electrical help please
Submitted: Monday, Mar 21, 2011 at 18:54
ThreadID: 85146 Views:2701 Replies:7 FollowUps:10
Related Pages
Hi All
I am trying to calculate how many amps per hour a fan will pull from a battery. Given I=P/V The fan in question is 280 watts and it will be run from an inverter. Loses from using the inverter aside, this gives me 1.16. How do I equate this figure into amps per hour drawn.
Thanks Guru’s :-)
Cheers Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Roughasguts - Monday, Mar 21, 2011 at 19:01
I would just but a 12 volt fan from super cheap around 20 bucks.
Cheers.
AnswerID: 448870
Follow Up By: Robin Miller - Monday, Mar 21, 2011 at 19:26
Lyndon used a figure for the fan of 280 watts roughasguts so masively bigger
than a 12v supercheap one.
Maybe an error some where - can you clarify Lyndon !
FollowupID: 721136
Follow Up By: Lyndon & - Monday, Mar 21, 2011 at 19:33
yes Robin, 280 watts, it's a big sucker. It will be used for a group of people.
Cheers Lyndon
FollowupID: 721138
Reply By: Lunar 1 - Monday, Mar 21, 2011 at 19:11
Current is an instantaneous value so it will draw the same at all times. If you're trying to work out how long a battery will last you can divide the amp/hour rating of the battery by the current of the fan. i.e a 7 amp/hour battery can supply 7 amps for 1 hour or 1 amp for 7 hours.
Inverters are a really inefficient way to supply power and you would almost certainly be losing as heat, as much as you got to actually use. A dedicated 12v appliance is always a better option if possible.
AnswerID: 448872
Reply By: Member - Robert R1 (SA) - Monday, Mar 21, 2011 at 19:12
Lyndon,
If you run the fan for 1 hour you will use 1.16 Ampere Hours.
Regards,
And he sees the vision splendid of the sunlit plains extended, And at night the wondrous glory of the everlasting stars. Clancy of the Overflow.
AnswerID: 448873
Follow Up By: Lyndon & - Monday, Mar 21, 2011 at 19:37
Hi Bob
Do you know what efficiency percentage I could apply to the inverter (roughly). I don’t think it will be as bad as stated above as 50 percent. Maybe 80 percent?
Regards Lyndon
FollowupID: 721139
Reply By: Member - Boobook - Monday, Mar 21, 2011 at 19:39
If you use it on 240V it will draw 1.16Amps.
When connected to a 12V battery it will use about 300Watts or ..........wait for it 25 Amps.
In other words a large N70 cranking battery will last about 2 - 3 hours before it is fully discharged.
AnswerID: 448880
Follow Up By: x4by4 - Monday, Mar 21, 2011 at 19:56
Hi Boobook,
Agree completely.
Your post was not up when I sent mine :)
Pete
FollowupID: 721143
Reply By: x4by4 - Monday, Mar 21, 2011 at 19:52
Hi Lyndon,
280 W /240 = 1.167 Amp (at 240 volts)
If the inverter is 90% efficient, 280w/.9 = 311 Watts
311 W / 12v = 26 Amps, so the inverter will be drawing 26 Amps from your 12v battery.
So if you started with a fully charged 80 AH battery you would only get about 2 hours before the battery voltage was below 12v
The Ampere-Hour rating of a battery is normally done at 20 hour rate but if you discharge a battery down to the voltage they use you will drastically reduce the life of the battery.
Pete.
AnswerID: 448884
Follow Up By: Lyndon & - Monday, Mar 21, 2011 at 21:02
Thanks for that. It would be run from 3 x 50 amp AGM Orbital’s in parallel, so I guess I should get 4 hours run time no problems. The batteries will be charged via an 80 amp Christies Charger.
Everyone in agreeance with the method used by x4by4?
FollowupID: 721161
Follow Up By: V8 Troopie - Tuesday, Mar 22, 2011 at 01:35
That sounds like you do not value your batteries life expectancy a lot.
