Jayco Swan water tank
Hi All,
I have a 2010 jayco swan and for the life of me I cant find the drain plug on the water tank. How am I supposed to drain the water in there?
If anyone knows on my model where it is could you describe the location?
Cheers.
Reply By: landed eagle - Sunday, Mar 27, 2011 at 08:42
I imagine they would be the same tanks as the expandas. Mate has a 2010 model and mine's a 2009. Both the same. The drain plug is a knurled knob where the water filler inlet goes into the tank. Both of ours have a blue plastic washer to seal them.
AnswerID: 449335
Follow Up By: franklKTM450 - Sunday, Mar 27, 2011 at 09:19
Oh, yes... I seen that. I did try and give it a twist but it was very tight and to be honest i wasnt expecting it to drain from there. Thanks Landed Eagle.
FollowupID: 721731
Follow Up By: Member - Toyocrusa (NSW) - Sunday, Mar 27, 2011 at 11:09
Yep. Same on my 2010 Sterling. I found my filler pipes (The 40mm clear plastic ones) had algea in them after 6 mths so have removed them and changed the filling system to mains pressure through John Guest fittings and pipe and through a two stage water filter. Have also replaced the breather pipes with JG pipe as well. Cheers,Bob
FollowupID: 721737
Follow Up By: Member -Dodger - Sunday, Mar 27, 2011 at 17:00
If you have trouble getting the bung out then disconnect the pickup hose at the tank as it is usually @ the lowest point.
You can get a tap that will fit the thread of the bung making it easier next time.
Cheers Dodg.
FollowupID: 721772
Follow Up By: franklKTM450 - Sunday, Mar 27, 2011 at 21:35
Hi Dodg,
where can I get the tap from? What size?
FollowupID: 721809
Follow Up By: Member -Dodger - Monday, Mar 28, 2011 at 08:25
There is a small screw in outlet that is available from most caravan supplies or Bunnings then just add an in-line plastic tap from garden irrigation.
You could probably get both from Bunnings just take the bung in with you for size and thread patern.
Another way is to put a T junction in pickup line near outlet and put an in-line tap just after T.
All fairly easy if you study your system and have a good think.
Cheers Dodg.
FollowupID: 721831
