hema navergator 5"
Submitted: Monday, Mar 07, 2011 at 14:29
ThreadID: 84855 Views:2882 Replies:3 FollowUps:0
Hi there just got the hema navigator 5' DO I NEAD TO BYE MAPS FOR IT & what ones Thanks Dale
Reply By: Member - Trouper (NSW) - Monday, Mar 07, 2011 at 14:42
Dale, Who did you buy it from? and where? All the maps should be on the sysytem. Turn it on and try it, there should at least be a 'city navigator' type map.
regards....................jeff
AnswerID: 447576
Reply By: Patrol22 - Monday, Mar 07, 2011 at 15:37
For the most part you won't need any maps. The Hema Maps and the NATMAP 1:250K are preloaded as is Route 66 street directory. You can of course load as many different maps as you think necessary....ie 1:25K topo, 1:50K topo etc etc. If you wish to use Memory Map (also preloaded) you may need to buy some maps for that as well.
AnswerID: 447578
Reply By: Member - Stephen L (Clare SA) - Monday, Mar 07, 2011 at 19:00
Hi Dale
Like the others have stated above, it should be just a matter of attaching it to your windscreen, plugging in the power,turning the unit on and selecting what navigation you want to uses and away you go.
The only option that I have purchased was the sun shield.
They are a great unit and I use mine in 100% OziExplorer.
AnswerID: 447609
