driving lights durability
Submitted: Friday, Mar 11, 2011 at 13:19
sco230618
We have moved to the Kimberleys for work and we need some
driving lights.
But we have been told don't fit such and such light they rattle off your bull bar.
Don't fit such and such light the lens falls out.
You cannot fit such and such because.........
I have a Prado with a factory fitted bull bar. We envisage doing the
Gibb River Road and may be part of the Tanami Road and of course the Bungle Bungles etc..... We are experienced drivers and the car will not be thrashed but:- What lights will give the best service. My Lucas Flame Throwers are too valuable to use.
Reply By: Gossy - Friday, Mar 11, 2011 at 13:26
I would say that any light you can buy in the Aussie market should be OK; light quality is a different issue.
I would suspect that anyone selling lights in Aust that cannot handle corrugations would be out of business. Stick with the big name and you can't go wrong (Cibie, lightforce, hella, IPF etc).
447911
Follow Up By: ben_gv3 - Friday, Mar 11, 2011 at 13:37
That's a whole lotta assumptions there.
There's a reason why the likes of Narva sells stabiliser bars:
Narva bars
IMO I would buy plastic bodied lights if you're worried about corrugations etc., eg Lightforce, some of the Nightstalkers.
Lots of people use metal bodies lights so it's horses for courses I think
720268
Reply By: badman - Friday, Mar 11, 2011 at 14:00
It seems for the most part you get what you pay for in lights. I recommend HID as they are more durable as they contain no wire element to break, LED if you can afford it: litestorm.com.au look pretty good. And Loc-tite the buggers in place, they won't move.
447915
Reply By: Mick O - Friday, Mar 11, 2011 at 14:03
Timely that the latest 4X4 Action mag have just done a BIG compare on
driving lights. They tested 30 odd models in Halogen, HID and LED. Results were quite amazing. There is a hell of a difference between brands and not all the big boys performed as
well as you’d expect for that sort of money. They also looked at durability, mounting and the robustness of the wiring looms.
Well worth a read and may solve your issue for you.
Cheers Mick
447916
Follow Up By: Michael ( Moss Vale NSW) - Friday, Mar 11, 2011 at 16:25
Mick, How did their advertisers and sponsors lights fare??? :) Michael
720283
Follow Up By: Mick O - Friday, Mar 11, 2011 at 18:19
Ha Ha. Not as significantly as they would of in that other infomercial mag. No they stopped short of making any recommendations other than a stamp on some like "best value HID" etc. I felt pretty sure it was going to be a sponsor-fest but I was pleasantly surprised in that it appeared quite balanced and basically let the results of the various tests speak.
What surprised me was the actual price of some of the lights. I was gobsmacked by the HID prices in particular. Struth it's been a long time since I bought a set of
driving lights. Next time I see a ute-muster, B&S Bundybear rig festooned with
driving lights, I'll be left wondering just which bodily organ they sold to pay for them all ;-)
Cheers Michael.
Mick
720289
Follow Up By: Michael ( Moss Vale NSW) - Friday, Mar 11, 2011 at 18:42
Yes !! I cant see the value in some lights, a few hundred dollars would see me out,, I actually still have the IPF's that came on the Patrol as freebys when i got it new..They do the job.. It would be nice to have good lights, but for me, I rarely do night driving, those days are long gone and i don't need to see that far down the road that shows the curvature of the earth!! Michael
720297
Reply By: Member - Stephen L (Clare SA) - Friday, Mar 11, 2011 at 14:12
The
driving lights will be the least of your worries, and I am not being cynical and speaking from personal experience with a 120 Series that was once fitted with a genuine alloy bar.
Keep a very close eye on the factory bar mounts, they are not made for dirt roads. Make sure that you get them upgraded, for which ARB have been given the job of supplying mounts that should not fail.
I have done some research into the problem and you will find it is very common.
All the best
447917
Reply By: goddosglory - Friday, Mar 11, 2011 at 14:22
before you go parting with your money...ask your self the question?????
how often will i be using them...i have just done that trip....i decided not to
buy them...the amount of wild life on those roads at night..it is far safer to be camped between dusk and dawn..secondly they reduce the air flow to the radiator..not a good idea given the heat and humidty in the area !!!!