What you are saying is that you have a battery capacity of 150Ah and you are going to use 100Ah (roughly) of that before recharging.
If this was my set up I would aim for a 400Ah battery capacity and discharge these only by 25% whereas you plan to discharge your batteries by 66%.
You may get away with it for a while *if* you recharge these batteries promptly - keeping in mind they might take a while to get fully charged again.
Think of batteries like a tank you must fill up completely but are only allowed to use a fraction of the contends before the next refill. The smaller that fraction the longer your batteries will last.
FollowupID: 721191
Follow Up By: Lyndon & - Tuesday, Mar 22, 2011 at 08:08
I’m still a bit confused, let’s say I run the fan at home on 240v, are you saying it would then only use 1.16amp/hour?
FollowupID: 721197
Reply By: Battery Value Pty Ltd - Tuesday, Mar 22, 2011 at 09:02
Lyndon,
here are some figures for you:
fan: presuming the fan blades are driven by an induction motor (brushless, the ones with a cylindrically shaped capacitor), the active power of 280W has to be divided by the power factor of around 0.75 to get to the apparent power of 373VA.
Divide this by 12V and you get 31A.
Divide this again by the efficiency of the (has to be pure sine for the induction motor to work properly) inverter of 0.9 and the battery current is almost 35A.
Divide this by 3 and the current per battery is 11.5A.
Looking up the discharge tables for 50Ah spiral wound AGMs, this will result in 4 hours of run time which coincides nicely with your expectations.
Two important things: have a low voltage cutout device, set to around 10.8~11.0V, to prevent the batteries from getting over-discharged (this might be an in-built feature of the sine wave inverter).
Charging: using your generator, the batteries will be about 90% charged after 2.5 hours or so.
If you expect the batteries to give you the specced cycle life (around 300 at 100% DOD), you have to push at least 100% of charge back into them before discharging again.
This may take another 10 hours of slow absorption/float charging.
Solar might be an option for this.
If that's not on the table, the batteries will only be good for a sustained 3.5 hours run time (at some loss of cycle life).
Occasional topups and equalisation charging is definitely recommended for optimum battery health in your application.
cheers, Peter
AnswerID: 448926
Follow Up By: Lyndon & - Tuesday, Mar 22, 2011 at 19:17
Hi Peter
Thanks for your input, it is much appreciated. I guess the main question I now have left is charging the batteries whilst running the fan and or other accessories. I have heard this is a real no no, but is this always the case? Is this because the charger continues to charge even when batteries are full because it is unable to detect this due to draw on the batteries? What if after running the fan for two hours I run my charger for an hour, assuming that 60 or so amp’s have been drawn, is there any harm in putting 50 amp’s back in whilst the fan continues to draw?
Hope that make sense?
Thanks for your help.
Lyndon
FollowupID: 721249
Follow Up By: ctaplin - Tuesday, Mar 22, 2011 at 23:11
Hi Lyndon, all of Peter's calculations are correct and if I put my DC current tong tester around one of the leads feeding your inverter, I would expect 25-30 amps at least as your inverter isn't a pure sine wave unit.
After cyclone Yasi, we had no power for 48 hours so I hooked up my 1000 watt Sinegex pre sine wave inverter to a 100Ah deep cycle battery just to power our 400l household fridge/freezer unit. It was rated at 200 watts on the nameplate and the 12 volt DC current being pulled from the battery was 16 amps. I was amazed at the altenators ability to put heavy current back into the battery in my current model Hilux D4D 4x4 as my tong tester was reporting 30-40 amps of charging current into the aux battery even at idle. As Lyndon knows, I'm a qualified electrician so these are real figures from someone that knows what their doing...
Chris
FollowupID: 721289
Follow Up By: Lyndon & - Thursday, Mar 24, 2011 at 08:09
Thanks Chris
FollowupID: 721423
Reply By: landseka - Thursday, Mar 24, 2011 at 17:41
Just trying to think outside the box here. If you have a generator or some other 240v power to charge the batteries ("even while the fan is running" ) why not just run the fan from that supply???
AnswerID: 449146
