat which would be around two ton for 360k occasionally - I have hilly country and it definitely works the motor.
The temperature gauge rises when hitting the hills and I have to back off the throttle and change down in the gears to keep the temperature manageable.
I have put on 95k now without any major issue, just had one fuel problem with a faulty in tank fuel pump.
They have the power but do not know if they would last?
Cheers Tony
AnswerID: 447273