447919
Reply By: Member - Rowdy6032 (WA) - Friday, Mar 11, 2011 at 14:30
For what it's worth I have a Prado 120 with the factory fitted bar and Lightforce 240.
Have done the Bungles and
Gibb River and no problems with lights. Suggest you place spring washers or similar on bolts otherwise they will shake loose.
Mine didn't originally when fitted and came loose even on smooth road.
Your more likely to lose your front number plate on the Prado doing
creek crossings into Bungles as I and others found by experience. Try and secure that.
447921
Reply By: Muntoo - Friday, Mar 11, 2011 at 15:07
Hi, i previously owned a 120 Prado with genuine bar.
One thing is for sure, dont get the Lightforce 240 Blitz on that bar. They shake like hell on a normal bar on corrugations, never mind on the 120 Prado.
Hella 4000, loctite all bolts, and keep a good eye on them. They fall apart if dont have loctite. Stay away from plastic lights, as they wont last up here either.
The IPF900XS is great, no dramas whatsoever, and take a HID upgrade very
well. Good mounting system too.
Otherwise the Lightforce genesis or XGT would be the next best for surviving, but they are only good for spotlights, not
driving lights.
The Nite Stalker 170 and 210 seem to last as they are the same basically as the IPFs. But the only IPFs worth owning are the 900XS.
Make sure you use spring washers, and maybe even some rubber with the alloy bar. I have seen spotties rip holes out of the bar from overtightening, yet still rattling loose.
Welcome to the
Kimberley.
447924
Reply By: hotfishez - Friday, Mar 11, 2011 at 15:19
Lightforce XGT, blitz or genesis, HID if you want to spend the extra. Their standard lights are more than sufficent. Warranty is currently 3 years nqa and looking at going lifetime warranty. They will replace the lights if they were ever to fail or break etc. They are light weight and less likley to break bar mounts not that it will be a problem on the prado bar as from memory they bolt directly the the main bar. From experience and bang for buck, my preference are the lightforce XGT non HID are fine.
They are an Australian made product and Australian owned company.
447925
Reply By: Ozrover - Friday, Mar 11, 2011 at 15:20
I've had a set of Lightforce 240 Blitz lights on my last three 4wds, these are the same lights with the original bulbs, they've done two trips up
Cape York Peninsula, across the Gulf & uncounted kilometres around the centre, they've been under
water for over 24 hrs, run into cattle & are still in great condition.
When they do finally give up the ghost, I'll be looking for another set, they're only drawback for me is that the beam is a bit narrow.
447926
Reply By: Joe Grace Doomadgee - Friday, Mar 11, 2011 at 15:26
easy fix man..... i have lived in remote areas for a while with bad roads always and here is what you do:
Get a 2 1/2 " dia hose clamp and cut it in half so the "worm" drive thingy is in the middle when flattened out, you of course flatten it out and next step is to "size" it up against the top of the light and the roo bar, you want to be able to drill a hole in each end of the clamp to take 2 rivets or ss screws and what you need to aim for is getting one end of the clamp attache to the top or upper part of the light and the top of the roo bar, best way is to have the lights mounted and pre aligned then remove the lens body, when you have worked out where it will sit best and allow some adjustment you mark the holes and drill them and bolt/rivet it all up and you will have viabration free light that will not crack around the base.
I would take a pic of
mine but not sure how to attach them yet, will give it a crack so you can see but wont promise nuthin......
On having lights to "valuable" to use, why have them as it is this time you need the best you can get, whack em on with the clamp adjustors and you wont regret it .....
Joe
https://picasaweb.google.com/109510533237575983470/LightStabilizers?authkey=Gv1sRgCIjak8abodWnPA#5582673175170633522
447927
Follow Up By: Member - Joe n Mel n kids (FNQ - Friday, Mar 11, 2011 at 18:27
Image Could Not Be Found
720291
Follow Up By: Member - Joe n Mel n kids (FNQ - Friday, Mar 11, 2011 at 18:29
720293
Reply By: Tim - Friday, Mar 11, 2011 at 16:35
I'm out in western NSW and have seen countless tourist vehicles come through with the lens missing off the lightforce mounts and two wires hanging out so I would never go for those myself.
Tim
447930
Reply By: JR - Friday, Mar 11, 2011 at 16:43
3 patrols, 420'000km total so far, 50%+ off tar roads, same set of lightforce 240, just upgraded to HID bulbs. Some others have equal or better light but these are seriously tough. Being so light reduces problems from vibration and corrugations.
Only down side Ive heard is they are easily stolen. Not such an issue out here.
As mentioned some alloy bars vibrate terribly due to material and how they are mounted.
447931
Reply By: Wilgadene - Friday, Mar 11, 2011 at 16:56
I bought a pair of Narva light from ebay about three years ago (they were $130 at the time) and put them on our 100series bull bar. I didn't expect them to last forever but to date they are still going strong. So far (cross finger's) haven't blown a bulb, haven't rattled loose and haven't cracked in 60,000km. They have done the
Gibb River Rd,
Cape Leveque, and many other rough as guts roads without any drama's. Fair enough they don't burn the eyes out of Kangaroo's and other wildlife 2km away but I have found they do a good job for a very reasonable price. Not a big outlay if I break them or they get stolen (probably no one silly enough to steal budget price lights)
Here is a link to similar lights
Site Link
447932
Reply By: ABR - SIDEWINDER - Friday, Mar 11, 2011 at 16:57
I had to google 'Lucas Flamethrowers' as I have never seen them before.
My own HIDs have been on the new Prado for 16 months and are still there and working
well after quite a few trips and harsh roads. I switched from pencil beam to wide beam as I prefer the wide beam.
Derek from ABR
447933
Follow Up By: ABR - SIDEWINDER - Friday, Mar 11, 2011 at 17:26
Here is a picture that is not moving.
Derek from ABR
720286
Reply By: Shaker - Friday, Mar 11, 2011 at 18:52
Cibie Oscars are very strongly mounted & good lights.
447943
Reply By: Member - David G (WA) - Friday, Mar 11, 2011 at 20:21
Having lived in the West Kimberly for a number of years and being a Truck driver too i for the life of me cant see why you would leave your good lights at home because of their value when driving at night surely warrants the best especialy in the north of this state where you have livestock and wildlife roaming around on all major and minor roads and tracks
perhaps the flamethrowers just look good but dont have a very good light or are they only good for travelling around the city
Cheers Dave
447950
Reply By: sco230618 - Saturday, Mar 12, 2011 at 11:27
A. The Lucas Flamethrowers are valuable because in a couple of years they will be genuine antiques..
B. They are "Lucas" and made in England where they don't have corregations.
No better to leave them in
Melbourne on the TR3.
Now back to the real question:-
Thanks for all the information.
I do need the lights as I will need to drive at night for work at times.
I did use the idea of the radiator hose clamps when rallying and that worked to stop vibration.
I will now digest all info and let you know the results.
447983
Follow Up By: Member - Rod O (SA) - Saturday, Mar 12, 2011 at 16:01
Just got a letter from Toyota the other day to get the factory bullbar mounts on my 120 replaced by Toyota ASAP. I guess they have had some feedback about failures...
720341
Follow Up By: macbushy - Saturday, Mar 12, 2011 at 20:50
Ohhh no
Firstly i sell my loved 24 valve 80
Then bought a 08 120 Prado
Looking for info on spoties as my 7 yo super oscars wont fit
And just as am trying to decide between Oscars, Lightforce or HID I learn the factory bar might fall off.
Is there any way I can find out if this new (still being delivered) 120 has had the mounts replaced?
720384
Follow Up By: crash69 - Sunday, Mar 13, 2011 at 12:58
Toyota recall letter suggests you contact your Toyota Dealer if unsure if this applies to your vehicle. Alternative is calling Toyota Customer Support Line on 1800 987 366 between 8.00am and 6.30pm Monday to Friday (DST).
Just had my mounting brackets replaced, look much more substantial than old ones. Never had a problem with old ones, Prado 120, 2004 build, 250K+.
Good Luck
720427
